What sort of issues?
I have 1 670 and can play in mosty very high, no aa 1440p
doesnt it depend on the manufacturer though?
KFA2 EX OC 670 + user overclock will naturally have greater performance than a reference model 670 with no overclock.
although looking at cHk4 having SLI 670's, i wouldnt expect low frames on anything! XD
Low FPS mate, that's at everything at the highest it can be. Even when I drop a few things I'm having issues ( low fps )![]()
How low? 1440p or 1080p?
1600P, but I have also tried it at 1200P and still get the same.
I'll have to run fraps tonight but I'm estimating as low as 15.
Ok mate, cheers for that will try different driversSomething is knacked then, maybe with drivers. My single 670 in highest settings gets around 30fps. Downing to high increases massively, as does dropping the res
Tbh, anything below high isn't acceptable for gaming in my standards. If i was forced to use medium i would upgrade, but high is very much acceptable, i might drop down my very high settings to high just to hit 40fps.
What res are you at?
I noticed light effects on water totally disappear when going from very high to high - might have to leave that on v high too
1600x900, currently i've only changed shadows, shading and objects to high, the rest are on very high.
