Spec me a mechanical keyboard!
22 Nov 2004
London
Hello,
I know there are a lot of threads out there about mechanical keyboards, but I'm looking or something quite specific, and can't seem to find what I'm looking for. Perhaps you've been looking for something similar:
  • Cherry Blue or Brown (Blacks at a push)
  • Steel backed construction (I bottom out a lot when I type)
  • Backlit keys
  • Laser etched keys at least but preferably dye sublimation keys or injection moulded.
  • Simple design (not looking for a gaudy gaming one, but will consider if the above criteria are met)
  • Full sized keyboard with number pad
Thanks!
What's your budget? The Qpad Mk-85 seems to fit your criteria, but is quite pricy. OcUK seem to be out of stock on both brown and blue switches at the moment though.
I don't like the audio passthrough on the Qpad, last place (IMHO) I want my headset is connect to my keyboard.
I'm leaning more towards Razer Blackwidow.
