680 from ebay artifacting on OC Scanner
21 Sep 2010
Hi all,
Just received a PNY GTX680 from ebay. I decided to test it on EVGA OC Scanner at stock clocks, and it's producing a lot of artifacts. It's not actually crashing, just artifacting. Is this a screwed card or is there something I could be doing wrong here?
Thanks
See if the same happens after you lower the default clock speeds try lowering it 10-20 mhz, could be that the card cant do the default clock speed on said voltage.
Watch the temps too if really high could try reseating the cooler with fresh paste.Also try a few other GPU testers I like heaven benchmark for that.
if the card is dud I wouldn't worry about it, you have PP and ebay on your side and will always side with you.
I wouldn't trust OC scanner. My 7870 would show artifacts without any overclock yet I could overclock it and it wouldn't artifact or crash in games. Now with my 680 overclocked I overclocked it to 1300/1800 and it ran OC scanner fine without any artifacts but in games it would crash near enough instantly. Needed to back off to 1250/1750 before it worked.
Since I upgraded to 12.11 drivers on my 7970 my card artefacts like hell, well it's like visual glitches. But this is only when running BOINC and never get it during games.
