SLI Titans Overclocked and tested at 5760 x 1080 and in 3D
Yep - they all run at 1150 - 1176 totally locked and at 38C
I put some ram sinks on my main card that I had laying around and it will do +350 on memory as well, my other 2 only around 250 so I need to get some backplates or ram sinks for the others
Nice My new build pictures are incoming soon, new case, water cooled TITAN
and new compression fittings!
Just thought I would do some rebenching and testing newer games with the 320.18 drivers. The games like DMC and Dishonoured I didn't bother retesting purely because of the massive frames per second. Also, I tested Batman AC at DX11 with 8XCSAA and everything else fully maxed. The low fps was were it changed scenes. Batman does run very nice in AC. Also, you will notice I have dropped my OC by 10Mhz, purely because it wasn't stable 100% in all games at +140 but +130 seems to play very nice and I added 50Mhz to the memory to compensate :)
Crysis 3 is a killer and far from playable at those rubbish fps IMO and would need another Titan to get there (no chance for me). Grid 2 plays very nice, as does Tomb Raider after the hair being all blurry (TressFX) in the early days. Far Cry 3 is an embarrassment with running like dog poo in SLI and very poor scaling to boot.
On two Titans I'd say so, although there's not much call for it at that resolution in fairness
5760*1080 is high resolution but it is the same PPI as 1920*1080 so therefore the "need" for it is the same. At 2560*1440 @ 27"... this is a different type of high resolution... the PPI is far higher reducing he need for it.
