650W Corsair PSU enough?
8 Sep 2010
Kent
I am probably going to pick up another 680GTX towards the end of this year and just wanted to know whether I will have to get a new PSU when I do or will what I have already be sufficient for power?
Also, what's the average life expectancy of that sort of PSU in a gaming PC that gets around 5 hours of use each day?
Im guessing his Corsair is a CX, HX or TX model with a 3 year warranty so they prolly last around 5 years before the caps start wearing out me thinks.
Those ranges AFAIK are made by CWT, Flextronics etc.
A Seasonic would last at least 7 years to my reckoning since they already have 5 year warranties.
Thanks for all the replies thus far.
I have overclocked my 3570k (only via the multiplier) and the 680 is OC'd via the boost (no voltage). Looking like a new PSU may be in order anyway then, as it has been running for about 2.5 years...
Doesn't Corsair provide a 5 year warranty? Or is that only more recent PSUs? I also thought they used the same internal components as Seasonic.
Sorry yes its the CX range with a 3 year warranty and the others with a 5 :)
Corsair only use Seasonic on three of the AX range if I remember correctly, the other models use cheaper OEMS.
They've re-done their OEM's this year then?
Last time I checked a similar site to that late last year they only had 3 of the AX range and used a lot more Flextronic.
I'd be a little cautious running a pair of 680's on a 650W PSU and I'm usually the one posting 'you could run that on batteries'
You might get away with gaming but Furmark and Crysis 3 could be to much.
I can draw >650W from the wall socket in Furmark with a pair of GTX560Ti's so that's around 550W DC. Pretty much on the limit for my Corsair HX620.
In gaming it's a good 100W less though I hear Crysis is very hard on GPU's
I'd be looking at 850W for a pair of 680's
AD
