Trust sent with a bit more detail, i'll put this here though for those interested:
If you were to be successful joining the company that I work for in Audit then you would take one of two streams. The first is on the AAT stream. My understanding is that this takes 2 years and then you move onto the ACCA or ICAEW stream. Secondly, as you have a 2.1 degree, I think you might be able to start straight on the ACCA or ICAEW stream. It might depend on which country you obtained your degree in however. I thought that AAT was for people with no degree or a 2.2 or less degree.
I'm not sure what you expect from a salary, but there is a massive difference between those on the AAT stream and those on the ICAEW stream. To give you an idea, new starters on the AAT are earning around £14k pa, the ICAEW stream pays about £19-20k however.
