- 8 Oct 2004
Hi folks,
My parents have a fairly old Vista-based 32bit laptop with 3GB ram (only using 2GB obviously) and a core 2 duo 1.xghz processor (not sure exactly the spec). It's fairly old now and has never been formatted, so it's full of junk and quite clunky - VERY slow to boot - like 5 mins!
My plan, rather than buying them a new laptop, is to buy an upgrade from Vista > Win 8 (64 bit), format and install, install everything else from fresh and buy them a new large monitor to go with it, which they want.
Do you think this would give enough of a speed boost to the laptop for them to notice? I think the very act of formatting it and removing all the nonsense will do most of the work, but I've heard win 8 is a lot more speedy and efficient with RAM use than Vista, notoriously a dog.
I don't know if the CPU is capable of 64-bit but I would guess it is. I can check this later today.
Any ideas/thoughts?
Thinking these:
http://www.overclockers.co.uk/showproduct.php?prodid=SW-150-MS&tool=3
http://www.overclockers.co.uk/showproduct.php?prodid=MO-062-BQ
The laptop has only got VGA out so will that pump out high enough resolution for this screen do you think? No idea what the graphics chip is. I might be able to find out later today.
Cheers!
Any ideas/thoughts?
Thinking these:
Cheers!
