Sorry - I assumed this was a CPU related thread and these low res ones have their place in that context. Maybe use a couple of Titans and benchmark at 1080p instead, hang on I'll get back to you on that one
There are already Titan and GTX 690 tests out there at 1080P and 1440P, all of them show the opposite to your link.
They didn't even bother to test or show results at resolutions that people actually use.
I also don't trust reviews that only show you low resolutions no one uses.
The idea that lowering the resolution is a dead certainty for showing the CPU's gaming performance is probably a misunderstanding.
At low res the game does not require much from the hardware, in some games it may not even need the CPU, be that as it may, if C&Q is turned on the CPU may even go into a power saving state.
I'm not saying that's whats happening here, just that the review is incomplete as it only has one aspect, an aspect that is not even relevant.
The fact that every other review has the FX-8350 significantly faster than the 3570K at 1080P / 1440P on a Titan or GTX 690 is probably a good indicator that something else is going on.
One thing i have noticed with Crysis 3, which is different to any other game i know, is that applying any AA puts the load on the CPU, to much, and you?/i end up with a MASSIVE CPU bottleneck, none at all, and the CPU is registuring far less use. You also don't need any core to get anywhere near maxed out for it to start bottlenecking the GPU.
I don't know what CPU usage looks like/ what effect it has with this game on Intel or the FX CPU's, but on my old Thuban,
it makes no sense, i can get what looks like big CPU caused bottlenecking, and yet not one of my cores are over 60 / 70%. (on Planet Side 2 i get one miserable lonely core that's constantly pegged at well over 90%,
Pile of Crap game) Stock vs overclocked also seems to have nothing more than little effect on performance, having said that 'i think' the CPU-NB and Memory does. < need to do more testing.
The game seems to use the CPU differently to what, at least my CPU, was designed for.
That there is a whole different discussion on its own.
Far more information than they provide is needed to explain their discrepancy from other reviewers, thats for sure.
