D-Link DIR615 Not cutting the mustard, suggestions??
15 Oct 2007
Bedfordshire, UK.
I bought a d-link dir-615 last year to be pair up with the virgin superhub in modem mode, as the superhub was downright awful for wireless use. We now have our nephew saying with us who has a Xbox 360, which now brings the 360's in the household to 3!!, the bedroom where the d-link and 1st 360 is in is at the top of the hallway and the other 2 rooms with the other 360's in are the next 2 down the hallway, whilst the room nearest the d-link reports a full 4 bars on the 360 wireless test the furthest bedroom (which isnt really that much further away) with the final 360 in mostly only reports 2 bars sometimes 3!. The 360 in this room is only about 5 meters away as the crow flies, so is not that far at all so can't understand why the d-link is struggling, I have tried a number of different configs on the DD-WRT custom firmware that is installed on the d-link but can't get any better performance out of it.
Does any members have recommendations for a wireless router (dual band) that excells at long distance!?
Looking at the asus rt-n16 or the buffalo wzr2-g300. Not sure if the asus is dual band?
I've got one of these but i don't quite understand the question, it comes with the transformer block, to which you slid in the provided UK plug adapter into.
Yeah is it a 2 pin connectIon that plugs into the transformer block like the Sony PS3 console uses?......
images
As where I have my router position I will need a extender cable to reach my plug socket
I would second the Asus RT-N56U or Rt-N66U to go with VM.
I went from a DIR-615 which was barely coping with 50mb, and had a fairly weak signal (it also locked up at random), to the N66U which is far better in terms of speed, and seems to be better for signal strength as well.
One of the things I like about the 66U is that it allows me to have a guest network which a different name and security settings to the main ones, which is handy as my nephews tend to be lost without internet access on their ipods etc :)
You could also reuse the D-link as an access point from memory, as I think it has an option to turn off it's routing features, so if needed you could run a cable (or if you've already got a cable ran to somewhere else in the house use that), and have it boost or extend the range..
^^ This
The dir-615 is an EXCELLENT router and I have 2 myself both routing faultlessly doing 'stuff' ;) but when it comes to serving wifi they are absolutely pants - Rubbish range and can't cope with lots of clients fighting for bandwidth. My wifi is bridged with other routers and the wifi on the d-links are disabled
Buy a standard 3-pin mains extension lead and plug that cable into it.
The figure 8 connector appears to be a C7. If you want a longer one just Google 'C7' with the length of cable you'd like.
So the Asus RT-N56U does use a C7 figure 8 lead to connect into the transformer block?
^^ This
So the Asus RT-N56U should be a good upgrade for wireless range and performance over the DIR-615 then?
I wouldn't have thought so, but that's what you'd pictured.
I believe they use the normal plugin power supplies with a clip on part to match the local socket type.
Whatever they use a bog standard 3-pin mains extension lead will allow you to extend it to where you want.
I have no experience with the Asus but forum members here swear by it. It should really be better as the 615 to be fair is just a basic router from yesteryear. Any dual band router should blow the 615 out of the water
Read up on options here
