- 17 Nov 2011
I just want to see if it would be cheaper to build a PC around the PS4s spec's .... if you get me
I just want to see if it would be cheaper to build a PC around the PS4s spec's .... if you get me![]()
I thought they showed some specs at the PS4 reveal ... my bad!![]()
I'd put money on being able to build a PC that is just as, if not more, capable for the RRP than a PS4.
But it will still be a PC and not a custom, uniform design, with hundreds of developers working to make games run on JUST that spec
3570k + 7950 + 8GB 2133mhz Ram and you're golden.
Seriously doubt its 8GB VRAM. I'm sure is the system memory. If its an FX based AMD processor the RAM surely will be GDDR3. Underclocked with some customisations to keep the CPU cool.
I'm guessing 7000 series based GFX with 2GB VRAM. Maybe the equivalent to 7870.
