- 9 Jan 2013
- Worthing, West Sussex
Will a Builder series 430w handle a 7850 2GB GPU okay?
Those PSU's suck, not sure how efficient they are but they are not reliable in terms of life.
With an i5 3570k + a 7850 including all the other gear you will probably be pulling about 350 under full load, I read a review once that was pulling as low as 230 during benching.
Only problem is you do not leave much headroom for upgrades.
CX430 are budget range so use cheap caps etc they aren't really that good
those psu's are not that great and just because its corsair people take it for granted that its a good psu when it fact its ok but not great.
something like the xfx pro range are great.
for a similar price you can get XFX 450w which is produced by Seasonic..meaning better quality caps etc.
In case you haven't caught on yet.... this power supply is a Seasonic S12II. It's one we've reviewed a couple times before under different brands and with different wattages and it's one that does not use DC to DC VRM's and it does not use solid caps
You should be fine. My system is a AMD X6 overclocked to 3.6Ghz, they're not exactly energy efficient CPU's! plus a 6770, which is a fairly power hungry card.
I used a plug in power meter and the max I could draw from my system was 255w at the socket. I then crossfired it and it went upto 360w. You probably wouldnt want 430w at the socket from a 430w PSU but if your system is pulling roughly 250w then a 430w should be man enough to cover it.
Source?
Source not required its a Corsair product 99% of there products die.
Ignore this guy, He's talking crap.
