Hi there,
Recently bought a TFIII oc ed 880/1250, idle temps 37c, fans at 30%, great! I started BF3, and within a matter of seconds it jumped to 75c and fans at 85%, both slowly increasing and after an hour I just had to stop playing as the fans were driving me and my partner crazy. I peaked at about 87c, 100% fan speed and 100% GPU usage for the whole time playing.
I don't think this is an air flow issue, I have a Corsair 300r, 2 140mm intakes at the front, both hd trays removed, 1 140mm exhaust at the top, 2 120mm on h60 loop push/pull and 2 low rpm side intakes.
I've had loud cards before, but this is just a constant annoying whine.. even with my headset on all I can here is this card, and if I set the fans manually to an acceptable level with afterburner (about 70% is my limit with this card..) the temps just go up and up and up, what can I do? My friend has an identical card, and under load he doesn't go above 52c, 50% fan speed, have I just got a baddun? What are the rules with replacing, exchanging, etc etc? If i'd known I was buying a whining card in the first place, i'd have opted out and gone for the asus cu instead, as I can tolerate a loud noise on load, just not this jet engine type whine..
What do I do?
Regards,
Rob.
What do I do?
Regards,
Rob.
