I've come across this discussion a lot, get laser 4 wheel alignment than just tracking because tracking just checks for toe
I have a mk4 golf, so I don't have the camber/castor adjustments on it, does that mean the car shoudln't have any camber/castor or will it still be prone to that from damage/wear&tear on the other parts of the axle system.
A 4 wheel alignment varies from just £60 to £100+ so is pricey, due to the limitations I'm not sure if it's worth paying that much when they can only do a toe check and adjustment which a £20 tracking adjust will be able to take care of.
