Xeon E3 -> Overclock via Turbo Boost?
10 Apr 2004
I'm aware that these chips are multiplier locked, but do these chips allow for the +4 bins that the Core i5/i7 counterparts allow?
I can't find any proof so if anyone has any proof that these chips allow for the +4 bin then that would be great!!!
Thanks!!
You can't be running at 4ghz on all cores unless you also up the BCLK.... Do you understand how the turbo works ?
O.o
Yes, the E3-1245V2 has a non turbo multi of 34 and turbo multis of +2/+3/+4/+4, by raising the all cores turbo 4 bins over its stock setting of +2 you get +6, added to 34 thats 40, and 4GHz.
O.o
Very Cool.... but you miss the fact that only 1 core will ever hit the max turbo multiplier(that's what I was getting at :) as explained here / thread
If you put all the cores under load on your setup the the frequency across all cores will be 3.7ghz (this should be your specified overclock not 4ghz :p)
Anyway that's very impressive as I couldn't get my E3 to budge on a Z68 - you must be the first to prove it.... Any chance you could post screenies with the system under full load when you get a chance ? Cheers
Here's my +4 on my i7-2600
[1] At idle a single core can burst to 4.2ghz (this is a random event)
[2] At full load all the cores register 3.9ghz (solid no fluctuations)
Ill try and explain what I did further, heres a quote from the thread you linked:
Core i7-2600
35X - 4 cores active
36X - 3 cores active
37X - 2 cores active
38X - 1 core active
If the bios allows, you can get a +4 overclock on top of the base results above.
39X - 4 cores active
40X - 3 cores active
41X - 2 cores active
42X - 1 core active
What I did was basically:
Xeon E3_1245V2
36X - 4 cores active
37X - 3 cores active
38X - 2 cores active
38X - 1 core active
To:
40X - 4 cores active
40X - 2 cores active
40X - 1 core active
Giving a 4GHz turbo all the time.
Im pretty sure I remember the guy I sold it to doing the same thing, he mentioned it in a thread on here somewhere. I can show you a screenshot of my current i7 3820 running with a 40x multi on all four turbo clocks but I doubt that's any use.
Very cool - I'll take your word for it ;).... Now I have to wonder why I couldn't get my E3 working grrrrrrr
I also wonder if it'll work on the higher Xeons like an E3-1275v2
// Thread makes me want to buy back my E3 :rolleyes:
ps The misunderstanding was due to me thinking that you were running all the cores at 4ghz lol :p
