No a 690 won't max out 5760*1080 even in BF3 never mind BF4. You're limited by GPU grunt... so you have low FPS as opposed to hitting the VRAM wall.
There's not much point watercooling the 690 IMO. You're paying for the aesthetics. May as well get SLI 680s if that's your plan as they will be a touch faster as well.
Sorry, not read the whole thread: is there any reason you aren't considering AMD? Especially with water cooling as the AMD cards can fly under water with the unlocked voltage.
Reason being:
Image removed
(my own benches so not biased at all)
I when I say the 690 is a fail, I mean in surround gaming! its going to be a long long time before 1080p requires more than 2GB and I am sure a 690 will be long term investment for the owners![]()
Good numbers but it doesn't show the whole picture including frame latencies and microstutter. Before I decided on going down the Nvidia route I was going to get a pair of 7950s... That said I've never seen a pair in action and I'm sure they're better than my current card for higher resolutions.
So am I right in saying a Titan will be the best choice for my needs then![]()
I think The Titan is the best choice for everyone!
I'm buying one because:
1) It's the fastest GPU on the market.
2) It's 40-50% faster than a GTX680.
3) You don't require SLI to run a single-[high-res]-monitor, or even up to 3 monitors at 1080P. [No micro-stutter, or driver issues, or game issues]
4) It's a lot quieter than other solutions.
5) It will allow me to upgrade my monitor(s). Either a large 1440P monitor, or a Dell Ultra Widescreen [or similar] - I'm not a big fan of 3 monitor gaming!
6) It has massive amounts of VRAM [Bring it on PS4].
7) It chews threw everything you can throw at it, and more.
8) It's called TITAN.
Seriously though, I got paid a ton of overtime from Xmas. It's the only real reason I'm getting one. That £800 will be encapsulated by my salary and other savings [saved £700 last month!].
You would be better off with a GTX 690
More performance
No microstutter
In its element @1440p
Looks even sexier than a Titan
I am not getting a 670 or a 680 again. Definitely either a titan or 690 but I just can't make my mind up. I have to RMA my memory on my PC and I have probably missed out on the 1st batch of pre orders so think I will wait for more feedback on the titan.
Or I may just pre order a PS4 cause that's faster than a Titan and 690 soldered together....![]()
How will you enable super sampling, multi sampling or down sampling on that console to get rid of the jaggies ? Will that joypad make your aiming more precise ?![]()
Lol, no it's not. Not even close to a 690. Maybe for a year or two it would be more feasible to get the PS4 over a decent PC. But after that year (or two) it falls behind PC's again.
I’m an Nvidia fan boy always have been but £850ish for a single GPU is just plain mad... Why I hear you ask... well in 6 to 8 months Nvidia will have a new GPU out "I don’t know call it a Titan + Boosted edition or a 780/790" clocked @ 1.4 GHz & running 4GB of vram for £500. Personally I think Nvidia screwed over everyone who bought a 680 mid ranged GPU and for that reason I would not buy into an over rated... over priced... Single GPU from the green team @ a hefty £850.
If you can wait... If you can’t then may you could consider MSI HD 7970 Lightning BOOSTED Edition 3072MB.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-181-MS&groupid=701&catid=56&subcat=
