EK waterblocks, gpu block cleaning help!
22 May 2010
Minibotpc
Right, so i haven't cleaned my gpu block since i got it a good 8 or 9 months ago when i got my gtx 680. I would really like to clean it and see what craps been collecting inside the block. However i see a warranty sticker on it where the block top seperates from the base.
How am i supposed to clean it and see whats going on inside without voiding warranty? Flush it with distilled water? I cant imagine flushing would do a proper job, thats what im concerned about where as if i open it up i know i can clean it thoroughly and properly.
What would you do?
The sticker is just to prove that the block doesn't leak and can stand a certain amount of pressure not warranty.
This, EK fully support block top removal for cleaning, they'll even request you do so before requesting RMA for Nickel issues to rule out staining :)
Thank you guys, i appreciate all the replies!
I had a look at my block and you're right the sticker is for testing purposes only not warranty. Gonna give it a good clean this week i think and see whats built up over time :D
