Description
The Bullet HD Pro 2 is a revolution in sports camera design, and the only 20 mega pixel camera available on the market in this sports format - now including Video Motion Stabilization technology. The core of the Bullet technology is based on DigitalClarity CMOS sensor which has major advantages over traditional CCD based technology used in many current sports cameras, with low noise levels, smaller size and high performance image capture.
Built form military grade aluminum, shock proof and fully waterproof (certified IP68) up to 10m, this is the natural choice for all extreme sports activities. Having tested over 8 of the current market offerings in house the Bullet HD range was the only product that stayed completely "fog free", in all environment's due to its sealed design and not requiring a separate external case for waterproofing.
With its exceptionally small profile and lightweight design it can be worn helmet style and you hardly notice you are wearing it, or mounted on your bike, windsurfer, etc. without fear of it being caught and broken off should things not work out according to plan. When recording in video mode the .mov files are saved in 5 min segments, enabling you to quickly load and pick the best bits without having to copy and manipulate a massive file on your computer.
Supplied as standard with an impressive range of mounting options and accessories, you can also add advanced mounts and wireless remote in the future from our accessories range see separate listings.
If you can do it, you can capture the action in stunning HD quality with BulletHD cameras.
