I can't remember what the last 32 bit processors were? Pentium 4?
atom. not an issue for gamers but plenty of netbooks about.
Consoles impact PC development, like it or not.
PS4 is x86.
Worth bearing in mind.
PS4 will be using a x86-64 processor. If it was simply x86 then there would be no point in giving the system 8GB of memory.
The memory is unified if that makes a difference?
The AMD Jaguar is x64.
Yes, I read that after looking it up a little more.
It is a situation which means the PS4 could be easier for developers to program than the next Xbox which is an odd situation indeed.
Software is still so far behind hardware. Crysis (2007) QUOTE]
wasnt far cry there first on that ?
Why? The next Xbox is using pretty much the same CPU as the PS4, though the GPU's appear to be different.
I was not aware specifications were known for next Xbox.
	4GB really is all you need though. I ran a few games and these are the results I got:
So as you can see, at no point does my memory usage exceed 4GB, even if you take an unrealistic value of 2GB memory needed for OS.
+1 but the above post is also true. Not many games use more than 4GB, if anything close... some games use more than 2GB VRAM though but pls don't debate that here haha
Perhaps if you're a lightweight user who closes everything and likes loading times, in ''idle'' mode my pc uses 4.7 gb ram, and nearly 5.9gb is used by superfetch. Only 1.6 gb out of 12 is truly ''wasted'' and not used when I'm idling.
Any user who does not want to waste time waiting on things because of closing/opening apps while gaming, needs at least a decent quadcore, 8gb ram, and an SSD...
16GB or go home tbh
Well does anyone on here not have a 64-bit OS? I'd take a shot at no.![]()
No he is right windows can only see 3.5GB of system memory (GPU+RAM).
so as GPU Ram increses you can't address an increaseing amount of RAM
I doubt it would just address VRam thou.
If you're using an SSD you shouldn't have superfetch enabled.
