Lost Settings - Ultima Viper" Intel Core i7 930 2.80GHz @ 4.00GHz DDR3 System
28 Feb 2013
Blackpool, UK
Hi,
I recently had to swap out one of my HDD's but discovered my wonderful ex (:rolleyes:) had put a password on my BIOS! Therefore I had to press the CMOS reset switch.
As a result I have lost my overclock settings. I contacted OC and they suggested I post here.
Can any of you help please?
System Specification
- Power Supply: Corsair TX 650W ATX
- CPU: Intel Core i7 930 2.80GHz
- Motherboard: Gigabyte GA-X58A
- Cooler: Prolimatech Megahalems Rev B CPU Cooler with Sharkoon 2000RPM 120MM Fan
- RAM: Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel
- Graphics Card: EVGA Nvidia GTX465
Thanks in advance.
Kaitlynn
its 4ghz
you need to post your default cpu voltage when you set cpu v to normal in the bios and qpi/vtt voltage
then i can help you with settings
Hi, use these as a guide-
BIOS SETTINGS 4.0GHz -
Adavanced CPU Features - [A = AUTO][E = ENABLED] [D = DISABLED]
CPU CLOCK RATIO----------[a] - 4.0GHz - [21]x191 / 4.2GHz - [21]x201
INTEL(R)TURBO BOOST------[A] - E
CPU CORES E------------[ALL] - ALL
CPU MULTI THREADING------[A] - E
CPU ENHANCED HALT (C1E)--[A] - E
C3/C6/C7 STATE SUPPORT---[A] - D
CPU THERMAL MONTIOR------[A] - E
CPU EIST FUNCTION--------[A] - E
VIRTUALIZATION TECH------[A] - E
BI-DIRECTIONAL PROCHOT---[A] - E
UNCORE & QPI FEATURES -
QPI LINK SPEED-----------[A] - 36
UNCORE FREQUENCY---------[A] - 17
ISONCHORNOUS FREQUENCY---[A] - E
INTERGRATED PERIPHERALS -
ICH SATA CONTROL MODE----[IDE] - ACHI>SSD
STANDARD CLOCK CONTROL -
BASE CLOCK[BLCK]CONTROL--[A] - E
BCLK FREQUENCY [MHz]-----[A] - 201x20=4.2GHz / 191x21=4.0GHz
PCI EXPRESS FREQ[MHz]----[A] - 101]
C.I.A.2------------------[A] - D
ADVANCED CLOCK CONTROL -
CPU CLOCK DRIVE----------[a-OPS] - 800mv
PCI EXPRESS CLOCK DR-----[a-OPS] - 900mv
CPU CLOCK SKEW-----------[A-Ops] - OOOMV
IOH CLOCK SKEW-----------[A-Ops] - 000MV
ADVANCED DRAM fEATURES -
PERFORMCE ENHANCE--------[A] - TURBO
EXTREME MEMORY PRO[XMP]--[A] - D
SYSTEM MEMORY MULTI[SPD]-[A] - 8x=1608mhZ
DRAM TIMING SELECT[SPD]--[A] - EXPERT
CHANNEL A+B+C TIMINGS SETTINGS[ALL THE SAME] -
##CHANNEL STANDARD TIMING CONTROL##
CAS LATENCY TIME---------8 [A] - 9
TRCD---------------------8 [A] - 9
TRP----------------------8 [A] - 9
TRAS--------------------24 [A] - 24
CR-----------------------2 [A] - 2
##CHANNEL ADVANCED TIMING CONTROL##
TRC----------------------[A]
TRRD---------------------[A]
TWTR---------------------[A]
TWR----------------------[A]
TWTP---------------------[A]
TWL----------------------[A]
TRFC---------------------[A]
TRTP---------------------[A]
TFAW---------------------[A]
COMMAND RATE[CMD]--------[1]
##CHANNEL MISC TIMMINGS##
ROUND TRIP LATENCY-------[A]
ADVANCED VOLTAGE CONTROL -
CPU-LOADLINE CALIBRATION-----[a] STANDARD - LEVEL 1 - LEVEL 2 - ENABLED TO Level 1 = 4.2GHz / 4.0GHz
CPU VOLCORE--------------[0.00000v]
DYMANIC VCORE[DVID]------[0+00000v auto] to set DVID = NORMAL/[1.3250- 1.25625 = +0.06875v DVID] 4.0GHz
QPI/VTT VOLTAGE1.150v----[A] - 1.315v
CPU PLL 1.800v-----------[A] - 1.800v
MCH/ICH -
PCIE 1.500v--------------[A] - 1.500v
QPI PLL 1.100v-----------[A] - 1.140v
IOH CORE 1.1v------------[A] - 1.120v OR 1.100V
ICH I/O 1.50v------------[A] - 1.500v
ICH CORE 1.1v------------[A] - 1.140V OR 1.00V
DRAM -
DRAM VOLTAGE 1.500v------[A] - 1.540v
DRAM TERMINATION 0.750v--[A] - 0.750v
CH-A DATA VREF---0.750v--[A] - 0.750v
CH-B DATA VREF-----"-----[A] - --"--
CH-C DATA VREF-----"-----[A] - --"--
CH-A ADDRESS VREF-0.750v-[A] - 0.750v
CH-B ADDRESS VREF---"----[A] - --"--
CH-C ADDRESS VREF---"----[A] - --"--
MCH/ICH -
DRAM -
OK thank you
MCH/ICH -
DRAM -
Unfortunately I cannot find half the things shown above in my mobos cmos settings. Is it for a different mobo?
It's probably best to carry out the overclocking process rather than attempting to guess the original profile settings. I found this guide to be the most helpful:
http://www.overclockers.com/3-step-guide-overclock-core-i3-i5-i7/
If your chip is a D0 you can most likely leave everything at default and just change the bclk to 200, multiplier to 20, disable turbo + eist + c-states, and increase the qpi/vtt and core voltages until stable. Then you can probably test stability with eist and c-states on.
OK thank you, I will try this :)
If your still having problems I have one of these systems. Ocuk saved the o/c profile to one of the bios profiles as I had to enable mine when I received it. Can check my settings any time if you need.
Hi,
I also have one of these systems but lost the overclock if you could either check and post settings here or pm me them that would be fab
Cheers
Yes I am still having problems, would be great to see your settings please :D
Have you checked in your bios to see if the original ocuk profile is still present ? I will check my bios settings and post them for you.I have some photos of my bios I could email if it would help. Would post them but never have any luck with images and the forum.
From the main bios screen press F12 this will load the cmos from bios, there are 8 profile slots. My ocuk profile was 1. As for passwords these can be removed by pressing enter on the password item and pressing enter again, should then get message saying password disabled.
pic 2 shows when I had a faulty stick of ram hence the missing timings. Hope these help let me know if you need more info.
