I have not once changed my postion or attempted to add caveats after the fact.
I read your posts as being slightly contradictory but we can agree to disagree.
IUntil now, you never once mentioned that the WF 7950 was voltage unlocked in this thread.
Post #3. D'oh. It's kind of obvious from that, that I've said that they're unlocked.
Erm, that was my entire argument you can't start bring "if" and "buts" into it. Having a 7950 with a 7970 PCB is no guarantee of quality. We are agreeing on this point and yet you still argue. Regardless of this my entire argument is based on the fact that the WF 7950 is not guranteed to have voltage control.
Well you CAN bring "if's" into it. Having a card on the 7970 PCB DOES make it a better card overall, however, it doesn't do anything to help IF you get a bad chip. Although IF you get a good chip it WILL certainly help. Your argument was based on the negative side of this equation rather than positive side. I am dealing with both. Slightly short sighted really.
"Erm", also I never said that it is a guarantee of quality. It was a theoretical, "if all things were equal" argument then having a card on the ones above it PCB will be better. Hence the 7870/7950 example.
Again that was my point. The perception that higher asic, or PCB = better is not always true. Again you seem to be arguing with me yet agreeing at the same time.
Hence the "if all things were equal" argument above.
As NightSt@lk3r confirmed, they "can" be voltage lcoekd. My argument for better is based on the fact that currently, the MSI TF3 7950s are guranteed to have voltage control.
BE, yes. Non BE, no. Retailers should be advertising it if they're selling BE cards. I'd be bit angry if I bought a non BE card and then received a BE one. This is based on assuming they are indeed BE cards.....
. If they're not then I agree that they should be avoided. Although, it's still not the end of the world if they are voltage locked to 1.25V, it is a negative point due to the heat/noise issue mentioned previously. At least they aren't locked to stock volts.
Not labelled as a Boost Edition no.
The first Rev1 WF3's came at 900mhz core and unlocked voltage, GB later changed the BIOS to 1000mhz core and voltage soft locked at 1.25v and could be got round by flashing the older 900mhz BIOS on, but within the last week or 2 they seem to have released a Rev2 card that has a 7970 PCB and the voltage is hard locked.
But that said id still take a Rev2 7950 WF3 over the TF3.
Ah OK thanks for clarifying. So by getting a 6+6 pin GB WF 3x you're getting one that can be adjusted. The 8+6 pin ones can't be. Understood
.I've gone off MSI due to the problems they had with the heat on the V2 7950s so I would get a hard locked 7970 PCB version as well over the MSI ones. Although I understand the BE MSI TFIII has resolved this issue it did irritate me at the time.
