Don't you run the risk of them getting a bit shirty with you when you go defensive? Or were you going quickly enough that honesty would've been perilously expensive?
On a similar topic, I use my GPS to determine my speed as it seems to be more accurate when you're being fairly constant (i.e. motorways, refresh rate is too low to be reliable when accelerating) and I'm finding that I can be doing nearly 80mph according to my car speedo but just touching 70mph according to my GPS.
I know car speedo accuracy is dependent upon a number of factors - but should I be a bit careful with the way I'm gauging my speeds? I can be doing ~90mph according to my speedo, but an actual of 80mph by the GPS and I then think what if I get pulled over and the police car speedo is out of whack too?
Any ideas before I belt it up the M40/M42 tomorrow would be much appreciated
