7970 vs 570 sli?
9 May 2010
sheffield
right im gettin fed up of running out of vram in skyrim and some other games.
how much of an upgrade is a 7970 over my 570 sli?
i am gaming at 2560 x 1440
help me please
If it's a vram limit then the upgrade should fly in comparison, generally when you max vram your frames tank big time. Can't say if the raw performance will be the same/better but that's a little moot anyway if vram is an issue.
An overclocked 7970 is possibly on par with SLI570s/CF6970s, so in terms of actual grunt you're about the same but the boost through not being VRAM limited would be immense.
help me please
Once overclocked you should find the 7970 faster and smoother. I found the same coming from 6950 xfire. I find on a well clocked 7970 i can run all the games i currently play at maximum settings @1440p and maintain solid and smooth fps. However you will need to disable or knock AA down a tad.
Games ive tested and settings used.
BF3:Highest details+2xAA
Sleeping Dogs:Highest details+SSAA=High
Dirt Showdown:Highest details+MSAAx4
Hitman:Highest Details+AA disabled (not played this game much yet so might be able to use some AA)
Farcry3:Highest details+AA disabled
I currently I'm play on Skyrim with loads of mods I'm frequently goin up to 1280mb on vram stutters and constant slow downs I was looking at the xfx 7970 ghz edition with has 3 gig vram should give me a bit more to play with
Been playing around with Skyrim mods and all was good until I installed the Texture Pack Combiner, some stuttering started.
Low and behold I fired up Afterburner and was shocked to see my Vram usage sitting @3995Mb@1080p which of course is 1997Mb each gpu.
The cards in question are 6950>70 CrossFire running 950MHz/1300MHz, these are plenty fast at anything I have thrown at them@1080p, including Skyrim until the texture pack combiner was installed.
I swapped in a 7970 Wind Force and fired up Skyrim again, no stuttering but the vram is now hitting ~2750Mb.:eek:
As imo, the 7970 I used is slower than my CrossFire setup@1080p, it's definitely not gpu grunt at fault, they ran out of Vram!
At this point I should add that this is all being done in 3D via Tridef.
Mods used along with the Texture Combiner(and required files) are:
In game settings:
Not advocating/advising anyone rips out gpu's to replace a 2Gb gpu at all for 1080p gaming, the aim of the post is to be informative and let anyone know that a modded Skyrim can breach 2Gb vram@1080p.
Texture Combiner available here:
http://skyrim.nexusmods.com/mods/20801/#content
MSI are good but lots of problems with over heating cards. Personaly, I would go for the Gigabyte WFX3. Not sure if you are fussed about the volts being locked but if you are, someone can advise better on that.
