AMD Sea Islands Rumours.
You will :D and don't forget the condition. ;)
Come on, spill the beans ;)
What condition?
Just think of all the fiddling you could do with a waterloop.
I'm under the impression that its a bit of a pain in the back side and once you have it set its best not to touch it unless absolutely necessary. That doesn't sound like my idea of fun. I've only just become a jedi knight in the art of accelero gpu fitting. When you consider how people have killed their gpu's fitting this thing, that is some achievement. :D
not the case at all mate.
Watercooling is soo easy
by next year i'll be either getting 8950 or a gtx770 or a ps4 depending on which is best value for money.with the 8950 looking to have a slightly better spec than the 7970 it is looking likely that i won't be getting a ps4.
Got a 6970 at the moment, should I upgrade to the 7950/70 or wait for the 8XXX series? Will it be a huge leap?
I'm a little out of the loop at the moment with graphics cards. Also I notice that a lot of the 7 Series don't seem to offer 2 DVI connections on the same card. This is a pain due to my eyefinity set up and my monitors using this and one dp to dvi adapter.
15-30% or so ballpark.
seldom needed to wait.
You can see for yourself:
http://www.anandtech.com/bench/Product/509?vs=508
Seems probably around a 40% leap on average if you went with a Radeon 7970.
Not sure how much of a leap 8 series will be
