- 19 Oct 2002
- Shakespeare’s County
PMKeates is comedy.
http://www.autotrader.co.uk/classified/advert/201302205424443/Surely getting a good e46 or e39 at this budget is more luck rather than judgement and would require hunting far and wide? The majority will be terrible. The e46 estate quoted above illustrates this nicely, while the seller sounds honest and genuine the car is pretty ropey.
Remind me, during which years was the ZT the segment leader?All these BMW suggestions are ridiculous.
Low spec knackered old beemers that will cost a fortune to fix.
Ive already mentioned, the ZT CDti, it wins in every category apart from the "badge".
Saloon.. grantedThis is screaming MG ZT Cdti
Saloon... check
Comfortable.. check
Reasonable Cruiser?...check
BMW diesel engine.. check
50mpg+... check.
cheap to fix... check
Reliable... check
Looks reasonable...check
Not sure anything could be better for the cash ?
Remind me, during which years was the ZT the segment leader?Saloon.. granted
Comfortable.. not really. Crashy suspension, fairly basic seats, not well insulated. A bog standard Mondeo is more comfortable.
Reasonable cruiser.. I guess reasonable is the word.
BMW diesel engine.. well, it's a decent enough engine, but not spectacular and a bit underpowered. Other cars were fitted with better engines shortly after the M47R was available in the ZT.
50mpg+.. 48 MPG combined according to the official figures.
Cheap to fix.. maybe, but BMWs, broadly speaking, are not expensive to fix. New OEM parts are actually quite cheap, lots of aftermarket options, and used parts are in abundance. They are simple and designed for easy repair jobs, anybody can work on them.
Reliable... no idea, I'd hope so being as they have nothing on them.
Looks reasonable... looks OK, though I could move in to the panel gaps.
Money is clearly an issue here. Why on earth would you even consider a 2-3k car if you had the cash lying around to buy something nicer and newer?
I think saying it meets the 'comfort' criteria is marginal. I don't think it's particularly comfortable.So in conclusion, fits almost all the criteria, even when you're trying not to like it?![]()
in to a
- lots of cars meet the criteria, important are the best of those. I don't think the ZT is amongst the best of those.Eh? I want to sell my ATR and buy a car to drive to work and back with, I don't want to spend more than what I get on the ATR because I don't see the point? I'd rather put it away in a savings account. If money was an issue I certainly wouldn't own an Evo 9 and look to buy a second car.![]()
I still keep coming back to the Golf TDI PD130.
Firstly, old does not equal cheap and nasty. They are just old. All cars for £2-3k will be old. The better cars will be older, but then they are better cars. They will ride better, drive better, have better performance and have better equipment levels than newer cars from lower segments. A well maintained 13 year old 5 Series (which do exist) will drive better than a brand new Golf, let alone a 9 year old one.What I don't understand is the fascination with cheap nasty BMWs when what you want seems to be simple and reliable.
I sold the E39 2 years ago for less than £3k - show me the Golf, Focus, Passat, whatever, that is 'more decent' than it. Finding a nice one isn't easy, and they aren't the best cars in the world, but it will forever be a better and more decent car than the likes the basic hatchbacks churned out by mainstream manufacturers.Cheap, yes. Decent, doubtful!
