Mark 1 Focus is a solid buy. 1.6 Zetec should be doable.
10min drive = buy a bicycle![]()
Yes, I'm thinking of cycling to work and being without a car for a while at least. But I'll need one eventually, to visit people, interviews, etc.
You can have something fun if it isn't a daily, MX5 perhaps?
I can see where you're coming from, but hmm, I'm not sure.
I do not plan to be in my current job for more than a year. So will probably have to travel further in the not too distant future. I imagine a car like an MX5 is not that cheap to run if I had to use it daily?
I want a car that will last me a long(ish) time, and being cheap to run is one of the most important factors.
I think it's not best to rush into buying something. From advice from others I'm aiming for a car no more than 8 years old and under 100k mileage, sound good for a second hand? Might have to increase the budget to £1-1.5k
At this price, buy the car on condition, not mileage and age. Yes they can be a consideration, but don't make them a deal breaker. There are cars out there that are getting on a bit and have high miles on, but are well maintained. Conversely, there are cars with lower mileage that have been hammered around town for years, so aren't in as good a condition.
An MX5 won't cost a fortune to run, however they're not fantastic on fuel, I average just under 30mpg out of mine - if I had a long commute I'd consider something more practical and better on fuel.
A mk1 Focus would be ideal for this job.
Celica GT - Pretty much a bullet proof engine in this
http://www.autotrader.co.uk/classif...e/postcode/pe140ay/page/1/radius/10?logcode=p
Good shout, I've been advised by a friend to get a Toyota![]()
What's wrong with the KA? Focus / Fiesta / Yaris, all ~40mpg+
Celica GT and MX5 will seem heavy on fuel compared to your KA
