- 3 May 2004
- Kapitalist Republik of Surrey
I've been knocking about with a standard 1200cc engine in my Anglia for some time. It was a bit tired when I put it in and it's pretty knackered now. It's been giving me a few problems so a rebuild is imminent. Which is just as well, because I won a big valve head on eBay, so I'm going to be able to plough loads of time, split knuckles and money into it for next to bugger all horsepower. Have some pics:
You're right, I could build the 1700 beast back up and become king of the streets again, but I've done that before and... I fancy something a bit different. Something a bit more edgy. Something unreliable with an old style cam grind that won't idle properly and will choke out the guy sitting behind me in the traffic. Something that'll be a proper pain in the arse to drive at low revs. Something with big compression that screams its head off and only has three very soft bearings in the bottom end. That sort of thing
Added to confuse things, this is a standard 1500cc engine with the head from my modified 1700 on top so you can see the difference in port size on a stock engine. The new one is a bit smaller, but should help the little 1200 breathe quite nicely through two Webers:
I'll post up some pics when I build it. Here's the car if you don't know it:
