Hi there
We've been selling GoClever tablets for sometime now under the OcUK Ultima tagline on the 8" and 9.7" units, they've proven to be excellent, further backed up by a 2yr warranty and software updates direct from GoClever.
We are launch partner for a very exclusive premium product and here it is:-
GoClever 10.1" IPS 8GB Hybrid Tablet PC with Dock - Android Jellybean 4.1 /w Playstore @ £279.95 inc VAT
GoClever is a premium tablet brand offering both superb quality product along with great warranty of 2yr and software support for updates.
This unique hybrid product is constructed from magnesium allow for great strength whilst remaining light and giving great quality. Performance is excellent from the 1.60GHz dual core processor and Mali 400 quad core graphics. So whether its work or play this tablet can handle it with ease.
This tablet uses quality battery which gives upto 8hrs usage and when docked is upto 15hrs with over a weeks standby power, so no matter how long your journey the GoClever Hybrid will not let you down.
Specification:-
- DISPLAY: 10.1" LCD IPS 1280x800 pixels, Capacitive 5-point multi-touch
- CPU: Dual Core 1,6 GHZ
- GPU: MALI 400 MP4
- Operating System: Android 4.1
- RAM: 1 GB DDR3
- FLASH: 8GB
- NETWORK: Wi-Fi (802.11 b/g/n) „h 3G SUPPORT: external dongle 3G (optional)
- BLUETOOTH 4.0
- CARD READER: microSD HC up to 32GB
- PORTS: 1x microUSB 2.0, 1x 3.5mm audio and mic jack, 1x miniHDMI 1.4 FullHD
- G-SENSOR
- CAMERA: 2x Cameras (2Mpix front and 3Mpix back)
- SPEAKER, MICROPHONE
- DIMMENSIONS: 265x194x28 mm
- WEIGHT: 1370g h BATTERY: 6500mAh Lithium 3.7V HYBRID DOCK:
- 80 keys
- high sensitivity touchpad
- built-in powerbank function
- 2x USB 2.0 hub
- micro USB for charging (TAB + DOCK)
- HYBRID connect
- Battery 8000 mAh
- HYBRID ACCESSORIES: 5V 2A USB charger, USB to microUSB cable, UK plug„ EURO plug
- WORKING TIME (TAB&DOCK): Up to 15 hours of battery life
- Warranty: 2yr
Only £279.95 inc VAT.
ORDER NOW
GoClever 10.1" IPS 16GB Hybrid 3G Tablet PC with Dock - Android Jellybean 4.1 /w Playstore @ £319.99 inc VAT
Specification:-
- 3G Version
- GPU: MALI 400 MP4
- RAM: 1 GB DDR3
- FLASH: 16GB
- BLUETOOTH 4.0
- G-SENSOR
- 80 keys
- 2x USB 2.0 hub
- HYBRID connect
- Battery 8000 mAh
- Warranty: 2yr
Only £319.99 inc VAT.
ORDER NOW
As you can see they ooze quality and with upto 15hr working time are amongst best in their class, they don't dissapoint on performance either with Mali 400MP4 graphics processor which is great for gaming on and the 1280x800 IPS screens give a sharp and clear image.
If your after the same performance as the above, but at a lower cost but still great quality check these models out:-
GoClever 8" IPS 16GB Tablet PC - Android Jellybean 4.1 /w Playstore @ £129.95 inc VAT
OcUK Ultima tablets use a combination of the fastest hardware to ensure gameplay is smooth and response is instant. The other major advantage is they use Super-High resolution IPS screens for incredible image quality along with great viewing angles. They also come housed in very high quality and extremely thin chassis making them stunning to look at as well making you the envy of all your friends.
OcUK Ultima tablets are unbeatable for the money and their performance cannot be matched at this price point and the screens making using them a joy. They also feature aluminium ally back plate which further adds to the quality of these tablets, for the money these are unbeatable!
Specification:-
- Processor: RK3066 ARM Cortex A9 1.60GHz Dual-Core powerful processor
- Graphics: Quad Core Mali 400 3D Hardware Acceleration
- Display Screen: 8" Super Resolution 1024x768 IPS LED Backlit screen
- Operating System: Andoid Jellybean 4.1 /w Playstore
- Language: Multiple language support (English Default)
- Memory: 1GB DDR3
- Storage: 16GB NAND Flash (Upgradable to 32GB /w SD Card)
- Bluetooth: Yes Bluetooth 4.0
- BBC Iplayer / Netflix compatible
- Memory Card: Micro-SD (Support upto 32GB)
- G-Sensor: Yes
- WiFi: IEEE 802.11b/g/n 2.40GHz wireless network
- Touch: 5 points Capacitive screen
- Mini-USB Port
- Mini-HDMI supporting 1080P Video output
- Video Decode:AVI H.264, DIVX, DIVX, XVID, rm, rmvb, MKV?H.264, DIVX, DIVX, XVID), WMV, MOV, MP4?H.264, MPEG, DIVX, XVID), DAT?VCD), VOB?DVD), PMP,MPEG, MPG, FLV?H.263?H.264), ASF, TS, TP, 3GP, MPG etc.
- Music Decode: MP3,WMA,MP2,OGG,AAC,M4A,MA4,FLAC,APE,WAV
- Picture Format: JPG, JPEG, GIF, BMP, PNG
- Camera: Front 0.3M/Rear 2.0M
- Battery: 3800maH / 3.7v
- Battery life: 5-6hrs
- Dimensions: 210mm x 162mm x 10mm
- Weight: 418grams
- Warranty: 2yr
Only £129.95 inc VAT.
ORDER NOW
GoClever 9.7" IPS 16GB Tablet PC - Android Jellybean 4.1 /w Playstore @ £179.99 inc VAT
Specification:-
- Processor: RK3066 Cortex A9 1.60GHz Dual Core
- OS: Android 4.1
- Memory: 1GB DDR3
- Storage: 16GB Storage (Upgradable via SD Slot supporting upto 32GB)
- Display: 9.7" IPS LED 1024x768 4:3 Format
- Capacitive Touch: 5-point multi-touch G+G
- WiFi 802.11 b/g/n
- Bluetooth 4.0
- Support: 3G dongle, mouse, keyboard, pendrive!
- Mini-USB Port
- Camera: Front 2.0M/Rear 2.0M
- Battery: 6800mAh
- Dimensions: 242x186x12mm
- Warranty: 2yr
Only £179.99 inc VAT.
ORDER NOW
As you can see they all have highly rated batteries to give plenty of usage time and the manufacturer warranty of 2yr is a clear sign they are confident in the quality. We've been selling the 8" and 9.7" models for a couple of months now and the return rates are amongst the lowest of the tablets we sell, so the GoClever range is certainly reliable with great quality.
Soon we shall also be offering some quad core CPU GoClever tablets too along with potentially 8 core graphics with ultra high resolution (2058X1536).
Specification:-
- GPU: MALI 400 MP4
- RAM: 1 GB DDR3
- FLASH: 8GB
- BLUETOOTH 4.0
- G-SENSOR
- 80 keys
- 2x USB 2.0 hub
- HYBRID connect
- Battery 8000 mAh
- Warranty: 2yr
ORDER NOW
Specification:-
- 3G Version
- GPU: MALI 400 MP4
- RAM: 1 GB DDR3
- FLASH: 16GB
- BLUETOOTH 4.0
- G-SENSOR
- 80 keys
- 2x USB 2.0 hub
- HYBRID connect
- Battery 8000 mAh
- Warranty: 2yr
ORDER NOW
Specification:-
- Memory: 1GB DDR3
- G-Sensor: Yes
- Mini-USB Port
- Weight: 418grams
- Warranty: 2yr
ORDER NOW
Specification:-
- OS: Android 4.1
- Memory: 1GB DDR3
- WiFi 802.11 b/g/n
- Bluetooth 4.0
- Mini-USB Port
- Battery: 6800mAh
- Warranty: 2yr
ORDER NOW
