- 11 Dec 2005
- Cheshire
AMD FirePro 2270 Professional Graphics Card - 512MB - GDDR3 SDRAM @ £94.99 inc VAT
Employees in many industries need two computer monitors to successfully display and interact with information they need to get the job done. To meet these needs, IT needs a flexible professional graphics solution that's compatible with the variety of displays and computing systems they happen to have on hand.
AMD FirePro™ 2270 professional graphics are capable of driving two 30" high resolution DisplayPort, DVI or VGA displays. Featuring a low profile, energy efficient design, the AMD FirePro 2270 can be deployed in a wide range of systems, from notebook docking stations to small form factor desktops to large tower workstations.
512MB of Graphics Memory
Enables efficient multi-tasking across multiple applications or graphics intensive applications, helping to prevent system bog downs
Dual-view Display
Expands field of view across two 30" high resolution displays, allowing users to interact with multiple applications simultaneously, see images in more detail and improve workflow productivity. Ability to stretch one image or application across both screens to create one large view
Low Power Consumption
Consumes 15W maximum power, suitable for deployment in smaller energy efficient systems
Flexible Output Configurations
Supports two 30" high resolution DisplayPort, DVI or VGA displays, allowing IT to configure set ups with existing display inventory
Passive Cooling
Optimal cooling solution helps increase MTBF, enabling higher reliability and stability
Low Profile Design
Allows installation in the smallest form factors, notebook docking stations or full height systems
Unified Driver Architecture
Delivers the stability and reliability demanded by professional users, as well as the convenience and ease of maintenance vital for IT
Was £99.98 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
AMD FirePro V3900 Professional Graphics Card - 1GB - DDR3 SDRAM @ £93.95 inc VAT
AMD FirePro™ V3900 professional graphics enables an exceptional user experience by delivering features and reliability designed to help boost the productivity of professionals working with low to moderate-complexity designs.
The AMD FirePro™ V3900 professional graphics card is powered by a new generation GPU, backed by 1GB of fast DDR3 memory, 480 stream processors and support for up to 5 (five) display devices using AMD Eyefinity multi-monitor technology and DisplayPort™ 1.2 multi-streaming technology.
Features:-
- Officially certified for superior reliability when working in many CAD and M&E applications
- Outstanding performance for projects ranging from low to moderate complexity
- Supports up to 5 simultaneous displays with AMD Eyefinity and DisplayPort™ 1.2 multi-streaming technologies1
- 1GB of high speed DDR3 memory (twice the capacity of other entry-level cards2)
- Massively parallel processing architecture featuring 480 next-gen AMD stream processors
- Support for both dual-link DVI and DisplayPort™ connectivity
- AMD AutoDetect technology automatically optimizes GPU driver settings as applications are launched
- Full OpenCL™, OpenGL and DirectX® 11 support (Please see www.amd.com/api for specific version support)
- PCI Express® 2.1 compliant
Specifications:-
- AMD FirePro V3900 Professional Graphics Card
- Core Clock Speed: 650MHz
- Stream Processors: 480
- Maximum GPU Power: 50W
- Frame Buffer / Memory: 1GB GDDR5 128 Bit
- Power Connectors: zero power connections
- Display Outputs: DL-DVI-I, DisplayPort x 1
- Warranty: 3 Years
Was £98.99 Inc. VAT
Only £93.95 inc VAT.
ORDER NOW
AMD FirePro V4900 Professional Graphics Card - 1GB - GDDR5 SDRAM @ £131.99 inc VAT
AMD FirePro™ V4900 professional graphics offer strong performance and outstanding reliability while delivering features that help boost the productivity of professionals working with medium to large models, all in a single slot, half-length solution.
The AMD FirePro™ V4900 professional graphics card is powered by a new generation GPU, backed by 1GB of blazing-fast GDDR5 memory, 480 stream processors, and support for three simultaneous monitor outputs on a single card with AMD Eyefinity technology.
Features:-
- AMD Eyefinity Technology, With the revolutionary multi-display technology, the AMD FirePro V4900 professional graphics card supports three independent displays, delivering the most immersive graphics/computing experience with innovative display capabilities supporting massive desktop workspaces.
- DisplayPort 1.2, Support for the newest DisplayPort standard adds exciting new features such as high bit-rate audio, higher data bandwidth, and multi-streaming capabilities.
- AutoDetect Technology, As a user moves between applications, or opens new ones, the graphics driver settings are automatically configured for optimized performance.
- Full 30-bit Display Pipeline, Enables more color values than 24-bit products for more accurate color reproduction and superior visual fidelity.2
- Full Shader Model 5.0 Support, Helps create highly complex geometry and scenes without taxing the CPU.
- Certification, Ensure compatibility, reliability and the highest level of performance when used with professional 3D software packages.
- DirectX® 11 and OpenGL Advanced Features, Enables optimal performance in leading applications. Please visit www.amd.com/api to see specific OpenGL version support.
- OpenCL™, Industry standard API – Open, multiplatform development platform to help enable broad adoption of heterogeneous computing. Please visit www.amd.com/api to see specific OpenCL™ version support.3
Specifications:-
- AMD FirePro V4900 Professional Graphics Card
- Core Clock Speed: 800MHz
- Maximum GPU Power: 75W
- Frame Buffer / Memory: 1GB GDDR5 256 Bit
- Display Outputs: DL-DVI-I, DisplayPort x 2
- Warranty: 3 Years
Was £139.99 Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
AMD FirePro W5000 Professional Graphics Card - 2GB - GDDR5 SDRAM @ £371.99 inc VAT
AMD FirePro W5000™ is the most powerful midrange workstation graphics card ever created, delivering significantly better performance than the competing card against a wide set of measurements.1 For example, it has the ability to process up to 1.65 billion triangles per second, allowing a designer to easily interact and render 3D models, while the competing solution is only able to process up to 0.41 billion triangles per second (up to 4 times less).2 In addition, with double the graphics memory (2GB vs 1GB of the competitor) and a memory bandwidth that is up to 2.5 times faster than the competitor, moderately complex models will be no match for the AMD FirePro™ W5000.3 It’s the ideal solution for professionals working with a broad range of applications, moderately complex models and datasets and advanced visual effects.
Features:-
- Drive up to four displays with AMD Eyefinity technology,4 enabling users to multitask across multiple applications with ease
- Offers unmatched application responsiveness, features double the memory and up to 2.5 times more memory bandwidth than the competing midrange solution3
- Support for DisplayPort 1.2, enabling resolutions well beyond standard HD and compatibility with multistream transport hubs that allow AMD FirePro™ W5000 to power up to six displays4
- Optimizations and certifications for many major CAD/CAE and media and entertainment applications
- Intelligent power saving and monitoring technologies for higher performance
- AMD Eyefinity Technology, Industry-leading multidisplay technology enabling highly immersive and unrivaled multitasking experience across up to four displays, powered by a single AMD FirePro™ W5000 graphics card.4
- GeometryBoost, Allows the GPU to process geometry data at a rate of twice per clock cycle resulting is a doubling in the rate of primitive and vertex processing. Triangle rates increase two-fold relative to a GPU that does not possess GeometryBoost.
- DisplayPort 1.2, Simultaneously output multiple, independent audio streams and display content at resolutions beyond standard HD (maximum resolution of 4096x2160).
- Energy Efficient Design, AMD PowerTune technology dynamically optimizes GPU power usage and AMD ZeroCore Power technology significantly reduces power consumption at idle.5
- AMD ZeroCore Power, AMD ZeroCore Power technology leverages AMD's leadership in notebook power efficiency to grant our desktop GPUs the ability to power down when your monitor is off, also known as the "long idle state."
- AMD PowerTune, AMD PowerTune is an intelligent system that performs real-time analysis of applications that utilize a GPU. In the event that an application is not making the most of the power available to the GPU, AMD PowerTune can improve that application's performance by raising the GPU's clock speed by up to 30 percent - automatically.
- Video Codec Engine (VCE), A multistream hardware H.264 HD encoder, for power efficient and quick video encoding.
Specifications:-
- AMD FirePro W5000 Professional Graphics Card
- Core Clock Speed: 825MHz
- Stream Processors: 768
- Frame Buffer / Memory: 2GB GDDR5 256 Bit
- Warranty: 3 Years
Was £389.99 Inc. VAT
Only £371.99 inc VAT.
ORDER NOW
PNY Nvidia Quadro NVS 300 Dual VGA Low Profile Graphics Card - 512MB - GDDR3 SDRAM @ £102.95 inc VAT
The NVIDIA® NVS™ 300 by PNY, multi-display business graphics solution, designed for small and standard form factor systems, delivers reliable hardware and software for a stable business environment. Tested on leading business applications, NVS 300 by PNY is capable of driving two VGA, single link DVI or DisplayPort displays. With NVIDIA Mosaic™ and NVIDIA nView® technologies built in, you can span and efficiently manage your entire Windows desktop across multiple displays.
- Bus Interface : PCI Express Gen 2 x16
- Max Displays/Board DP : 2 ultra-high resolution displays at 2560 x 1600
- Max Displays/Board DVI : 2 ultra-high resolution displays at 1920 x 1200
- MAX Displays/Board VGA : 2 ultra-high resolution displays at 2048 x 1536
- Power : 17.5W - Passive cooling
- Form Factor : Small Form Factor
- Mosaic Mode Enabled : Yes (Windows 7 only)
- nView Enabled : Yes
Was £107.99 Inc. VAT
Only £102.95 inc VAT.
ORDER NOW
PNY Nvidia Quadro NVS 300 Dual DVI Low Profile Graphics Card - 512MB - GDDR3 SDRAM @ £103.99 inc VAT
Only £103.99 inc VAT.
ORDER NOW
PNY Nvidia Quadro 410 Graphics Card - 512MB - GDDR3 SDRAM @ £119.99 inc VAT
NVIDIA® Quadro® 410 GPUs combine outstanding workflow productivity for entry CAD/PLM users, comprehensive professional application certifications, and the peace of mind professionals have come to expect from NVIDIA Quadro products – all at an exceptional value.
- Shader Model 5.0.
- OpenGL 4.2.
- Microsoft® DirectX 11.
- NVIDIA CUDA Parallel Processing Architecture.
- NVIDIA® nView® multi-display technology.
- NVIDIA® Mosaic technology.
- 512MB Vram
- 64 Bit GDDR3
- 38W
- 1x DisplayPort
- 1x Dual Link DVI-I
- Max resolution: 3840x2160
- 192 CUDA Cores
Was £124.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
PNY Nvidia Quadro 600 Graphics Card - 1GB - GDDR3 SDRAM @ £149.99 inc VAT
NVIDIA® Quadro® 600 by PNY Technologies - Low-profile, power-efficient, professional graphics solution
Built for Professionals™, and certified on leading CAD and DCC applications, NVIDIA Quadro 600 by PNY delivers the best performance per watt in its class, maximizing productivity while conserving energy.
Designed for both small form factor and full height workstations, the NVIDIA Quadro 600 by PNY delivers advanced capabilities, allowing you to design, iterate and deliver higher quality results in less time.
- Frame Buffer Memory: 1GB DDR3
- Memory Interface: 128-bit
- Memory Bandwidth: 25.6 GB/s
- CUDA Parallel Processing Cores: 96
- Display Connectors: DVI-I (1), DP (1)
- Max Power Consumption: 40 W
- Graphics Bus: PCI Express 2.0 x16
- Form Factor: Low Profile - 2.731” H x 6.6” L Single Slot
- Thermal Solution: Active
- 3D Vision Pro: Support via USB
Was £158.99 Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
PNY Nvidia Quadro 2000 Graphics Card - 1GB - GDDR5 SDRAM @ £399.95 inc VAT
Delivering the industry’s best-in-class performance across leading CAD and DCC applications, the NVIDIA Quadro 2000 by PNY mid-range professional graphics solution features Scalable Geometry Engine™ technology and 1GB of memory for fast processing of complex models and scenes.
With Quadro solutions your work flows – design, iterate and deliver higher quality results in less time.
- Frame Buffer Memory: 1GB GDDR5
- Memory Interface 128-bit
- Memory Bandwidth 41.6 GB/s
- CUDA™ parallel processing cores: 192
- Display Connectors: DVI-I (1), DP (2)
- Max Power Consumption: 62 W
- Form Factor: 4.376” H x 7” L Single Slot
Was £419.99 Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
PNY Nvidia Quadro 2000D Graphics Card - 1GB - GDDR5 SDRAM @ £389.99 inc VAT
Delivering the industry's best-in-class performance across leading professional ISV applications, the NVIDIA Quadro 2000D by PNY features two dual-link DVI connectors to drive two ultra-high-resolution panels and add flexibility for multi-monitor configurations. Professional applications can take advantage of the Quadro 2000D advanced feature set, including Scalable Geometry Engine™ technology, 192 NVIDIA CUDA™ parallel processing cores and 1GB of memory for fast processing of complex models and scenes.
The NVIDIA Quadro 2000D by PNY also delivers the industry's most advanced diagnostic imaging graphics solution. Offering two dual-link DVI connectors for display flexibility, support for 10/12-bit grayscale monitors up to 10Mpixels, and DICOM monitor calibration capabilities – the Quadro 2000D enables more confident medical analysis.
Based on NVIDIA's award-winning Fermi Architecture, the Quadro 2000D delivers advanced capabilities including Mosaic Technology which enables any application to scale across up to eight displays using multiple Quadro graphics boards.
- Memory Size: 1 GB GDDR5
- Memory Bandwidth: 41.6 GB/s
- CUDA Parallel Processing Cores: 192
- Display Connectors: DVI-DL + DVI-DL
- Maximum Power Consumption: 62 W
- Physical Dimensions: 4.376" H x 7.0" L Single Slot
- Warranty: 3 Years
Was £399.98 Inc. VAT
Only £389.99 inc VAT.
ORDER NOW
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) HDD @ £43.99 inc VAT
Combining proven components, state-of-the-art technology and industry-leading manufacturing expertise, the Seagate Barracuda 7200.12 drive - the 12th generation of this award-winning desktop hard drive family - delivers 500GB of high-performing, eco-friendly digital storage.
- Capacity: 500GB
- Cache: 16MB
- Interface: SATA 6GB/s
- Spin Speed: 7200RPM
- Seek Time: 8.5ms
- Warranty: 1 Years
Was £49.99 Inc. VAT
Only £43.99 inc VAT.
ORDER NOW
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD @ £59.99 inc VAT
The new Barracuda ST1000DM003 hard drive from Seagate offers customers a compelling new storage choice for high-capacity, high-performance computing solutions. The new Barracuda ST1000DM003 drive is built on a full-speed, 7200RPM platform. Further turbocharged with a huge 64MB cache and the industry’s new, high-performance SATA 6Gb/s interface, the Barracuda ST1000DM003 drive is destined to set a new standard for high-speed desktop performance. Discerning high-performance PC users, multimedia development professionals and power users in general will appreciate the capacity, performance and flexibility the Barracuda ST1000DM003 drive offers.
- Backwards compatible with SATA-II
- Capacity: 1TB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Warranty: 1 Years
Was £69.98 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST3000DM001) HDD @ £104.99 inc VAT
The new Barracuda ST3000DM001 hard drive from Seagate offers customers a compelling new storage choice for high-capacity, high-performance computing solutions. The new Barracuda ST3000DM001 drive is built on a full-speed, 7200RPM, 6 Head, 3 Disk platform. Further turbocharged with a huge 64MB cache and the industry’s new, high-performance SATA 6Gb/s interface, the Barracuda ST3000DM001 drive is destined to set a new standard for high-speed desktop performance. Discerning high-performance PC users, multimedia development professionals and power users in general will appreciate the capacity, performance and flexibility the Barracuda ST3000DM001 drive offers.
- Capacity: 3TB
- Cache: 64MB
- Warranty: 1 Years
Was £113.99 Inc. VAT
Only £104.99 inc VAT.
ORDER NOW
Western Digital Caviar Red 3TB SATA 6Gb/s 64MB Cache WD30EFRX - OEM HDD @ £129.95 inc VAT
WD Red is the only hard drive designed for NAS systems that have 1-5 drive bays. The drives are designed and extensively tested for compatibility in the unique 24x7 operating environment and demanding system requirements of home and small office NAS.
- Capacity: 3TB
- Cache: 64MB
- Spin Speed: 5900RPM
- Warranty: 3 Years
Was £149.99 Inc. VAT
Only £129.95 inc VAT.
ORDER NOW
Western Digital Caviar Red 2TB SATA 6Gb/s 64MB Cache WD20EFRX - OEM HDD @ £89.99 inc VAT
- Capacity: 2TB
- Cache: 64MB
- Warranty: 3 Years
Was £109.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Samsung SH-118AB/BEBE SATA 18x DVD-ROM (Black) - OEM @ £11.99 inc VAT
Samsung's 18x Serial SATA DVD-ROM gives a great optical drive for excellent value.
- DVD-ROM: 18x
- CD-ROM: 48x
- Access time 120ms
- Buffer Size : 1.5MB
Was £14.99 Inc. VAT
Only £11.99 inc VAT.
ORDER NOW
Liteon IHOS104-06 4x BD-ROM (Black) - OEM @ £29.99 inc VAT
Lite-On BD-ROM drives offer the best solution for people who want to enjoy High Definition Blu-ray movies at an affordable cost. Besides Blu-ray movies, your current DVD and CD collections can also be played. Lite-On BD-ROM drives are compatible with Blu-ray, DVD and CD formats to ensure optimal playback possibilities.
• Higher transfer rates with SATA connection.
• Future proof; compatibility with the latest motherboards.
• Better airflow in PC casings due to smaller cable and plug sizes.
• Enjoy High Definition Blu-ray movies.
• This is Bare OEM Hardware Drive and software is included PowerDVD
- Read Speed - 32x (CD) / 12x (DVD) / 4x (BD)
- Enclosure Type - Internal
- Enclosure Colour - Black
- Interface - Serial ATA
Was £34.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Asus BC-12B1ST BluRay-Rom / DVD-RW Drive OEM @ £59.99 inc VAT
The ASUS internal BC-12B1ST dual format high definition drive that has the capability to read and play different Blu-ray formats. The BC-12B1ST also reads and writes in three types of DVD formats in one convenient package – DVD+R, DVD-R and DVD-RAM
- Reading Speeds: BD-R : 8X / BD-RE : 8X / BD-ROM : 8X / BD-R(DL) : 8X / BD-RE(DL) : 6X / BD-ROM(DL) : 8X / DVD+R : 16X / DVD-R : 16X / DVD+RW : 12X / DVD-RW : 12X / DVD-ROM : 16X / DVD+R(DL) : 12X / DVD-R(DL) : 12X / DVD-ROM(DL) : 12X / DVD-RAM : 12X / CD-R : 48X / CD-ROM : 48X / BDMV Playback : 4X / DVD Video Playback : 6X / VCD Playback : 16X / Audio CD Playback : 16X
- Write Speeds: BD-R : 12X / BD-R(DL) : 8X / BD-R(LTH) : 4X / BD-RE : 2X / BD-RE(DL) : 2X / DVD+R : 16X / DVD-R : 16X / DVD+RW : 8X / DVD-RW : 6X / DVD+R(DL) : 8X / DVD-R (DL) : 8X / DVD-RAM : 12X / CD-R : 48X / CD-RW : 24X
- Buffer: 8 MB
Was £63.98 Inc. VAT
ORDER NOW
Samsung SH-224BB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM @ £18.95 inc VAT
The SH-S224 drive offers a powerful over-speed performance feature that enables consumers to burn data at high speeds - even on low speed media. With over-speed recording, users can write at 24X speeds on 16X media and 12X speeds on 8X media. As lower speed media is more cost-effective, users can save money while burning discs at faster speeds.
The SH-S224 drive provides blazing recording speeds across a gamut of different data media types including 24X DVD±R recording, 12X DVD-RAM recording, 16X DVD+R Dual Layer recording, 12X DVD-R Dual Layer recording, 8X DVD+RW recording and 6X DVD-RW recording. It enables consumers to burn 4.7GB on a DVD±R disc in approximately 4 minutes and 26 seconds, a 6 percent increase in speed compared to a 20X DVD writer. It also takes less than 12 minutes to burn 4.7GB in DVD-RAM format, which is a 30 percent increase in speed over a 20X DVD drive.
Samsung's SH-S224 drive supports SATA interface, the dominant interface for PCs.
As with Samsung's complete WriteMaster optical disc drive lineup, the SH-S224 features specific technology that ensures best-of-breed performance including SAT1 (Speed Adjustment Technology), TAC2 (Tilt Actuator Compensation) and Double OPC3 (Optimum Power Control). Buffer Under Run Free Technology4 supports stable writing under high speed, and Magic Speed5 and ABS (Automatic Ball Balancing System) 6 technologies reduce vibration and noise. The SH-S224 is also eco-friendly designed and is RoHS compliant.
Write Speed
- DVD-R: 24x
- DVD-R: 24x
- DVD-R DL: 12x
- DVD+R DL: 16x
- DVD+RW: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- CD-R:48x
- CD-RW: 4x
Read Speed
- DVD-R: 16x
- DVD+R: 16x
- DVD-R DL: 12x
- DVD+R DL: 12x
- DVD-RW: 12x
- DVD+RW: 12x
- DVD-RAM: 12x
- CD-R: 40x
- CD-RW: 40x
Was £20.99 Inc. VAT
Only £18.95 inc VAT.
ORDER NOW
Asus 24x DVD±RW DRW-24B5ST SATA ReWriter - Black (OEM) @ £18.95 inc VAT
ASUS DRW-24B5ST is a powerful 24X DVD±R/12X DVD±R(DL)/8X DVD+RW/6X DVD-RW/16X DVD-ROM/12X DVDRAM/ 48X CD-R/32X CD-RW/48X CD-ROM for a seamless function of flexibility, high quality and reliability.
- Interface: SATA-II
- Tray Loading
- Auto vibration Reduction System
- CD Write Speed: 48x
- DVD Write Speed: 42x
- CD Read Speed: 48x
- DVD Read Speed: 16x
- DVD-RAM Read Speed: 12x
- 1 Year Warranty
Was £21.98 Inc. VAT
ORDER NOW
Asus Xonar D2X 7.1 PCI-E Sound Card @ £79.99 inc VAT
With the introduction of Windows Vista, the whole audio architecture landscaped has been changed. This has resulted in teething problems for gamers - with the possibility of losing all surround sound or hardware accelerated Direct3D and EAX while gaming in the Windows Vista environment. To circumvent this problem, the Asus Xonar family of audio cards utilizes an Asus exclusive technology - the new DS3D GX extension in the Xonar D2X driver; to provide full support for surround sound and hardware accelerated features by translating DirectX to the DS3D GX. While other solutions like OpenAL requires special installation and game support, DS3D GX doesn't. Gamers can enjoy DirectX gaming with hardware enhanced surround sound and EAX effects automatically and immediately after installation. Asus Xonar D2X audio card, dedicated to be the best audio card for gaming and home entertainment, provides unprecedented 118dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24-bit ultra fidelity input and output with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar D2X is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Centre, which you will never have with onboard audio or other sound cards.
- PCI-Express Interface
- Vista Gaming with DirectSound & EAX support
- Hi-Fi class audio quality with SNR up to 118dB
- Dolby HomeTheater Technologies & DTS Connect
- Valuable Cakewalk and Ableton Live music production software bundled
- Unprecedented SSNR NR Up to 118db reaching the limit of PC audio sound quality clarity
- Full duplex High-definition audio processing at 192KHz/24Bit for all Input and outputs and Inputs
- Versatile Dolby/DTS Audio Technologies for Game, Music, and Video
- Accurate 3D sound positioning and hardware acceleration for PC gaming
- Real-time DDL and DTS Connect encoders for amazing gaming and surround sounds over your Home Theater System
- Requires floppy power-connector
- Vista Ready
Was £89.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp @ £22.99 inc VAT
The Xonar DG sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DG an ideal sound card for gamers who want to remain totally aware of their play environments.
- Built-in Headphone AMP
- Powers up every sound detail in gaming
- 3 gain modes for different usage scenarios
- Dolby Headphone for an immersive 5.1 surround imaging
- GX2.5 for realistic 3D audio effects
Was £25.99 Inc. VAT
Only £22.99 inc VAT.
ORDER NOW
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp - OEM @ £19.99 inc VAT
- OEM Bare card.
Driver location: http://uk.asus.com/Multimedia/Audio_Cards/Xonar_DG/#download
Was £22.99 Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Asus Xonar DGX 5.1 PCI-Express Sound Card with built in Headphone Amp @ £21.95 inc VAT
The Xonar DGX sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DGX an ideal sound card for gamers who want to remain totally aware of their play environments.
- PCI-E
Was £24.98 Inc. VAT
Only £21.95 inc VAT.
ORDER NOW
Asus Xonar Essence STX Sound Card @ £119.99 inc VAT
The Xonar Essence STX PCI-Express is the latest sound card from Asus that provides high quality audio performance. Its integrated headphone amplifier produces less than 0.001% distortion to accompany its industry-leading 124dB Signal-to-Noise Ratio (SNR). The sound cards also boast Hyper-ground technology, EMI Shield design, AV100 high-definition sound processor, 24-bit Burr Brown PCM 1792A D-A converters, Nichicon Fine Gold capacitors, Optical digital output, Two pairs of RCA jacks and Input and output 6.3mm stereo jacks. The new Asus Xonar Essence STX PCI-Express is also perfect for gaming and entertainment PCs since it supports ASIO 2.0, Dolby Digital Live, Headphone, Virtual Speaker, Pro-Logic II home theater sound technologies and DS3D GX2.5 3D gaming engines.
- Optical digital output
- EMI Shield design
- Dolby Digital Live
- Pro-Logic II home theater sound technologies
- DS3D GX2.5 3D gaming engines
- 24-bit Burr Brown PCM 1792A D-A converters
- 124dB Signal-to-Noise Ratio (SNR)
Was £129.98 Inc. VAT
ORDER NOW
Asus Xonar Essence ST Sound Card @ £119.99 inc VAT
Choosing only the best components and finest design, the Xonar Essence ST achieves unprecedented 124dB SNR - 64 times clearer than on-board solutions, bringing top-of-the shelf audio experience for audiophiles. Xonar Essence ST is the world’s first audio card to focus on precision clock tuning to minimize audio jitter. The result is extensive musical details and lively sound image presented for revolutionary experience.
- Industry-leading 124dB SNR
- Built-in headphone amp drives every available headphone with <0.001% distortion
- Nichicon Fine Gold capacitors offer great dynamic performance
- Perfectly shielded EMI-free analog output path
- Customize your sound color effortlessly via swappable OPAmp socket
Was £144.98 Inc. VAT
ORDER NOW
Asus Xonar Xense Sound Card + Sennheiser PC 350 Xense Edition Headset @ £179.99 inc VAT
The new Asus Xonar Xense One and Sennheiser PC 350 Xense Edition package is the result of cooperation between Asus and premier personal audio maker, Sennheiser. Xonar Xense is a perfectly matched combination of cutting edge audio card and superior quality headphones that reinvents immersive sound for serious gamers. The gaming audio set creates unbeatable sonic experiences in PC gaming that are sure to be appreciated by hardcore gamers keen on competitive online play.
- Powerful headphone amplifier and matched high-impedance driver secure FPS-optimized sound positioning and dynamics
- No footsteps missed in front of the 118dB SNR sound clarity brought by EMI shield and studio-standard 6.3mm audio jack
- Stylish full-stainless steel design matches the earcup cover of Sennheiser headset
- Pro gamers’ long-hour usage catered by excellent headset ergonomics
- New Gain Level perfectly tuned up for the PC 350 headset
Was £189.95 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Adata DashDrive Air AE400 Wireless Storage Reader and Power Bank @ £52.99 inc VAT
The AE400 can serve multiple mobile devices to read/write and stream data from SD memory cards and USB storage media via wireless technology, and is also equipped with a power bank that can charge other mobile devices.
Data transfer between devices and SD card/USB drive/ Portable HDD
- The AE400 adopts Samba/WebDAV server/Http streaming protocol to provide data transfer and sharing, providing devices (iOS/Android/ Windows/OS X/Linux) with wireless access to a SD Card, USB Flash Drive, or Portable HDD.
- Supports up to 15 hours continuous stream for one user.
- Supports simultaneous streaming of 1080p video for up to 3 users or 720p video for up to 5 users.
Power Bank
- Built-in high capacity battery: 5000 mAh
- Supports fast charging for iPhone/iPad
Easy to operate wireless hotspot
- The AE400 can connect to existing wireless networks and create an internet bridge connection. Through this hot spot, up to 10 other devices can connect to the internet through the AE400.
Free Application Download
- For iPad, iPad mini, iPod Touch and iPhone users. Requires iOS 5.0 or later versions. This application is also suitable to Android 2.3 and later versions’ devices.
Stylish Housing
- The surface of the AE400 gleams with a modern, hexagonal lattice design.
Cable transfer mode
- The AE400 can also act as a standard card reader via micro USB cable connected to a computer.
- Ports: Micro-B USB (data transmission & battery charging), USB AF (host port for UFD/portable HDD or Power Bank function), SD card (for SD/SDHC/SDXC)
- Battery: Li-Polymer 5000mAh rechargeable battery
- Power Bank: 5000 mAh
- Temperature: Operating 0~50°C; Storage -20~60°C
- File system compatibility: FAT32/exFAT
- Operating System Compatibility: iOS 5.0+ / Android 2.3+ Windows XP, Vista, 7, 8 Mac OS X 10.x+ / Linux 2.4+
- Wireless standard: IEEE 802.11b/g/n
- Wireless security: WPA, WPA2
- Data rate: up to 150 Mbps (wireless), up to 480 Mbps (USB2.0)
- Dimensions (L x W x H): 80 x 59 x 21mm (3.1 x 2.3 x 0.8in)
- Weight: 128g
- Warranty: One Year Warranty
- Box Contents: AE400, User’s guide, Micro USB cable
- Hexus Review: http://hexus.net/tech/reviews/storage/52441-adata-dash-drive-air-ae400/
- Kitguru Review: http://www.kitguru.net/mobile/zardon/adata-dashdrive-air-ae400-review/
Was £59.99 Inc. VAT
Only £52.99 inc VAT.
ORDER NOW
Intel 330 Series 60GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail @ £69.95 inc VAT
Get Fast. Play Fierce.
Faster game and application loads, less lag, smoother visuals.
Stay ahead of the competition when you level up to 6.0 gigabits per second (Gb/s) performance
New Level of Performance
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 500MB/sec
- Maximum Write: 450MB/sec
- Max I/O Per Second (IOPS): 33000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 years
Was £79.99 Inc. VAT
Only £69.95 inc VAT.
ORDER NOW
Intel 335 Series 180GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail @ £139.99 inc VAT
- Capacity: 180GB
- Maximum Read: 550MB/sec
- Maximum Write: 520MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- Warranty: 3 years
Only £139.99 inc VAT.
ORDER NOW
OCZ Vector 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (VTR1-25SAT3-128G) @ £113.99 inc VAT
The groundbreaking Vector Series delivers an industry-leading solid-state storage solution designed to provide superior user experience and improved application performance.
Advanced suite of NAND flash management keeps your drive at higher sustained performance over the long term for maximum endurance.
Excels in both incompressible and compressible data types such as multimedia, encrypted date,.ZIP files and software.
Cutting-edge controller technology delivers maximum performance and delivers unmatched endurance without compression or loss of usable capacity, rated for 20GB/day of host writes for 5 years (typical client workloads)
- Capacity: 128GB
- Controller: Indilinx Barefoot 3
- Maximum Write: 400MB/sec
- Max I/O Per Second (IOPS): 95000 IOPS (4KB File)
- Warranty: 5 Years
Was £119.99 Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW) @ £83.99 inc VAT
The Samsung SSD840 is a high performance SSD designed for power users. Capable of delivering up to 98,000 IOPS Random Read Speed and 540MB/s Sequential Read speed, it is an SSD of unrivaled high performance. Even better, the advanced MDX controller delivers these speeds regardless of data type, unlike some competing controllers that greatly favor compressible data.
• Capacity: 120GB
• Sequential Read: 530MB/s
• Sequential Write: 130MB/s
• Random Read (QD32, 4KB): 86,000 IOPS
• Random Write (QD32, 4KB): 32,000 IOPS
• Random Read (QD1, 4KB): 7,900 IOPS
• Random Write (QD1, 4KB): 29,000 IOPS
• Warranty: 3 Year
Was £89.99 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
Samsung 128GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD128BW) @ £113.99 inc VAT
The Samsung SSD840 PRO is a high performance SSD designed for power users. Capable of delivering up to 100,000 IOPS Random Read Speed and 540MB/s Sequential Read speed, it is an SSD of unrivaled high performance. Even better, the advanced MDX controller delivers these speeds regardless of data type, unlike some competing controllers that greatly favor compressible data.
• Capacity: 128GB
• Sequential Write: 390MB/s
• Random Read (QD32, 4KB): 97,000 IOPS
• Random Write (QD32, 4KB): 90,000 IOPS
• Random Read (QD1, 4KB): 9,800 IOPS
• Random Write (QD1, 4KB): 31,000 IOPS
• Active Power Use: 0.068W (down from 0.24W for 830 Series)
• Idle Power Use: 0.042W (down from 0.14W for 830 Series)
• Warranty: 5 Year
ORDER NOW
Samsung 250GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD250BW) @ £131.99 inc VAT
• Capacity: 250GB
• Sequential Read: 540MB/s
• Sequential Write: 250MB/s
• Random Read (QD32, 4KB): 96,000 IOPS
• Random Write (QD32, 4KB): 62,000 IOPS
• Warranty: 3 Year
ORDER NOW
Startech 2-Port SATA III 6Gbps PCI-Express Controller Card (PEXSAT32) @ £26.99 inc VAT
The PEXSAT32 2-Port PCI Express SATA 6 Gbps (SATA 3.0) Controller Card offers simple connectivity between a host computer and SATA 3.0 devices - a cost-effective solution for connecting high-speed storage, such as High RPM Hard Drives and Solid State Drives (SSD), which in turn allows for easier data backups and archiving.
With full support for SATA 3.0 hard drives and data transfer speeds of up to 6 Gbps, the adapter card features a native PCI Express single chipset that provides enhanced compatibility, reliability and performance for external SATA 600 MB/s storage needs.
The controller card is backward compatible with SATA 2.0 devices, providing the versatility to use older storage, and features port multiplier capability with command-based and FIS-based switching for connecting multiple external hard drives to a host PC through a single external SATA connection.
A dual profile solution, the SATA 3.0 controller card includes a low profile bracket for installation in slimline or small form factor computer cases.
- Number of Ports: 2
- Includes normal and low profile backplate
- Max Data Transfer Rate: 6Gbp/s
- OS Compatability: XP, Vista, Windows 7, and Server 2008
- Lifetime Warranty
Was £31.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
OcUK Premium One Piece 8GB USB2.0 Stainless Steel Pen Drive @ £5.99 inc VAT
nonl2brPremium Stainless Steel single piece crafted 8GB Overclockers UK branded flash pen finished in a sophisticated champagne. Featuring speeds of up to 15Mb/s Read and 12Mb/s write along with a 5 year Warranty. Featuring Kingstons Flash technology the Overclockers UK flash drive delivers admirably in all aspects of performance, value and design.<br>
<br><br>
- Hi Speed USB 2.0 Compatible (backwards compatible to USB 1.1)<br>
- Easy plug and play functionality<br>
- Compatible with Windows® 7, Windows Vista®, Windows XP®, Windows 2000®, Windows® ME, Linux 2.4 and later, Mac® OS9, X and later<br>
- Portable and light weight (5.5 grams)<br>
- Up to 15Mb/s Read, 12Mb/s Write.<br>
- Lanyard or Keyring attachable<br>
- Dimensions: (LxWxD) 56x17x6mm <br>
- 5 Year Warranty<br>
- Capacity: 8GB<br>
<br><br>
<CENTER><IMG SRC="http://www.overclockers.co.uk/LP/images/transcend_chart.JPG" width="509" height="456"/></CENTER>
Was £6.49 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
OcUK Premium One Piece 16GB USB2.0 Stainless Steel Pen Drive @ £8.99 inc VAT
nonl2brPremium Stainless Steel single piece crafted 16GB Overclockers UK branded flash pen finished in a sophisticated champagne. Featuring speeds of up to 15Mb/s Read and 12Mb/s write along with a 5 year Warranty. Featuring Kingstons Flash technology the Overclockers UK flash drive delivers admirably in all aspects of performance, value and design.<br>
<br><br>
- Capacity: 16GB<br>
<br><br>
Was £9.98 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
Asus Z77 Sabertooth Intel Z77 (Socket 1155) DDR3 Motherboard @ £184.99 inc VAT
The new-generation ASUS SABERTOOTH Z77 with 32GB DDR3 memory features both the innovative Intel Z77 express chipset and Thermal Armor for precision cooling and unsurpassed reliability. The SABERTOOTH Z77 also features ASUS exclusive pioneering Dual Intelligent Processors 3 with SMART DIGI+ Power Control where 2 dedicated chips, the TPU and EPU provide an auto overclock and save energy through optimized power management, significantly boosting performance.
Another incredible feature is Fan Xpert 2 which enables the most customizable fan controls ever offered on a motherboard, while ASUS Wi-Fi GO! offers a future-proof and more convenient entertainment experience. Wi-Fi GO! can also convert PCs into routers and home entertainment becomes easier with Wi-Fi functions such as DLNA streaming, so users can enjoy content from a variety of devices.
Furthermore the ASUS SABERTOOTH Z77 includes support for both NVIDIA SLI and AMD CrossFireX which offer the ultimate in flexibility for 3D graphics. While LudicLogix Virtu MVP boots responsiveness, improves gaming frame rates by 30-70%, sharpens visual quality and works seamlessly with hundreds of game stations. Thus the SABERTOOTH Z77 takes motherboards to a whole new level!
Asus Exclusive Innovations:
· SMART DIGI+ Power Control
· Fan Xpert+
· Network iControl
· USB BIOS Flashback
· USB 3.0 Boost
· AI Suite II
Innovations:
· Quad GPU AMD CrossfireX - a flawless architecture accommodating the power of up to four graphics cards
· LudicLogix Virtu MVP - boots responsiveness, improves gaming frame rates by 30-70% and sharpens visual quality
Spec details:
SABERTOOTH Z77 V1.0
Note: The specifications are subject to change without notice.
CPU
LGA1155 socket for Intel® 3rd/2nd Generation Core™ i7/ i5/ i3/ Pentium® / Celeron® Processors
Supports 22/32nm CPU
Supports Intel® Turbo Boost Technology 2.0
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
** Refer to www.asus.com for CPU support list
Chipset
Intel® Z77 Express Chipset
Memory
4 x DIMM, Max. 32GB, DDR3 1866/1600/1333/1066 MHz, Non-ECC, un-buffered Memory
Dual channel memory architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs. Please refer to Memory QVL(Qualified Vendors List) for details.
** Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors List).
Expansion Slots
2 x PCI Express 3.0*/2.0 x16 slots (Single at x16, Dual at x8/x8)
1 x PCI Express 2.0 x16 slot** [black] (Max. at x4 mode, compatible with PCIe x1 and x4 devices)
3 x PCI Express 2.0 x1 slots
* PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
** The PCIe 2.0 x16 slot shares bandwidth with PCIe 2.0 x1_1 slot, PCIe 2.0 x1_2 slot and PCIe 2.0 x1_3 slot. The PCIe 2.0 x16 slot default setting is in x1 mode.
VGA
Integrated Graphics Processor- Intel® HD Graphics support
Multi-VGA output support: DisplayPort/HDMI port
Supports DisplayPort 1.1a with max. resolution 2560 x 1600@60Hz
Supports HDMI 1.4a with max. resolution 1920 x 1200@60Hz
Supports Intel® InTru™ 3D/Quick Sync Video/Clear Video HD Technology/Insider™
Maximum shared memory of 1696MB
Multi-GPU support
Supports NVIDIA® Quad-GPU SLI™ Technology
Supports AMD® Quad-GPU CrossFireX™ Technology
Supports LucidLogix Virtu MVP Technology*
* LucidLogix Virtu MVP supports Windows 7 operating systems.
Storage
Intel® Z77 Express Chipset:
- 2 x SATA 6Gb/s ports (brown) with RAID 0,1,5 and 10 support
- 4 x SATA 3Gb/s ports (black) with RAID 0,1,5 and 10 support
- Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology*
2 x ASMedia® 1061 SATA controllers**:
- 2 x SATA 6Gb/s ports (gray)
- 2 x eSATA 6Gb/s ports (red)
* Supports on Intel® Core™ processor family with Windows 7 operating systems.
** These SATA ports are for data hard drivers only. ATAPI devices are not supported.
LAN
Intel® 82579V Gigabit LAN controller
Audio
Realtek® ALC892 8-Channel High Definition Audio CODEC
- Absolute Pitch 192khz/24bit True BD Lossless Sound
- BD Audio Layer Content Protection
- Supports Jack-Detection, Multi-streaming, and Front Panel Jack-Retasking
- Optical S/PDIF out port at back I/O
USB
Intel®Z77 Express Chipset- supports ASUS USB 3.0 Boost UASP Mode.*
- 4 x USB 3.0 ports(2 ports at mid-board, 2 ports at back panel)
ASMedia® 1042 USB 3.0 controller- supports ASUS USB 3.0 Boost UASP Mode.
- 2 x USB 3.0 ports at back panel (blue)
- 10 x USB 2.0/1.1 ports (6 ports at mid-board, 4 ports at back panel)
*The USB 3.0 ports only support Windows® 7 or later versions. UASP standard only supports Windows® 8
Exclusive TUF Features
"Ultimate COOL!" Thermal Solution
- TUF Thermal Armor
- TUF Thermal Radar
"TUF ENGINE!" Power Design
- 8+4+2 Digital Phase Power Design
- TUF Components (Choke, Cap & MOSFET; certified by military-standard)
- ASUS DIGI+ Power Control Utility
"Safe & Stable!" Guardian Angel
- ESD Guards
- MemOK!
- Anti Surge
- Dust Defender
Other Special Features
- USB 3.0 Boost featuring the latest USB 3.0 UASP standard
- USB BIOS Flashback with USB BIOS Flashback Wizard for EZ BIOS download scheduling
- USB Charger+ featuring quick-charging function for all smart devices
- Network iControl featuring instant network bandwidth domination for top network program in use
- Lucid Virtu MVP
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- AI Suite II
- ASUS Q-Connector
- ASUS Q-Shield
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS MyLogo 2
- Multi-language BIOS
Back Panel I/O Ports
1 x DisplayPort
1 x HDMI port
1 x Optical S/PDIF Output
1 x USB BIOS Flashback Button
1 x LAN (RJ45) port
4 x USB 3.0/2.0 ports (blue, 1 supports USB BIOS Flashback)
4 x USB 2.0/1.1 ports
8-channel Audio I/O ports
Internal I/O Connectors
1 x USB 3.0/2.0 connector supports additional 2 USB 3.0/2.0 ports (19-pin; moss green)
3 x USB 2.0/1/1 connectors support additional 6 USB 2.0/1.1 ports
4 x SATA 6Gb/s connectors (2 x brown; 2 x gray)
4 x SATA 3Gb/s connectors (black)
1 x CPU Fan connector (4-pin Black)
1 x CPU OPT Fan connector (4-pin Black)
4 x Chassis Fan connectors (4-pin Black)
2 x Assistant Fan connector (3-pin White)
Front panel audio connector(AAFP)
1 x S/PDIF Out header
1 x Thunderbolt header
24-pin EATX Power connector
8-pin EATX 12V Power connector
System Panel (Q-Connector)
1 x MemOK! button
1 x Clear CMOS jumper
BIOS
64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function, F3 Shortcut Function and ASUS DRAM SPD (Serial Presence Detect) memory information
Manageability
WfM 2.0, DMI 2.0, WOL by PME, PXE
Accessories
2 x Serial ATA 6Gb/s cables
2 x Serial ATA 3Gb/s cables
1 x ASUS SLI bridge connector 7cm
1 x ASUS Q-Shield
1 x 2 in 1 Q-connector
2 x Accessory Fans(35mm)
1 x Accessory Package
- 1 x 40mm I/O Cover fan lid
- 3 x PCIe x16 slot dust covers
- 2 x DRAM slot dust covers
- 3 x PCIe x1 slot dust covers
- 2 x Short fan screws
- 4 x Long fan screws
- 1 x Adhesive Sponge for 35mm Fan
1 x TUF Inside sticker
1 x TUF Certification card
1 x TUF 5 Year Warranty manual (by region)
Thermal Armor Accessory Installation Guide
User's manual
Support DVD
Drivers
Anti-virus software (OEM version)
ASUS Update
ASUS Utilities
Form Factor
ATX Form Factor, 12”x 9.6” (30.5cm x 24.4cm)
Was £188.99 Inc. VAT
Only £184.99 inc VAT.
ORDER NOW
Asus P8B WS Intel C206 (Socket 1155) DDR3 Motherboard @ £179.99 inc VAT
The ASUS Workstation Series is the ideal foundation for a powerful PC. It delivers awesome power, dependable performance and unparallel multiple I/O scalability for the most demanding tasks and future upgrades. It intelligently reduces operation noise and dissipates heat through advanced and environmentally friendly methods to accommodate user needs. ASUS Workstation Series motherboards also bring you ultimate reliability and quality through our 24x24 initiative, which means 24 hour operation and a 24-month life cycle supply guarantee. Let the ASUS Workstation Series improve the quality of your work and life.
CPU
- Intel® Socket 1155 for 3rd/2nd Generation Core™ i7/Core™ i5/Core™ i3 Processors
- Intel® Socket 1155 for Intel® E3-1200/12x5 v2 processors
- Intel® Socket 1155 for Intel® E3-1200/12x5 processors
- Supports Intel® 32 nm CPU
- Supports Intel® Turbo Boost Technology 2
Chipset
- Intel® C206
Memory
- 4 x DIMM, Max. 32GB, DDR3 1600/1333/1066 MHz ECC, Non-ECC, Un-buffered Memory *1
- Dual Channel Memory Architecture
- Supports Intel® Extreme Memory Profile (XMP)
* Refer to www.asus.com or user manual for the Memory QVL (Qualified Vendors Lists).
* Non-ECC, Un-buffered memory only support for client OS (Windows7,Vista and XP).
Graphic
- Integrated Graphics Processor *2
- VGA output support : DVI port
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
- Maximum shared memory of 1748 MB
Multi-GPU Support
- Supports AMD Quad-GPU CrossFireX™ Technology
Expansion Slots
- 2 x PCIe 3.0/2.0 x16 (x16 or dual x8, black+blue) *3
- 2 x PCIe 2.0 x16 (x4 mode, white)
- 1 x PCIe x1
- 1 x PCI
Storage
- Intel® C206 chipset : 2 x SATA 6Gb/s port(s), gray
- Intel® C206 chipset : 4 x SATA 3Gb/s port(s), blue
- Support Raid 0, 1, 5, 10
LAN
- Intel® 82574L, 2 x Gigabit LAN Controller(s)
Audio
- Realtek® ALC892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- Audio Feature :
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
IEEE 1394
- VIA® 6308S controller
- 2 x IEEE 1394a port(s)
USB Ports
- Built-in Controller : 2 x USB 3.0 port(s) (2 at back panel, blue)
- Intel® C206 chipset : 14 x USB 2.0 port(s) (6 at back panel, gray, 8 at mid-board)
Workstation Feature
- 4 x PCIe x 16 slot(s)
- G.P. Diagnosis Card bundled
- Quick Gate: 2 x vertical USB 2.0 on board
- ASUS SASsaby series Cards support
- ASUS WS Diag. LED
Special Features
- ASUS EPU :
- EPU switch
- ASUS Power Design :
- 8 +2 Phase Power Design
- GPU Boost with switch
- ASUS Exclusive Features :
- MemOK!
- AI Suite II
- Anti-Surge
- ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert
- ASUS EZ DIY :
- ASUS EZ Flash
- ASUS Q-Design :
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports
- 1 x PS/2 keyboard/mouse combo port(s)
- 1 x DVI-I
- 1 x IEEE 1394a
- 2 x LAN (RJ45) port(s)
- 2 x USB 3.0
- 6 x USB 2.0
- 1 x Coaxial S/PDIF out
- 1 x Optical S/PDIF out
- 6 x Audio jack(s)
Internal I/O
- 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
- 2 x Vertical USB 2.0 port(s)
- 1 x TPM connector(s)
- 1 x COM port(s) connector(s)
- 1 x IEEE 1394a connector(s)
- 1 x CPU Fan connector(s)
- 1 x Power Fan connector(s)
- 1 x S/PDIF out header(s)
- 1 x 24-pin EATX Power connector(s)
- 1 x 8-pin ATX 12V Power connector(s)
- 1 x Front panel audio connector(s) (AAFP)
- 1 x System panel(s)
- 1 x MemOK! button(s)
BIOS
- 32MB flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.6, ACPI 2.0a, multi-language BIOS, ASUS EZ Flash Utility, ASUS CrashFree BIOS 3
Manageability
- WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Operating System
- Fedora 13
- Windows® Server 2008 R2 Enterprise
- Windows® Server 2008 Enterprise 32/64-bit
- Windows® Server 2003 R2 Enterprise 32/64-bit
- Windows® 7 32/64-bit
- Windows® Vista 32/64-bit
- Windows® XP 32/64-bit
- RedHat® Enterprise Linux WS 6.0 32/64-bit
- Open SUSE 11.4
- Ubuntu Desktop 10.04
Form Factor
- ATX Form Factor
- 12 inch x 9.6 inch ( 30.5 cm x 24.5 cm )
Was £184.99 Inc. VAT
ORDER NOW
Gigabyte Z77X-UP4 TH Intel Z77 (Socket 1155) DDR3 Motherboard @ £161.99 inc VAT
nonl2br<p><font face="Arial" color="#0066CC" size="4"><b>Special Features / Z77X-UP4<font color="#00CCFF">TH</font><br>
</b><font color="#000000" size="2"><br>
GIGABYTE 7 series motherboards combine a host of new and exciting technologies
with the latest Intel Z77 Express Chipset, creating a unique range of motherboard
designs that harness the outstanding performance of the new 3rd generation Intel®
Core™ processors. With an exclusive 'All Digital' VRM design, GIGABYTE
3D Power and GIGABYTE 3D BIOS (Dual UEFI), GIGABYTE 7 series motherboards ensure
exceptional power delivery and absolute control, with additional features that
ensure an unrivalled experience on your next PC build. </font></font></p>
<table style="border-width: 0 0 1px 1px; border-spacing: 0; border-collapse: collapse; border-style: solid; border-color: #dcdcdc;" width="95%" border="0" cellspacing="0" align="center">
<tr valign="middle">
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px" height="59"><img src="http://img830.imageshack.us/img830/9393/intelb.jpg" width="82" height="50"></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="*" height="59">
<font face="Arial" color="#0066CC" size="2">Support for the new INTEL 3rd
Generation CPU's. <font color="#000000">On the socket 1155 platform.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 0 1px 0 1px; border-style: solid; border-color: #dcdcdc;" width="5px" height="59"> </td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px" height="59"><img src="http://img853.imageshack.us/img853/8321/usbpower3.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">USB 3x Power Boost. <font color="#000000">Delivering
greater device compatibility and faster charge times.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img803.imageshack.us/img803/491/ud5e.jpg" width="82" height="50"></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="*">
<font size="2" face="Arial" color="#0066CC">Ultra Durable 5. <font color="#000000">Super
high rated Ferrite Core Chokes (60A). 2x Copper PCB and IR3550 IC's in the
CPU power zone for the coolest temperatures ever.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 0 1px 0 1px; border-style: solid; border-color: #dcdcdc;" width="5px"> </td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img16.imageshack.us/img16/957/usb3.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Super Speed USB 3.0. <font color="#000000">Super
fast transfer rates of up to 5 Gbps, 10x faster than USB 2.0.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img3.imageshack.us/img3/6383/virtumvp.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Lucid Virtu MVP. <font color="#000000">Producing
faster frame rates, with sharper visuals and reduced tearing.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img17.imageshack.us/img17/2311/sata3b.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Super SATA3 Native Suport. <font color="#000000">Supporting
super fast 6Gbps link speeds.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img62.imageshack.us/img62/4753/crossfiresli.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">NVIDIA SLI and AMD Crossfirex.
<font color="#000000">For multi display or ultimate performace gaming.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img694.imageshack.us/img694/3946/gen3v.jpg" width="82" height="50"></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="*"><font face="Arial" size="2" color="#0066CC">PCIe
GEN 3. <font color="#000000">Designed to take full advantage of the next
generation high bandwidth graphic card solutions.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="5px"><img src="http://img29.imageshack.us/img29/5711/dualeufibios.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">UEFI DualBIOS™. <font color="#000000">A
superior graphical BIOS interface, based on the trusted and secure GIGABYTE
Dual BIOS technology.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img803.imageshack.us/img803/5448/onoffcharge.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">ON/OFF Charge Technology. <font color="#000000">Allows
you to charge your iPad, iPhone or iPod even of your PC is off.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="5px"><img src="http://img220.imageshack.us/img220/2125/msata.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Onboard mSATA Connector. <font color="#000000">Mount
a low capcity mSATA SSD onto your motherboard to take advantage of INTEL
SRT and RAPID START.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img822.imageshack.us/img822/9665/dualthunderbolt.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Dual Thunderbolt. <font color="#000000">Daisy
chain up to 12 devices + 2 display monitors and transfer 1TB of data in
only 5 minutes!</font></font></td>
</tr>
</table>
<p><font face="Arial" color="#0066CC" size="2"><b><font size="4">Tech Spec / </font><font face="Arial" color="#0066CC" size="4"><b>Z77X-UP4<font color="#00CCFF">TH</font></b></font></b><font size="2">
</font><font face="Arial" color="#0066CC" size="2"><font size="2"><a href="http://uk.gigabyte.com/products/product-page.aspx?pid=4139#sp">[Click
for Complete/Advanced]</a></font></font></font></p>
<table style="border-width: 0 0 1px 1px; border-spacing: 0; border-collapse: collapse; border-style: solid; border-color: #dcdcdc;" cellpadding="0" cellspacing="0" width="95%" align="center" border="0" >
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" " align="left" width="114" height="26">
<font face="Arial" size="2" color="#0066CC">CPU</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="26">
<font face="Arial" size="2">Support for Intel Core i7, i5, i3, Pentium and
Celeron 1155 processors<font size="1">(Go to GIGABYTE's website for the
latest CPU support list.)</font></font> </td>
</tr>
<tr valign="middle" >
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114">
<font face="Arial" size="2" color="#0066CC">Chipset</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089">
<font face="Arial" size="2">Intel Z77 Express Chipset</font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="27"><font face="Arial" size="2" color="#0066CC">Memory</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="27">
<font face="Arial" size="2">4x DDR3 1600/1333/1066 MHz memory modules <br>
<font size="1">* Due to Windows 32-bit operating system limitation, when
more than 4 GB of physical memory is installed, the actual memory size displayed
will be less than 4 GB. </font></font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="27"><font face="Arial" size="2" color="#0066CC">Onboard
Graphics </font></td>
<font face="Arial" size="2">1x D-Sub, 1x DVI-D (1920x1200 max res), 1x HDMI
(1920x1200 max res), 2 x Thunderbolt ports (MDP1/MDP2)</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="24"><font face="Arial" size="2" color="#0066CC">Audio</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="24">
<font face="Arial" size="2">Realtek ALC892 HD Audo 2/4/5.1/7.1 S/PDIF In
& Out </font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="24"><font face="Arial" size="2" color="#0066CC">Multi-Graphics</font></td>
<font face="Arial" size="2">Support for AMD CrossfireX/NVIDIA SLI Technology</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="27"><font face="Arial" size="2" color="#0066CC">LAN</font></td>
<font face="Arial" size="2">1 x Realtek Gbe LAN chip</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="57">
<font face="Arial" size="2" color="#0066CC">Expansion Slots</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="57">
<p><font face="Arial" size="2">1 x PCI Express x16 slots, running at x16<font size="1"><br>
</font><font face="Arial" size="2">1 x PCI Express x16 slots, running
at x8</font><font size="1"><br>
</font><font face="Arial" size="2"><font face="Arial" size="2">1 x PCI
Express x16 slots, running at x4</font></font><font size="1"><br>
</font>3x PCI Express x1 slot<br>
</font> <font face="Arial" size="2">1x PCI slots </font> </p>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="51"><font face="Arial" size="2" color="#0066CC">Storage
Interface</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="51">
<p><font face="Arial" size="2">2 x SATA 6Gb/s connectors<br>
4 x SATA 3Gb/s connectors <br>
1 x mSATA 3Gb/s (Disables sata connector 5 when in use)</font></p>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="43"><font face="Arial" size="2" color="#0066CC">USB</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="43"><font face="Arial" size="2">USB
3.0/2.0 : </font> <font face="Arial" size="2"> 6 x on the back panel, 2x
via USB brackets on headers<br>
</font> <font face="Arial" size="2">USB 2.0/1.1 : </font> <font face="Arial" size="2">6
x via USB brackets on headers</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Internal
I/O Connectors</font></td>
<font face="Arial" size="2">1 x 24-pin ATX main power connector, </font>
<font face="Arial" size="2">1 x 8-pin ATX 12V power connector,</font> <font face="Arial" size="2">2
x SATA 6Gb/s connector, 4 x SATA 3GB/s connectors, 1 x mSATA connector,</font>
<font face="Arial" size="2">1 x CPU fan header, </font> <font face="Arial" size="2">4
x system fan headers, </font> <font face="Arial" size="2"> 1 x front panel
header, </font> <font face="Arial" size="2">1 x front panel audio header,
</font> <font face="Arial" size="2">1 x S/PDIF Out header, </font> <font face="Arial" size="2">1
x S/PDIF In header, 3 x USB 2.0/1.1 headers,</font> <font face="Arial" size="2">1
x USB 3.0/2.0 headers,1 x clearing CMOS jumper, 1 x TPM header, 1 x Serial
port header.</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Back
Panel Connectors</font></td>
<font face="Arial" size="2">1 x PS/2 KB/Mouse port, 1 x D-Sub, 1 x DVI-D,
1 x HDMI, 2 x Thunder Bolt,</font> <font face="Arial" size="2">1 x Optical
S/PDIF Out connector, </font> <font face="Arial" size="2">6 x USB 3.0/2.0
ports,1 x RJ-45 ports, </font> <font face="Arial" size="2">5x audio jacks
</font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">BIOS</font></td>
<font face="Arial" size="2">2 x 64 Mbit AMI EFI BIOS,</font> <font face="Arial" size="2">Support
for DualBIOS™</font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Form
Factor</font></td>
<font face="Arial" size="2">ATX Form Factor; 30.5 x 24.4cm</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Warranty</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089"><font face="Arial" size="2">3
Year Gigabyte Warranty</font></td>
</tr>
</table>
Was £167.99 Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard @ £82.99 inc VAT
nonl2br
<br />
<p><font face="Arial" color="#0066CC" size="4"><b>Special Features / Z77-D3H<br>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img694.imageshack.us/img694/2274/ultradurable4classic.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Ultra Durable 4 Classic. <font color="#000000">Advanced
temprature, humidity, electrostatic and power failure protection... The
ultimate in reliability.</font></font></td>
</tr>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img30.imageshack.us/img30/6495/crossfirej.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">AMD Crossfirex. <font color="#000000">For
</tr>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"> </td>
<font size="2" face="Arial" color="#0066CC"></font></td>
</tr>
</table>
<p><font face="Arial" color="#0066CC" size="2"><b><font size="4">Tech Spec / </font><font face="Arial" color="#0066CC" size="4"><b>Z77-D3H</b></font></b><font size="2">
</font><font face="Arial" color="#0066CC" size="2"><font size="2"><a href="http://uk.gigabyte.com/products/product-page.aspx?pid=4140#sp">[Click
</tr>
</tr>
</tr>
(1920x1200 max res)</font></td>
</tr>
<font face="Arial" size="2">VIA VT2021 codec High Definition Audio 2/4/5.1/7.1-channel
w/ Support for S/PDIF Out</font> </td>
</tr>
<font face="Arial" size="2">Support for AMD CrossfireX</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="24"><font face="Arial" size="2" color="#0066CC">LAN</font></td>
<font face="Arial" size="2">1 x Atheros GbE chip (10/100/1000 Mbit) </font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="58">
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="58">
</font> <font face="Arial" size="2">2x PCI slots </font> </p>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="41"><font face="Arial" size="2" color="#0066CC">Storage
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="41">
</td>
</tr>
3.0/2.0 : </font> <font face="Arial" size="2">4x on the back panel, 2x via
</font> <font face="Arial" size="2">USB 2.0/1.1 : </font> <font face="Arial" size="2">4x
on the back panel, 6x via USB brackets on headers</font></td>
</tr>
<font face="Arial" size="2">1 x 4-pin ATX 12V power connector,</font> <font face="Arial" size="2">2
<font face="Arial" size="2">1 x CPU fan header, </font> <font face="Arial" size="2">3
</font> <font face="Arial" size="2">1 x S/PDIF Out header, </font> <font face="Arial" size="2">3
x USB 2.0/1.1 headers,</font> <font face="Arial" size="2">1 x USB 3.0/2.0
headers,1 x clearing CMOS jumper, 1 x TPM header, 1 x Serial port header</font></td>
</tr>
<font face="Arial" size="2">1 x PS/2 keyboard/mouse port, 1 x D-Sub, 1 x
DVI-D, 1 x HDMI, 1 x Optical S/PDIF Out connector, </font> <font face="Arial" size="2">4
x USB 3.0/2.0 ports,</font> <font face="Arial" size="2">4 x USB 2.0/1.1
</font> </td>
</tr>
</tr>
Factor</font></td>
</tr>
</tr>
</table>
Was £89.99 Inc. VAT
Only £82.99 inc VAT.
ORDER NOW
Gigabyte Z77N-WIFI Intel Z77 (Socket 1155) DDR3 Mini ITX Motherboard @ £94.99 inc VAT
The New Z77N-WIFI from Gigabyte gives you all the features of a fully overclockable Z77 chipset with the mini form factor of M-ITX making it perfect for a high end ultra compact PC.
CPU
Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
L3 cache varies with CPU
(Some Intel® Core™ processors require a graphic card, please refer "CPU support List" for more information.)
Chipset
Memory
2 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory
* Due to a Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than the size of the physical memory installed.
Support for DDR3 1600/1333/1066/800 MHz memory modules
Support for non-ECC memory modules
Support for Extreme Memory Profile (XMP) memory modules
(Please refer "Memory Support List" for more information.)
Onboard Graphics Integrated Graphics Processor:
1 x DVI-I port, supporting a maximum resolution of 1920x1200
2 x HDMI ports, supporting a maximum resolution of 1920x1200
Audio
Realtek ALC892 codec
2/4/5.1/7.1-channel
LAN
2 x Realtek GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
1 x PCI Express x16 slot, running at x16
(The PCIEX16 slot conforms to PCI Express 3.0 standard.)
* Whether PCI Express 3.0 is supported depends on CPU and graphics card compatibility.
Storage Interface Chipset:
2 x SATA 6Gb/s connectors (SATA3 0/1) supporting up to 2 SATA 6Gb/s devices
2 x SATA 3Gb/s connectors (SATA2 2/3) supporting up to 2 SATA 3Gb/s devices
Support for RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
USB Chipset:
Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header)
Up to 6 USB 2.0/1.1 ports (4 ports on the back panel, 2 ports available through the internal USB header)
1 x serial port header
1 x USB 3.0/2.0 header
2 x USB 2.0/1.1 headers
1 x CPU fan header
1 x system fan header
1 x front panel header
Back Panel Connectors
2 x HDMI ports
2 x antenna connectors
1 x DVI-I port
2 x USB 3.0/2.0 ports
2 x RJ-45 ports
1 x optical S/PDIF Out connector
5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Line In, Line Out, Mic In)
I/O Controller
iTE I/O Controller Chip
H/W Monitoring
System voltage detection
CPU/System temperature detection
CPU/System fan speed detection
CPU fan speed control
* Whether the CPU fan speed control function is supported will depend on the CPU cooler you install.
BIOS
2 x 64 Mbit flash
Use of licensed AMI EFI BIOS
Support for DualBIOS™
PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
Unique Features
Support for @BIOS
Support for Q-Flash
Support for Xpress Install
Support for EasyTune
* Available functions in EasyTune may differ by motherboard model.
Support for eXtreme Hard Drive (X.H.D)
Support for Auto Green
Support for ON/OFF Charge
Support for Q-Share
Support for EZ Setup
Bundle Software
Norton Internet Security (OEM version)
Operating System
Support for Microsoft® Windows 8/7/XP
Form Factor
Mini-ITX Form Factor; 17.0cm x 17.0cm
Was £98.99 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
Asus P8H61-MX USB 3.0 Intel H61 (Socket 1155) DDR3 Motherboard - OEM ** @ £39.95 inc VAT
** Part comes as board, I/O, SATA Cable, Manual and driver disc only. No Retail box.
This motherboard supports the Intel® 3rd/2nd generation processors in the LGA1155 package, with iGPU, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, 2-channel (4 DIMM) DDR3 memory and 16 PCI Express 3.0/2.0 lanes. This provides great graphics performance. Intel® 3rd/2nd generation processors are among the most powerful and energy efficient CPUs in the world.
The Intel® H61 Express Chipset is a single-chipset design to support socket 1155 Intel® 3rd/2nd generation processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, H61 chipset provides 4 USB 3.0 ports for 10 times faster data retrieval speed. Moreover, Intel® H77 Express Chipset can also enable iGPU function, letting users enjoy the latest Intel® integrated graphic performance.
Intel® Smart Response Technology boosts overall system performance. It uses an installed fast SSD (min 18.6GB available capacity required) as a cache for frequently accessed data. Key benefits include reduced load and wait times, and lower power consumption through the elimination of unnecessary hard drive spin. This technology combines SSD performance with hard drive capacity, operating up to 6X faster than a hard drive-only system.
Your computer can receive web updates with fresh content for selected applications, even when the system is in sleep mode. This means less time waiting for applications to update and sync with the cloud, leading to a more efficient computing experience.
Allows your computer to quickly resume from a low-power hibernate state in seconds. Saving your system memory to the designated SSD, it provides your computer a faster wake-up response time, while still keeping the energy use low.
Specifications:
CPU: Intel® Socket 1155 for 3rd/2nd Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
Supports Intel® 22 nm CPU
Chipset: Intel® H61
Memory: 2 x DIMM, Max. 16GB, DDR3 2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333 MHz Memory
* 1600MHz and higher frequency is supported by Intel® 3rd generation processors.
* Due to OS limitation, when installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Install a 64-bit Windows® OS when you want to install 4GB or more memory on the motherboard.
* Due to the CPU behavior, DDR3 2133/1866MHz memory module will run at DDR3 2000/1800MHz frequency as default.
Graphics: Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
Multi-GPU Support Supports LucidLogix® Virtu™ MVP Technology *1
Expansion Slots:
1 x PCIe 3.0/2.0 x16
1 x PCIe 2.0 x4
1 x PCIe 2.0 x1
1 x PCI
Storage:
Intel® H77 chipset :
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *3
LAN: Realtek® 8111F, 1 x Gigabit LAN Controller(s)
Audio: Realtek® ALC887 8-Channel High Definition Audio CODEC
USB Ports Intel® H61 chipset :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
10 x USB 2.0 port(s) (4 at back panel, black, 6 at mid-board)
Special Features ASUS EPU :
- EPU
ASUS Digital Power Design :
- ASUS DIGI+ VRM Utility
GPU Boost
- MemOK!
- Anti-Surge
- USB 3.0 Boost
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS EZ Flash 2
- ASUS MyLogo 2
100% All High-quality Conductive Polymer Capacitors
Back I/O Ports 1 x PS/2 keyboard/mouse combo port(s)
1 x DVI
1 x D-Sub
1 x HDMI
1 x LAN (RJ45) port(s)
2 x USB 3.0
4 x USB 2.0
3 x Audio jack(s)
Internal I/O Ports 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s)
4 x SATA 3Gb/s connector(s)
1 x Chassis Fan connector(s)
1 x Internal speaker connector(s)
1 x System panel(s)
1 x Chassis Intrusion connector(s)
BIOS 64Mb Flash ROM, AMI BIOS, PnP, DMI v2.0, WfM2.0, SMBIOS v2.5, ACPI v2.0a
Manageability WOL, PXE, PME Wake Up
Form Factor uATX Form Factor
9.6 inch x 8.2 inch ( 24.4 cm x 20.8 cm )
Was £43.99 Inc. VAT
Only £39.95 inc VAT.
ORDER NOW
Gigabyte H61MA-D2V Intel H61 (Socket 1155) DDR3 Motherboard @ £41.99 inc VAT
nonl2br
<p><font face="Arial" color="#0066CC" size="4"><b>Special Features / H61MA-D2V</b></font></p>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img830.imageshack.us/img830/9393/intelb.jpg" width="82" height="50"></td>
<font face="Arial" color="#0066CC" size="2">For INTEL® 1155 Processors.
<font color="#000000">The latest CPU technology.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img853.imageshack.us/img853/8321/usbpower3.jpg" width="82" height="50"></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img444.imageshack.us/img444/5711/dualeufibios.jpg" width="82" height="50"></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="*"><font size="2" face="Arial" color="#0066CC">GIGABYTE
Dual EUFI BIOS. <font color="#000000">A new innovative way to modify BIOS
settings.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img151.imageshack.us/img151/9414/dvih.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">DVI Output. <font color="#000000">Compatible
with HDCP.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img836.imageshack.us/img836/8124/ud4so.jpg " width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Ultra Durable 4. <font color="#000000">Next
generation high quality components.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="5px"><img src="http://img403.imageshack.us/img403/2329/japcaps.jpg " width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">50,000 Hours Japanese Solid
Capacitors. <font color="#000000">Delivering solid stability, reliability
and longevity.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="5px"><img src="http://img694.imageshack.us/img694/3946/gen3v.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">PCI Express Gen.3 Support. <font color="#000000">Delivering
maximum bandwidth for the latest graphics cards.</font></font></td>
</tr>
</table>
<p><font face="Arial" color="#0066CC" size="2"><b><font size="4">Tech Spec / </font><font face="Arial" color="#0066CC" size="4"><b>H61MA-D2V</b></font></b><font size="2">
</font><font face="Arial" color="#0066CC" size="2"><font size="2"><a href="http://uk.gigabyte.com/products/product-page.aspx?pid=4183#sp">[Click
<font face="Arial" size="2">Support for Intel<sup>Ž</sup> Core? i7/ i5 /
i3 / Pentium and Celeron<sup>Ž</sup>, Socket 1155 <font size="1">(Go to
GIGABYTE's website for the latest CPU support list.)</font></font> </td>
</tr>
<font face="Arial" size="2">Intel<sup>Ž</sup> H61 Express Chipset</font>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="27"><font face="Arial" size="2" color="#0066CC">Video</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="27"><font face="Arial" size="2">1x
DVI, 1x D-SUB</font></td>
</tr>
<font face="Arial" size="2">2x DDR3 1333/1066/800 MHz memory modules <br>
</tr>
<font face="Arial" size="2">Realtek ALC887 codec High Definition Audio 2/4/5.1/7.1-channel</font></td>
</tr>
<font face="Arial" size="2">1 x Realtek 8111E (10/100/1000 Mbit) </font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="56">
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="56">
(To support PCI-E Gen3, you must install 22nm CPU / Ivybridge)<br>
</font>3x PCI Express x1 slot</font></p>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="19"><font face="Arial" size="2" color="#0066CC">Storage
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="19">
<p><font face="Arial" size="2">4x SATA 3Gb/s connectors</font></p>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="43"><font face="Arial" size="2">Chipset:
</font> <font face="Arial" size="2">4x on the back panel, 4x via USB brackets
on headers<br>
</font> <font face="Arial" size="2">Etron EJ168 chip: </font> <font face="Arial" size="2">2
USB 3.0/2.0 ports on the back panel</font></td>
</tr>
<font face="Arial" size="2">1 x 4-pin ATX 12V power connector,</font> <font face="Arial" size="2">4
x SATA 3Gb/s connector,</font> <font face="Arial" size="2">1 x CPU fan header,
</font> <font face="Arial" size="2">1 x system fan headers,</font> <font face="Arial" size="2">1
x front panel header, </font> <font face="Arial" size="2">1 x front panel
audio header</font><font face="Arial" size="2">, </font> <font face="Arial" size="2">2</font><font face="Arial" size="2">
x USB 2.0/1.1 headers,</font> <font face="Arial" size="2">1 x clearing CMOS
jumper.</font></td>
</tr>
<font face="Arial" size="2">1 x PS/2 keyboard/mouse port, </font> <font face="Arial" size="2">1
x D-SUB, 1 x DVI,, </font> <font face="Arial" size="2">4x USB 2.0/1.1 ports,
</font> <font face="Arial" size="2">2x USB 3.0/2.0 ports</font><font face="Arial" size="2">,
</font> <font face="Arial" size="2">1 x RJ-45 ports, </font> <font face="Arial" size="2">3x
audio jacks </font> </td>
</tr>
<font face="Arial" size="2">2 x 32 Mbit AWARD BIOS </font> <font face="Arial" size="2">Support
for DualBIOS?</font> </td>
</tr>
Factor</font></td>
<font face="Arial" size="2">Mico ATX Form Factor; 24.4cm x 17.4cm</font>
</td>
</tr>
</tr>
</table>
Was £44.99 Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
Gigabyte 970A-DS3 AMD 970A (Socket AM3+) DDR3 Motherboard @ £56.99 inc VAT
The 970A-DS3 motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via the GIGABYTE 333 onboard acceleration technologies. Featuring the USB3.0 controller, AMD 900 series motherboards allow users to take advantage of super fast USB transfer rates of up to 5Gbps, delivering 10x faster data transfer compared to USB 2.0. Utilizing the industry's first Serial ATA Revision 3.0 solution via AMD SB950 chipset, GIGABYTE AMD 900 series motherboards offer native 6 ports of next generation high speed data storage devices support with data transfer speeds of up to 6 Gbps with RAID 0, 1, 5, 10. The AMD 900 series motherboards introduce a unique hardware design with lower resistance fuses for ensuring lower voltage drops and providing more stable and plentiful power delivery. All USB ports also benefit from a 3x power boost for better power delivery to power hungry USB devices.
• On/Off Charge Technology
• Get Ready for New Generation of 32nm AMD AM3+ CPU
• Supports next generation of 45nm AMD AM3 CPU
• SATA 6 Gbps Support
• USB 3.0 Support
Form Factor: ATX
Graphics Interface: PCIe 2.0 (x16)
CPU Socket: AM3+
SLI: No
QPI Speed: N/A
System Bus: 4800MT/s
Hybrid SLI: No
Chipset: AMD 970
Hybrid Crossfire: No
Memory Type: DDR3
Crossfire: No
Memory Channel: Dual
Water Cooled: No
Memory Type (ECC): Non-ECC
SATA: SATA III - 6Gb/s
Memory Type (R/U): Unbuffered
RAID: SATA
Memory Speed (Mhz): DDR3 - 1066, DDR3 - 1333, DDR3 - 1600, DDR3 - 1866, DDR3 - 2000(OC)
Expansion Slots: 2 x PCI (32 bit), 1 x PCIe 2.0 x16, 1 x PCIe 2.0 x16 (x4 Bandwidth), 3 x PCIe x1
Memory Capacity: 32GB
Internal I/O: 1 x 24pin (V), 1 x 4pin (V), 1 x FP Audio Header, 6 x SATA III - 6Gb/s, 1 x SPDIF-Out Header, 3 x USB 2.0 Header
Graphics On Board: No
Back Panel: 1 x 10/100/1000 (LAN), 1 x Line In, 1 x Line Out, 1 x Mic In, 1 x PS/2 Keyboard/Mouse Combo, 6 x USB 2.0, 2 x USB 3.0
Was £59.99 Inc. VAT
Only £56.99 inc VAT.
ORDER NOW
Gigabyte 78LMT-USB3 AMD 760G (Socket AM3+) DDR3 Motherboard @ £39.95 inc VAT
The 78LMT-USB3 motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via revolutionary GIGABYTE Ultra Durable technology. Based on AMD 760G chipset, the 78LMT-USB3 supports the latest 45nm AMD AM3 Phenom II/ Athlon II processors, integrated DDR3 memory controller, HyperTransport™ 3.0 technology links and PCI Express 2.0 graphics interfaces for ATI Hybrid CrossFireX support. The 78LMT-USB3 is able to provide user friendly computing, reach the maximum system performance easily while still able to save the power and environment in real life at the same time.
GIGABYTE's AMD motherboards are ready to support new generation of 32nm AMD AM3+ multi-core processors, delivering the very best platform for multitasking, multimedia and high performance gaming.
CPU AM3+ Socket:
Support for AMD AM3+ processor
Support for AMD AM3 Phenom™ II processor / AMD Athlon™ II processor
(Please refer "CPU Support List" for more information.)
Hyper Transport Bus
4400 MT/s
Chipset
North Bridge: AMD 760G
South Bridge: AMD SB710
Memory
4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory (Note 1)
Support for 1333+ (O.C.)/1066 MHz memory modules
Onboard Graphics North Bridge:
1 x D-Sub port
1 x DVI-D port, supporting a maximum resolution of 1920x1200 (Note 2)
1 x HDMI port, supporting a maximum resolution of 1920x1200 (Note 3)
Audio
2/4/5.1/7.1-channel (Note 4)
LAN
1 x Realtek GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
1 x PCI Express x1 slot
(All PCI Express slots conform to PCI Express 2.0 standard.)
1 x PCI slot
Storage Interface South Bridge:
1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
6 x SATA 3Gb/s connectors supporting up to 6 SATA 3Gb/s devices
Support for RAID 0, RAID 1, RAID 10, and JBOD
USB South Bridge:
Up to 8 USB 2.0/1.1 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
2 x Etron EJ168 chips:
1 x IDE connector
1 x CPU fan header
1 x parallel port
1 x D-Sub port
1 x DVI-D port
1 x HDMI port
1 x RJ-45 port
3 x audio jacks (Line In/Line Out/Microphone)
I/O Controller
H/W Monitoring
CPU overheating warning
CPU/System fan fail warning
CPU/System fan speed control (Note 5)
BIOS
2 x 16 Mbit flash
Use of licensed AWARD BIOS
PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
Unique Features
Support for @BIOS
Support for Q-Flash
Support for Xpress BIOS Rescue
Support for Download Center
Support for Xpress Recovery2
Support for EasyTune (Note 6)
Support for Smart Recovery
Support for On/Off Charge
Support for Q-Share
Bundle Software
Operating System
Support for Microsoft Windows 7/ Vista/ XP
Form Factor
Micro ATX Form Factor; 24.4cm x 24.4cm
Was £42.95 Inc. VAT
ORDER NOW
Thermaltake Armor Revo Gaming Case - Black/Blue @ £132.98 inc VAT
Gamers and PC enthusiasts have long revered the Thermaltake Armor as an excellent and spacious chassis to house a high performance rig. With the Thermaltake Armor Revo's pure aesthetic gaming design and engineering deliver impressive amount of features that not only looks awesome but also fully integrated as well. From the inclusion of the latest internal USB 3.0 header to the ability to support high-performance 24cm water cooling radiator, the Armor Revo has the best of both world. While many other chassis claims high airflow design by stuffing as many fans into the case as possible, Thermaltake engineers placed three oversized 200mm blue LED fans and a 140mm rear exhaust fan in strategic locations, in addition to the CableClear cable management, to not only improve overall airflow but to prevent airflow blockage as well.
- Dimension (H x W x D): 586 x 254 x 552 mm
- Side Panel: Transparent Window
- Colour: Exterior & Interior : Black
- Material: SECC
- Cooling System: Front (intake) : 200 x 200 x 30 mm Blue LED fan x 1 (600~800rpm, 13~15dBA)
- Rear (exhaust): 140 x 140 x 25 mm Turbo fan (1000rpm,16dBA)
- Top (exhaust): 200 x 200 x 30 mm Blue LED fan (600~800rpm, 13~15dBA) / 140 x 140 x 25 mm or 120 x 120 x 25 mm (optional)
- Side (intake): Plug&Play 200 x 200 x 30 mm fan (600~800rpm, 13~15dBA)
- Bottom (Intake): 120 x 120 x 25 mm (optional)
- Drive Bays: Accessible: 4 x 5.25’’, 1 x 3.5’’ (Converted from one 5.25” drive bay)
- Hidden: 6 x 3.5’’ or 2.5’’
- HDD Docking: 1 x 3.5’’ or 2.5’’
- Expansion Slots: 8
- Motherboards: 9.6” x 9.6” (Micro ATX), 12” x 9.6” (ATX)
- I/O Ports: USB 3.0 x 2, USB 2.0 x 2, eSATA x 1, HD Audio x 1
- PSU: Standard PS2 PSU
- LCS Upgradable: Supports 1/2”?3/8”?1/4” water tube
- Other: CPU cooler height limitation: 180mm / VGA length limitation: 330mm
Was £139.99 Inc. VAT
Only £132.98 inc VAT.
ORDER NOW
Thermaltake Armor Revo Gaming Case - Snow Edition @ £132.98 inc VAT
- Material: SECC
ORDER NOW
Intel Liquid Cooling Solution CPU Cooler (Socket LGA1155 / 1156 / 1366 / 2011) @ £69.98 inc VAT
Intel teamed up with no other than Asetek to offer the Intel RTS2011LC self contained water cooler kit. Asetek have been making these type of kits for a while and was behind the Corsair H50 and H70 as well as the Antec Kuhler 620 and 920.
- Socket LGA1155/LGA1156//LGA1366/LGA2011
- Fan Speed: 800-2200 RPM (4 wire PWM)
- Fan Dimensions: 120 mm x 120 mm x 25 mm
- Fan Airflow: 74CFM
- Unit Noise Level: 21dBA@800 RPM / 35dBA @ 2200 RPM
- Radiator Dimensions: 150mm x 118mm x 37mm
- Pump Z-Height: 33mm
- Total Thermal Solution Weight: 820 grams
- Cooling Liquid: Propylene Glycol
- Thermal Interface Material: TC-1996
Was £73.98 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Thermaltake Armor A30 LAN Gaming Case - Black @ £74.99 inc VAT
This A30 Armor case from Thermaltake is the ideal option for any budding LAN party regular. Small, portable yet about to house powerful gaming rigs then this case is right up your street. Includes new technology such as USB3.0 front support and a windowed side panel.
- Characteristic black bulletproof armor design with metal mesh elements;
- Top and front blue LED fan creates combat ambience and excellent ventilation
- Front I/O with USB 3.0 SuperSpeed Connector
- USB 3.0 x 1, USB 2.0 x 1, eSATA x 1 , HD Audio x 1
- Support for 13" GPU's
- 5.25" Drive Bays: 2
- Ext. 3.5" Drive Bay: 1
- Int. 3.5" Drive Bay: 2 & 2 x 2.5" SSD / HDD
- Expansion Slots: 4
- Front Cooling(intake): 90 x 90 x 25 mm blue LED fan (1200rpm, 16dBA )
- Rear Cooling(exhaust): 60 x 60 x 25 mm fan x 2 (1500rpm,18dBA)
- Top Cooling (exhaust): 230 x 230 x 20 mm blue LED fan (800rpm, 15dBA)
Was £79.99 Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
NZXT KRAKEN X40 AIO Water Cooling Unit - 140mm (Socket 775 / 1155 / 1156 / 1366 / 2011 / AMD AM2 / AM3 / AM3+ / FM1) @ £78.98 inc VAT
NZXT introduces the Kraken series, the first premium all-in-one water coolers for PC enthusiasts. The Kraken X40 is a high-end 140mm water cooling solution where ease of use meets functionality. Included is one NZXT FX-140 PWM fan, with capacity to install an additional in a push-pull configuration for unrivaled cooling performance. At the core of the cooler is a state-of-the-art pump attached to an all copper base. Bridging the radiator and pump are extra-long 16” tubing and premium sleeved cables, allowing Kraken X40 to be easily installed into even the largest chassis. We developed the Kraken series to be the best closed loop water cojolers on the market. Our customers should not settle for anything less.
• World's first all-in-one 140mm cooler with capacity to mount up to two 140mm fans
• High performance pump and copper block with interactive digital fan control
• Integrated HUE controlled LED pump cap
• Large tower support with extended 16" tubing and premium black sleeved cables for a clean look and improved airflow
• Completed sealed system backed by a 2 year warranty
• Material - Copper
• Pump Motor Speed: 2900 + 150 RPM
• Voltage: 12V
• Current 175 mA
• Fan Control: Interactive Digital Fan Control
• LED Color: Hue Controlled Color Changing Lights
• Fan Model: NZXT FX-140
• Dimension: 140 x 140 x 25 mm
• Speed: 800 - 2000 RPM + 10%
• Noise: 21 - 37dBA
• Voltage: 4.5 - 12V
• Air Flow : 54 - 98.3 CFM
• Air Pressure: 0.8 - 2.2 mm-H2O
• Connector: 4 Pin PWM
• Radiator Dimension: 138.4 x 27.0 x 172.5mm
• Material: Aluminum
• Tube Length: 400 mm
• Material: Rubber
Was £84.98 Inc. VAT
Only £78.98 inc VAT.
ORDER NOW
Thermaltake Chaser A31 Gaming Windowed Case - Black/Blue @ £76.98 inc VAT
The new Thermaltake Chaser A31 gaming case designed for computer gamers and enthusiasts that deliver a combination of cooling, performance and expandability any full tower features within this ultra-mean case. It has an e-sports appearance and outstanding protection designs that characterize a unique personality. Take a look at the side, the transparent windowed panel offers the best inner view for built system see through. Since gaming hardware produces a lot of heat, therefore this enclosure is built for maximum cool with a perforated front bezel with two 120 mm fans at front and rear. The two USB 3.0 SuperSpeed ports are located on front panel for faster data transfer and easy access. There's even an user friendly tray on top for mobile, mp3player, digital camera have lying around. The Chaser A31 is maximally customizable to fit user’s needs; the modular design lets you modify the placement of the front fans and hard drive cages. Get ready to be envied at the next LAN party.
- Dimension (H x W x D): 501 x 212 x 495mm
- Front Cooling: (intake) : 120 x 120 x 25 mm Turbo fan x 1 (1000rpm, 16dBA) / 120 x 120 x 25 mm (optional)
- Rear Cooling: (exhaust): 120 x 120 x 25 mm Blue LED fan (1000rpm,16dBA)
- Top Cooling (exhaust): (optional) 120 x 120 x 25 mm fan x 2 or 140 x 140 x 25 mm fan x 2
- Bottom Cooling(Intake) : (optional) 120 x 120 x 25 mm fan
- Drive Bays: Accessible: 3 x 5.25’’ , 1 x 3.5’’ (Converted from one 5.25” drive bay) / Hidden: 6 x 3.5’’ or 2.5’’
- Expansion Slots: 7
- Motherboard Support: 9.6” x 9.6” (Micro ATX), 12” x 9.6” (ATX)
- I/O Ports: USB 3.0 x 2, HD Audio x 1
- PSU: Standard PS2 PSU (optional)
- CPU cooler height limitation: 160mm
- VGA length limitation: 290mm(with HDD rack) / 410mm(without HDD rack)
Was £79.99 Inc. VAT
Only £76.98 inc VAT.
ORDER NOW
Prolimatech Magnetic Fan Pins (4pack) - Blue @ £3.60 inc VAT
These magnetic pins allow you to fix you fans to your chassis without the presence of vibration noises that normal screws provide.
- Material: Rubber / metal
- Color: Blue
- Contents: 4 magnetic rubber pins in storage box
- Compatibility (fan): without continuous web of the mounting holes
- Compatibility (housing): material: ferromagnetic (eg steel, nickel)
Was £3.95 Inc. VAT
Only £3.60 inc VAT.
ORDER NOW
Thermaltake Element Q mini-ITX HTPC Case - 220W Power Supply @ £51.98 inc VAT
This mini-ITX desktop or HTPC chassis is made from steel inside and out, and the front is capped with black plastic that houses the signature Element red trim. The outside of the entire chassis is black while the inside is left exposed. In the front there is room for a full sized 5.25" optical drive above a slot for either an internal 3.5" drive or it can be used to install a floppy drive externally. Below these you find the front I/O panel behind a cover with a press to release lock. Once the panel is open it will expose the connectivity for the two USB 2.0, MIC, and headphone jacks.
- Case Type: Mini Case
- Material: Steel
- Front Bezel Material: Plastic
- Motherboard Support: Mini ITX
- 5.25" Drive Bays: 1
- Int. 3.5" Drive Bay: 1
- Expansion Slots: 1
- Front I/O Ports: USB 2.0 x 2 / HD Audio
- Power Supply Supported: SFX
- Power Supply Included: 200W SFX Power Supply
- Dimensions: 64.07mm H x 125.53mm W x 100.29mm
Was £56.99 Inc. VAT
Only £51.98 inc VAT.
ORDER NOW
Thermaltake Commander Snow Edition Midi Tower Case - Black/White @ £43.98 inc VAT
The Commander MS-I Snow Edition is equipped with extra-long VGA support which will hold some premium weapons (graphic cards) in the market, such as nVidia GTX590 and AMD Radeon HD6990 with ease, cable management and 12cm blue LED fan to enhance air mobility (ventilation), USB2.0 and USB 3.0(internal 19pin) front I/O slots allow direct data transfers during combat situation, and 9 drive bays grant with maximum magazine (HDD, optical drives) storability so you will never run out of resources!
- Case Type: Middle Tower
- Net Weight: 4.5 kg / 9.9 lb
- Dimension (H x W x D): 426.0 x 202.0 x 484.0 mm (16.8 x 8.0 x 19.1 ) inch
- Front Cooling (Intake): 120 x 120 x 25 mm (optional)
- Rear Cooling (Exhaust): 120 x 120 x 25 mm Blue LED fan, 1000rpm, 16dBA
- Top Cooling (Exhaust): 120 x 120 x 25 mm (optional)
- Bottom Cooling (Intake): 120 x 120 x 25 mm (optional)
- Drive Bays: Accessible: 3 x 5.25’’, 1 x 3.5’’ / Hidden: 5 x 3.5’’, 1 x 2.5”
- Motherboards: Micro ATX / Standard ATX
- I/O Ports: USB2.0 x 1, USB3.0 x 1, MIC & Speaker (support AC’97 & HD Audio)
Was £46.99 Inc. VAT
Only £43.98 inc VAT.
ORDER NOW
"Titan 8700i Pulse" Intel Core i5 3570K 3.40GHz @ 4.40GHz DDR3 Ivybridge Gaming PC @ £608.98 inc VAT
Get ready to game with the "Titan 8700i Pulse"! Featuring the Intel Core i5 3570K overclocked to a ridiculous 4.40Ghz, you can enjoy ultra smooth framerates and an immersive computing experience. With a the latest DX11 graphics cards, equip yourself ready for the game ahead. With a massive 500GB hard drive you will never run out of space for your essential data. 8GB of memory provides a smooth computing experience, the "Titan 8700i Pulse" is finished off with the fantastic range of gaming cases to choose from.
Why You Should Buy This System
- A guaranteed 4.40GHz performance for the price of 3.40GHz
- Cinematic DX11 graphics
- Precision built and cabled by Overclockers UK expert technicians
- 8 Hours stressed tested and quality controlled
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
- All systems with an Windows 7 selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012. Not compatible with Windows 8.
System Specification
- Case: Xigmatek Alfar Midi Tower Windowed Case - Black/White (default choice, options available)
- Power Supply: Corsair GS 600w PSU
- CPU: Intel Core i5 3570K 3.40GHz @ 4.40GHz Ivybridge CPU
- Motherboard: Asus P8Z77-V LX2 Intel Z77 (Socket 1155) DDR3 Motherboard
- Cooler: Corsair H60 Water Cooler CPU Cooler
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 500GB HDD
- Graphics Card: ATI Radeon HD 5450 SILENT 512MB (default choice, options available)
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 24x DVD+/-RW SATA Drive
- Wireless: Asus USB-N10 Micro USB Network Adapter Wireless-N 150Mbps
Service Package
- Full 24 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Immense overclocks, powerful graphics and sleek hardware all combine to create the "Titan 8700i Pulse", perfect for the gaming enthusiast.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow 7 working days for your system to be built and configured. This may take longer during busier periods.
*Fast track service subject to current stock levels during busier periods.
Was £659.98 Inc. VAT
Only £608.98 inc VAT.
ORDER NOW
Thermaltake Level 10 GT Visionary Full Tower Case - Black @ £199.98 inc VAT
Following the high-profile launch of Level 10 Super Gaming Modular Case, the design collaboration between Thermaltake and BMW Group DesignworksUSA, in 2009, Thermaltake looks to invigorate the PC enthusiasts with the latest Level 10 GT computer case. The design language of the Level 10 GT expresses a passion for visual aesthetics deriving from demanding and immersive game play and multimedia entertainment enthusiasm. Modern games and entertainment applications also require highly advanced hardware configurations, which at the same time request more space and optimized ventilation than conventional hardware. With EasySwap Pitstop 5 every HDD/SDD has its own removable tray, EasySwap in hot-plug mode within seconds. With this users have greatest storage flexibility and maximum data transfer speeds you need. Modern multimedia peripherals operate at tremendous data transfer velocities, with 2 USB 3.0 connectors right on the top of the Level 10 GT you be guaranteed to always enjoy SuperSpeed entertainment. The concept of the clear lines of the outside design of the Level 10 GT is just as well continued in the inside. An advanced and highly convenient cable management bundles respective cables almost like in tunnels behind a back plate. Your system shines in clarity, easy access to all components is warranted for and even ventilation is greatly improved. High tech components are prone to heat impacting longevity and performance. For this vital reason the implementation of Thermaltake's QuadFan (of which three also feature ColorShift) Ventilation concept creates an ideal environment for your components to unfold their full potential. Perception of what and how it is surrounding us, can have strongly inspiring, motivating and vitalizing effects on us. With triple ColorShift three LED fans with five sets of illuminations let you get into the driver seat of your respective moods. Or if so wanted, you turn them all entirely. At times enthusiasm may push you to the ultimate limits, to where you have not been before. Particularly for those who are bound to go beyond these restrictions, i.e. tune and clock your setting, further measures to keep the heat down might be asked for. Ready for Liquid Cooling Systems you can rest assured to keep your coolness. Powerful performance needs space to unfold, this is also the case for highly advanced graphics cards, which the length has grown considerable over the past years and is most likely to grow even further in the future. With space for up to 37 cm oversized cards, there is sufficient space to stay future proof.
- Performance cooling made quiet: one top 200mm exhaust fan, one front 200mm intake fan, one side 200mm intake fan and one rear 140mm exhaust fan.
- Hinged side panel to enable easier opening of the side door and access to computer for maintenance or upgrade.
- Dramatically improved cable management. User no longer "hides" the excessive cable on the back, the Level 10 GT features numerous holders designed into the chassis for cable management.
- Five hot-swappable hard drive bays, each with its dedicated backplane to support hot-swap. Hard drive mounting supports both 2.5" or 3.5" drives.
- Connectivity array. Four USB 2.0 ports are conveniently located on the front bezel including a pair of audio ports. Two USB 3.0 ports and one eSATA port located on the top.
- Water cooling ready - 120mm or 240mm radiators can be easily attached to the top side of the chassis (top 200m fan needs to be removed)
- Fan speed management control embedded. ColorShift fans can be easily controlled through controls on the top.
- Fully black-powdered interior.
Was £209.99 Inc. VAT
Only £199.98 inc VAT.
ORDER NOW
Thermaltake Level 10 GT Visionary Full Tower Case - White 'Snow Edition' @ £209.99 inc VAT
Was £219.98 Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
Thermalright Archon SB-E X2 CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £55.19 inc VAT
Ever since the introduction of the first Archon “Slim Tower Heatsink” back in 2010, Thermalright has never stopped improving on its own design. Incorporating our new proprietary Pressure Vault Bracket System we introduce to the world the all new Archon SB-E X2. Aside from a total overhaul and upgrade of the mounting bracket system, the Archon SB-E X2 will be using two TY-141 high efficient double ball bearing silent fans, giving enthusiasts the perfect mash-up of performance, compatibility and silenceEver since the introduction of the first Archon “Slim Tower Heatsink” back in 2010,
Incorporating our new proprietary Pressure Vault Bracket System we introduce to the world the all new Archon SB-E X2. Aside from a total overhaul and upgrade of the mounting bracket system, the Archon SB-E X2 will be using two TY-141 high efficient double ball bearing silent fans, giving enthusiasts the perfect mash-up of performance, compatibility and silence!
The Archon SB-E X2 inherits the same award wining heatpipe design from the Archon SB-E. Eight 6mm sintered copper heatpipes along with a massive 170mm x 150mm heatsink footprint allows the pipes to equally disperse heat from the CPU to the heatsink fins, so no bit of airflow is left to waste! Archon SB-E X2’s Slim Tower design is only 53mm across. This allows the Archon SB-E X2 to be fully compatible with RAM of all kinds, so power users are free to fill their RAM slots with high-end overclocked RAM.
Premium performance is only the beginning when it comes to Thermalright products. Silence is equally important, so striking a balance with performance is key. The Archon SB-E X2 comes with two TY-141 140mm silent fans. The TY-141 utilizes Thermalright’s new Silent Torpedo fin design, delivering a massive 73.6 CFM for only 21dBA of silence! The Archon SB-E X2 is Silence and Performance done right, brought to you only by Thermalright!
• Heatsink Dimensions : L155 mm x W53 mm x H170 mm
• Weight : 775g (Heatsink Only)
• Heatpipes: Eight 6mm Copper Heatpipes
• Copper Base: C1100 Pure Copper Mirror Finished base with Nickel Plating.
Was £59.99 Inc. VAT
Only £55.19 inc VAT.
ORDER NOW
Thermaltake Level 10 GTS Gaming Case - Black @ £84.98 inc VAT
The highlight of Thermaltake cases are Level 10 GTS, a mid-tower of pedigree with the innate aesthetics and dynamic mechanism, inherited the unique characteristic of its predecessors Level 10 and Level 10 GT. It has equipped with two internal Superspeed USB 3.0 front ports, four EasySwap HDD bays and HDD security system to advance data management, advanced cable management, excessive ventilation options with built-in dust filters offer a clutter-free and dust-free environment, and last but not the least tool-free drive locking devices and combat headset holder grant instant accessibility and a clean surrounding. To deliver the best gaming experience in all respects, the special edition “Level 10 GTS Battle Dragon” is proven to be a member of the royal family and ready to take on any challenge for enthusiasts under all kind of situation with the Battle Dragon mark on their case! The Battle Dragon has sanctified Level 10 GTS with a powerful and ferocious Battle Dragon totem on the side panel for its purity of ancestry.
- 5.25" Drive Bay: 4
- Int. 3.5" Drive Bay: 1x internal (also fit 2.5")
- 4x Easy Swap Bays (Also fit 2.5")
- Front I/O Ports: USB3.0 X 2 / USB2.0 X 2 / Audio port
- Top Cooling (Exhaust): 200 x 200 x 30 mm fan x1 or 120 x 120 x 25 mm fan x2
- Rear Cooling (Exhaust): 120 x 120 x 25 mm Blue LED Fan
- Front Cooling (Intake): 200 x 200 x 20 mm blue LED fan
- Bottom Cooling (Intake): 120 x 120 x 25 mm fan
- Side Cooling (Intake): 200 x 200 x 30 mm fan x 1 or 140 x 140 x 25 mm fan x 1
Was £89.99 Inc. VAT
Only £84.98 inc VAT.
ORDER NOW
Thermaltake Level 10 GT Visionary Full Tower "Battle Edition" Case - Army Green @ £209.99 inc VAT
ORDER NOW
"Primo 6100i" Intel Core i3 2120 3.30GHz DDR3 Dual Core System @ £305.99 inc VAT
The "Primo 6100i" features a Intel Core i3 2120 3.30GHz processor seamless multi-tasking capabilities which is perfect for home/office use. Awesome power contained within a small chassis the "Primo Ignition" has the option to upgrade to one of many of the latest Low Power, energy efficient Nvidia series graphics cards for extra graphical punch. Utilising Hyper threading technology the "Primo Ignition" makes short work of video encoding and multitasking.
Why You Should Buy This System?
- Intel Core i3 2120 3.30GHz (Clarkdale) Processor with Hyperthreading technology for 4 Virtual cores
- 500GB Hard drive gives massive storage capacity including DVD Re-Writer Make this system perfect for data backup
- Case: IMP microATX Case
- Power Supply: OcUK 500W PSU
- CPU: Intel Core i3 2120 3.30GHz (Clarkdale) Dual Core CPU
- Motherboard: Gigabyte H61MA-D2V Intel H61 (Socket 1155) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- RAM: 4GB or 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: Seagate Barracuda 7200.12 1TB SATA 6Gb/s 64MB Cache HDD
- Graphics Card: Onboard Intel GMA graphics or a choice of energy efficient graphics cards
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: OcUK 24x DVD+RW SATA ReWriter
- 802.11N Wireless Network Adapter
Service Package
With multiple video outputs, compact size and advanced hyperthreading technology the "Primo 6100i" is perfect for the user looking for a highperformance system for a low price.
Was £335.99 Inc. VAT
Only £305.99 inc VAT.
ORDER NOW
Thermaltake Level 10 GTS Gaming Case - Snow Edition @ £84.98 inc VAT
Was £89.99 Inc. VAT
ORDER NOW
Thermaltake Soprano Tower Case - White @ £94.98 inc VAT
The classic case from Thermaltake; The Soprano was brilliant back in its hey-day. However Thermaltake have decided to rejuvenate it by releasing a new and up to date refreshed version. This case has all the brilliance of the original but includes newer features and design.
- Case Type: Mid Tower
- Dimension (H x W x D): 460 x 220 x 510 mm (18 x 8.7 x 20 inch)
- Colour: Exterior & Interior : Black & White
- Material: SECC
- Front Cooling: 200 x 200 x 20 mm Blue LED fan x 1 (600rpm, 13dBA)
- Rear Cooling: 120 x 120 x 25 mm Turbo fan (1000rpm,16dBA)
- Bottom Cooling: 120 x 120 x 25 mm
- Hidden: 5 x 3.5’’ or 2.5’’
- I/O Ports: USB 3.0 x 2, USB 2.0 x 2, HD Audio x 1
- LCS Support: 1/2” / 3/8” 1/4” water tube
- Other: CPU cooler height limitation: 175mm / VGA length limitation: 315mm
Was £109.99 Inc. VAT
Only £94.98 inc VAT.
ORDER NOW
Thermaltake Soprano Tower Case - Black @ £94.98 inc VAT
- Material: SECC
ORDER NOW
Thermaltake V3 "BlacX Edition" Midi Tower Case - Black @ £42.98 inc VAT
The new V3 BlacX Edition chassis is designed with the goal of offering more to the advocates who have excessive data to manage and required more than a stand chassis for daily usage but still keeping it within the means. With that initiative in mind, we used the V3 Black Edition chassis by adding our BlacX docking station to accomplish the goal. The BlacX docking station enhanced the original V3 Black Edition chassis data management ability and kept all the great functionality of the V3 Black Edition chassis. The new V3 BlacX Edition chassis is a mid-tower that will accommodates all ATX or ITX motherboards, three 5.25” and one 3.5” bays accessible from the front, and further four 3.5” and one 2.5” bays are accessible from the inside built with a modern all black interior and exterior design. The external Superspeed USB 3.0 and the top-mounted HDD docking station, provide a trouble-free environment and convenience data management for the advocates. Moreover, the bottom based PSU mount and metal mesh front bezel with dust filter, plus the option for 3 additional case fans: the front panel allows to add a 120 mm intake fan, the top panel offers the possibility to install a 120 mm exhaust fan and on the bottom is room for yet one more intake fan to optimize ventilation.
- Net Weight: 4.8 kg / 10.6 lb
- Dimension: D473.0 x W190.0 x H445.6 mm
- Front Cooling (Intake) : 120 x 120 x 25 mm (optional)
- Drive Bays: External: 3 x 5.25’’, 1 x 3.5’’
- Hidden: 4 x 3.5’’, 1 x 2.5”
- HDD Docking: 1 x 3.5” or 1 x 2.5”
- Material SECC
- Expansion Slots 7
- Motherboard Support: Micro ATX & Standard ATX
- I/O Ports: USB3.0 x 1, USB2.0 x 1, MIC & Speaker (support AC’97 & HD Audio)
Was £46.99 Inc. VAT
Only £42.98 inc VAT.
ORDER NOW
Thermalright True Spirit 140 CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £33.59 inc VAT
Ultra style heatsink fin array, with copper base, elevates heatsink’s overall quality. Large heatsink fin array, provides dissipating area of up to 150*125mm, make complete use of the airflow, with 140mm or 120mm fan. With the max width of 55mm, tall memory spreaders are no issue. The cooler is supplied with one Thermalright TY-140 PWM fan, ultra low noise at 21 dBA at max rpm (50cm testing distance)
Fan-clips are compatible with both 140mm and 120mm fan.
Heatsink Specifications:
- Dimension: Length 155mm x Width 53mm x Height 170mm
- Weight: 771g (including fan and pads. excluding mounting brackets)
- Heatpipe: 6mm heatpipe*6 units
- Copper Base: C1100 Pure copper nickel plated with mirror shine
Fan Specification:
- Dimension: L160mm x H140mm x W26.5mm
- Weight: 140g
- Fan speed: 900~1300RPM (PWM controlled)
- Fan noise: 19~21dBA
- Airflow: 56~73CFM
- Connector: 4 Pin (PWM Fan connector)
Was £39.95 Inc. VAT
Only £33.59 inc VAT.
ORDER NOW
Noiseblocker BlackSilent Pro Fan PM2 - 40mm @ £8.40 inc VAT
Noiseblocker is the number one specialist for quiet fans. To achieve this, the company relies on maximum quality with low and high manufacturing tolerances, technological know-how and advanced German engineering.
In addition, the Noiseblocker prides itself on quoting technical specifications at realistic values.
The mounting system of the fan is very refined and minimizes vibration transfer. Here, a large silicon frame provides a reduced volume.
Even the cables have been thought about, Noiseblocker has come up with something special. 20cm and 50cm sleeved cables are included in the package meaning you have maximum control over cable management. Connection is via 3-pin.
Technical details:
Dimensions: 40 x 40 x 25 mm
Volume: 17.7 dB (A)
Speed: 3,800 r / min
Airflow: 9,2 m³ / h
Starting voltage: 5 V
Operating voltage: 5 - 13.2 V
Power consumption: 0.81 W
Connector: 3-pin (20 +50 cm cable)
Life expectancy: 100,000 hours
Warranty: 6 Years
Was £8.99 Inc. VAT
Only £8.40 inc VAT.
ORDER NOW
Noiseblocker Multiframe S-Series M8-S3 HS Fan - 80mm @ £10.80 inc VAT
The Multiframe S series made by (((Noiseblocker)))®, which is generally recognised as the reference standard, is the first fan with a vibration-free fan frame and incorporates numerous other improvements, so that it is superior to standard fans in almost all aspects.
In conjunction with the unique (((Noiseblocker)))® technology, our almost noise-free NB-NanoSLI® bearing and the NB-EKAPlus II drive, the NB-Multiframe® S series currently represents the best that German engineering expertise has to offer. Quality you can rely on!
- Dimensions: 80x80x25mm
- Noise Level: 19dbA
- RPM: 2200rpm
Was £11.99 Inc. VAT
Only £10.80 inc VAT.
ORDER NOW
Noiseblocker Multiframe S-Series M8 S1 - 80mm @ £10.80 inc VAT
- Noise Level: 6dbA
- RPM: 1200rpm
Was £11.99 Inc. VAT
ORDER NOW
Noiseblocker BlackSilent Pro Fan P-1 - 80mm @ £10.80 inc VAT
Technical details:
Dimensions: 80 x 80 x 25 mm
Volume: 15.4 dB (A)
Speed: 1,500 r / min
Airflow: 29,3 m³ / h
Life Expectancy: 160,000 hours
Warranty: 6 Years
Was £11.99 Inc. VAT
ORDER NOW
Noiseblocker BlackSilent Pro Fan PE-1 - 92mm @ £9.60 inc VAT
The high-quality NB-EKA Plus II drive and the almost noiseless NB-NanoSLI bearings guarantee operating noise levels which are particularly low over the long term - both equipment features which until now have only been used as part of the costlier Multiframe Reference series.
In addition to the tasteful design in matte black and mirror finish, the BlackSilentPro fans are equipped with an individually extendable cable management system and an NB-Silentframe silicone seal and installation material for vibration-free assembly without tools.
- Dimensions: 92x92x25mm
- Noise Level: 14dbA
- RPM: 1300rpm
Was £9.98 Inc. VAT
Only £9.60 inc VAT.
ORDER NOW
Noiseblocker Multiframe S-Series M12-S2 Fan - 120mm @ £15.60 inc VAT
- Dimensions: 120x120x25mm
- RPM: 1250rpm
Was £15.98 Inc. VAT
Only £15.60 inc VAT.
ORDER NOW
Noiseblocker Multiframe S-Series M12-S3 HS Fan - 120mm @ £15.60 inc VAT
- Noise Level: 27dbA
- RPM: 1800rpm
Was £15.98 Inc. VAT
ORDER NOW
Noiseblocker Multiframe S-Series M12-P Fan - 120mm PWM @ £15.60 inc VAT
- Noise Level: 29dbA
- RPM: 2000rpm
Was £15.98 Inc. VAT
ORDER NOW
Noiseblocker BlackSilent Fan XLP Fan - 120mm PWM @ £7.20 inc VAT
The fact that good quality does not have to be expensive is shown by the third version of the NB-BlackSilentFan series. The well-balanced properties of this bestseller make this inexpensive and high-quality series of fans the absolute bestseller throughout the world.
Our least expensive series of fans moves in such high circles, however, that other producers come off worse in direct comparisons even with their considerably more expensive "high-end" fans.
- Noise Level: 31dbA
- RPM: 2000rpm
Was £7.99 Inc. VAT
Only £7.20 inc VAT.
ORDER NOW
Noiseblocker NB-eLoop Fan B12-1 - 120mm @ £13.20 inc VAT
Noiseblocker already have the largest range of fans aiming to be the quietest on the market.
Noiseblocker eLoop fans are designed to reduce as much frame vibration as possible to avoid resonation being transferred into the chassis.
The most striking feature of the Noiseblocker eLoop fan is a completely new wing design that makes noise levels in the air stream even quieter. This allows the use of a directed air flow with less wasted air flow.
The new fans are based on the research findings of Dr. Rudolf Bannasch Bionikers, who has developed his research with the basic principles of the rotor loop. The new technology has been in development for the past two years, then brought to the development laboratory at Noiseblocker.
Technical details:
B12-1 : 800rpm, 7.83 dBA, 57.3 m³/h
Dimensions: 120 x 120 x 25 mm
Noise level: max. 7.83 dB (A)
Speed: max. 800 r / min
Airflow: max. 57.3 m³ / h
Starting voltage: 5.4V
Power consumption: 0.33 W
Connector: 3-pin
Warranty: 6 Years
Was £13.99 Inc. VAT
Only £13.20 inc VAT.
ORDER NOW
Noiseblocker BlackSilent Fan XK2 - 140mm @ £8.40 inc VAT
- Dimensions: 140x140x25mm
- RPM: 1100rpm
Was £8.99 Inc. VAT
Only £8.40 inc VAT.
ORDER NOW
Noiseblocker BlackSilent Pro Fan PK3 - 140mm @ £14.40 inc VAT
- RPM: 1700rpm
Was £14.99 Inc. VAT
Only £14.40 inc VAT.
ORDER NOW
Z77 Gamer PRO Intel Core i7 3770K 3.50GHz @ 4.40GHz DDR3 Ivybridge Overclocked Bundle @ £549.95 inc VAT
Designed by experts the "Z77 Gamer PRO OC Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Z77 Gamer PRO OC Bundle" offers you value and performance in perfect combination.
Why You Should Buy This Bundle?
- Prebuilt and configured. Just "plug and play"
- Quad core, hyperthreading Intel Core i7 3770K overclocked to 4.50GHz!
- 16GB of Dual Channel DDR3 memory delivers fast load times
- Intel Z77 Chipset for future proof computing
Bundle Specification
- CPU: Intel Core i7 3770K 3.50GHz @ 4.40GHz Quad Core CPU
- Motherboard: Asus P8Z77-V (Socket 1155) DDR3 Motherboard
- RAM: Patriot Intel Extreme Masters 16GB DDR3 1600MHz Dual Channel
- Cooler: Prolimatech Megahalems CPU Cooler - Black w/x2 120MM Zaward Golf III Fans
Service Package
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £594.95 Inc. VAT
Only £549.95 inc VAT.
ORDER NOW
Prolimatech PK-1 Nano Thermal Compound (1g) @ £0.83 inc VAT
The Prolimatech PK-1 Nano Aluminium Thermal Compound is thermal compound that is entirely environmentally safe and recyclable. Even with that being said it is at the head of the pack as far as performance, and is very easy to apply.
- Excellent long-term stability
- Non-electronically conductive
- Non-corrosive
- Easy to apply and less to use
- No "burn-in" time required
- Low dry-out
Was £1.99 Inc. VAT
Only £0.83 inc VAT.
ORDER NOW
Prolimatech PK-2 Nano Aluminium Thermal Paste - 5g @ £7.20 inc VAT
When putting down, nothing beats smooth and easy. That is why we created the PK-2 thermal compound. The PK-2 thermal compound is a high performance thermal bonding agent specially designed for easy application.PK-2's core feature is its low viscosity, allowing for one to quickly and easily apply the thinnest coat of thermal compound possible.This will get your components up close and personal in no time.
• Easy Application
• Easy Application
• Low Dry-Out
• Non-Corrosive
• Electrically Non-Conductive
• Wide range of application temperature
One Syringe of thermal compound amd one easy-to-spread spoon
Was £7.49 Inc. VAT
Only £7.20 inc VAT.
ORDER NOW
Prolimatech PK-3 Nano Aluminium Thermal Paste - 1,5g @ £3.60 inc VAT
Like two hot lovers, a heatsink and the processor want to make full contact. But microscopic imperfections in their craftsmanship create small gap for air. These gaps act as thermal insulators, inhibiting the transfer of thermal energy from your components. PK-3 thermal compound is made up of specially designed nano particles, engineered to correct these imperfections. The nano particles work by filling in the small air gaps and allowing for peak transfer of heat away from your components.
• High Thermal Conductivity
• Low Thermal Resistance
• Long-Term Stability
• Non-Corrosive
• Non-Corrosive
• No "burn-in" time required
One syringe of thermal compound and one easy-spread card
Was £4.50 Inc. VAT
Only £3.60 inc VAT.
ORDER NOW
XSPC K2 Thermal Compound 1.5g @ £4.80 inc VAT
High performance thermal compound for CPU and GPU water blocks.
- Thermal Conductivity = >4.0 W/mK
- Thermal Impedance = < 0.185 C-in2/W
- Viscosity at 25C = 76 CPS
- 1.5g Tube
Was £4.99 Inc. VAT
Only £4.80 inc VAT.
ORDER NOW
Corsair Vengeance 2000 Wireless 7.1 Professional Gaming Headset @ £105.98 inc VAT
Corsair Vengeance™ 2000 delivers the clutter-free freedom of wireless, high-quality 5.1/7.1 surround sound technology, superior audio fidelity, and a comfortable design. Experience true wireless freedom with up to 40 feet of range and 10 hours of battery life. Optimized HRTF technology provides precise positional audio cues for an incredibly immersive gaming experience. Large 50mm audio drivers have been painstakingly tuned for tight bass response - so lows are greatly enhanced without being distorted. Noise-cancelling mic prevents background sounds from interfering with VOIP chat. Large, sound-isolating circumaural earcups have microfiber-covered memory foam earpads. Padded headband stays comfortable over long play sessions.
Free yourself
Experience wireless freedom with up to 40 feet of range and 10 hours of battery life
Optimized HRTF positional audio technology
Experience immersive multi-channel gaming the way it was intended
50mm audio drivers and high-sensitivity noise cancelling mic
High bandwidth audio quality and clear in game chat
Large diameter, circumaural earcup design
Blocks distracting sounds and keeps your head in the game
Comfortable microfiber covers and memory-foam pads
Ear pads that provide improved comfort and conform to the shape of your head
Was £114.98 Inc. VAT
Only £105.98 inc VAT.
ORDER NOW
Logitech G930 7.1 Surround Sound Wireless USB Headset @ £120.00 inc VAT
Level up without being tied down. Gaming-grade wireless gives you a lag-free, interference-resistant connection with a range of up to 12 metres (40 feet) - so nothing stands between you and victory. 7.1 surround sound powered by Dolby technology delivers a detailed, positional soundfield that lets you hear your opponents before they see you. You'll have total command over music, voice morphing, chat clients and more with three programmable G-keys. And a memory foam-lined headband fends off fatigue, while plush ear pads ease pressure points and seal out unwanted noise.
- Gaming-grade wireless performance
- 7.1 surround sound
- Three programmable G-keys
- Memory foam-lined headband
- Noise-cancelling microphone
Was £129.98 Inc. VAT
Only £120.00 inc VAT.
ORDER NOW
Roccat Kave 5.1 Surround Sound Analog Gaming Headset @ £60.00 inc VAT
nonl2br
<br>
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels. <br>
<br>
- Real 5.1 Surround sound with speakers aligned at a 12° angle<br>
- Microphone with mute LED fully rotatable and completely removable<br>
- Tip’N’Control desktop remote for central management of all volume functions<br>
- Dual sound-profile with movie and game settings<br>
- Solid aluminium hinges enabling heavy duty use<br>
- Hand-sewn comfortable earcups featuring external noise cancelling<br>
- Adjustable vibration unit for a realistic gaming experience <br>
- Headband with three pads for equal weight distribution<br>
- Easy to carry folding and compact design <br>
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/125bfd1f2f2cc9251cc512dfde5e4fb1.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/f620e869ce025933aeef18e4d0fd3894.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/798d360d6701787365c7266f8cf96fbe.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/48545abd6c12c63d38c082c343da0099.jpg">
<br>
<script type="text/css">
#youtube {
float:right;
margin-left: 50px;
</script>
<div id="youtube">
<iframe width="640" height="390" src="http://www.youtube.com/embed/yEyXafzsrB0" frameborder="0" allowfullscreen></iframe>
</div>
Was £65.99 Inc. VAT
Only £60.00 inc VAT.
ORDER NOW
Enermax Platimax 750w '80 Plus Platinum' Modular Power Supply (EPM750AWT) @ £159.98 inc VAT
The Enermax Platimax 750W is a High-performance power supply topology which uses all magnetic quadrants of the main transformer to achieve maximum efficiency and rock stable output voltage. It features Innovative and patented transmission technology for direct voltage transmission to reduce the wire-resistance and to increase the efficiency.
- 80 Plus Platinum
- Dynamic Hybrid Transformer Topology
- Copper Bridge Array
- Multi Rail Design
- Special OC Edition
- Future ready and flexible
- Full Modular Cable Management
- Fit4Server
- DX 11 Ready
- HeatGuard
- CordGuard
- SafeGuard
- High Quality Japanese Capacitors
- 5 Year Warranty
Was £172.99 Inc. VAT
Only £159.98 inc VAT.
ORDER NOW
Enermax Platimax 850w '80 Plus Platinum' Modular Power Supply (EPM850AWT) @ £182.99 inc VAT
The Enermax Platimax 850W is a High-performance power supply topology which uses all magnetic quadrants of the main transformer to achieve maximum efficiency and rock stable output voltage. It features Innovative and patented transmission technology for direct voltage transmission to reduce the wire-resistance and to increase the efficiency.
- 80 Plus Platinum
- Multi Rail Design
- Fit4Server
- DX 11 Ready
- HeatGuard
- CordGuard
- SafeGuard
- 5 Year Warranty
Was £192.98 Inc. VAT
Only £182.99 inc VAT.
ORDER NOW
Enermax Platimax 1000w '80 Plus Platinum' Modular Power Supply (EPM1000AWT) @ £229.98 inc VAT
The Enermax Platimax 1000W is a High-performance power supply topology which uses all magnetic quadrants of the main transformer to achieve maximum efficiency and rock stable output voltage. It features Innovative and patented transmission technology for direct voltage transmission to reduce the wire-resistance and to increase the efficiency.
- 80 Plus Platinum
- Multi Rail Design
- Fit4Server
- DX 11 Ready
- HeatGuard
- CordGuard
- SafeGuard
- 5 Year Warranty
Was £241.99 Inc. VAT
Only £229.98 inc VAT.
ORDER NOW
Enermax Platimax 1500w '80 Plus Platinum' Modular Power Supply (EPM1500AWT) @ £264.98 inc VAT
The Enermax Platimax 1500W is a High-performance power supply topology which uses all magnetic quadrants of the main transformer to achieve maximum efficiency and rock stable output voltage. It features Innovative and patented transmission technology for direct voltage transmission to reduce the wire-resistance and to increase the efficiency.
- 80 Plus Platinum
- Multi Rail Design
- Fit4Server
- DX 11 Ready
- HeatGuard
- CordGuard
- SafeGuard
- 5 Year Warranty
Was £284.99 Inc. VAT
Only £264.98 inc VAT.
ORDER NOW
Enermax Revolution 87+ 650w '80 Plus Gold' Modular Power Supply (ERV650AWT-G) @ £109.98 inc VAT
The revolution 87+ range of PSU's from Enermax offer stable and safe power supply thanks to four high-performance and massive 12V rails each with separated over current protection (OCP). Extremely low ripple noise. DC-to-DC converter for minimum energy losses and maximum efficiency as well as best possible and most stable voltage regulation at dynamic and cross loading. Technological breakthrough topology using a staged dynamic transformer array for extremely high efficiency with the most durable and stable output at any load. Integrated 13.9cm fan with patented Twister Bearing Technology ensures efficient and ultra silent cooling and long lifetime (100,000 hours MTBF).
- 80 Plus Gold certifed
- Dynaminc Hybrid Transformer Topology
- Quad Multi Rail Design
- Speed Guard
- Heat Guard
- High Quality Japanese Capactiors
- Safe Guard
- Cool Guard
- 5 Year Warranty
Was £117.98 Inc. VAT
Only £109.98 inc VAT.
ORDER NOW
Enermax Revolution 87+ 850w '80 Plus Gold' Modular Power Supply (ERV850AWT-G) @ £149.99 inc VAT
- Speed Guard
- Heat Guard
- Safe Guard
- Cool Guard
- 5 Year Warranty
Was £159.98 Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Enermax Revolution 87+ 1000w '80 Plus Gold' Modular Power Supply (ERV1000AWT-G) @ £179.99 inc VAT
- Speed Guard
- Heat Guard
- Safe Guard
- Cool Guard
- 5 Year Warranty
Was £194.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Enermax Triathlor 450w '80 Plus Bronze' Power Supply (ETL450AWT) @ £57.98 inc VAT
The new Enermax Triathlor range supports two massive 12V rails to power high-performance processors and graphics cards. More than 98 percent of the total power of the PSU can be delivered by the key rails only. Stable voltage output even at 0W load. In this way, Triathlor supports the energy-saving functions of modern CPU and graphics cards (C6 State/Hybrid Mode) and prevents compatibility issues. Smooth running 12cm T.B.Silence fan with patented Twister bearing (100,000 hours MTBF) and powerful Batwing blades for very effective and silent cooling.
- 80 Plus Bronze
- DC to DC design
- Full GPU and CPU Power from two 12 Rails which deliver 98% of the rated power
- OCP on all the rails
- 12cm T.B. Silence fans
- Speed Guard
- Air Guard
- Safe Guard
- High quality Japanese Capacitors
- Scratch resistance housing
- 3 Year Warranty
Was £62.99 Inc. VAT
Only £57.98 inc VAT.
ORDER NOW
Enermax Triathlor 550w '80 Plus Bronze' Power Supply (ETL550AWT) @ £64.98 inc VAT
- 80 Plus Bronze
- DC to DC design
- Speed Guard
- Air Guard
- Safe Guard
- 3 Year Warranty
Was £69.98 Inc. VAT
Only £64.98 inc VAT.
ORDER NOW
Enermax Triathlor FC 550w '80 Plus Bronze' Modular Power Supply (ETA550AWT-M) @ £71.99 inc VAT
The new Enermax Triathlor range supports two massive 12V rails to power high-performance processors and graphics cards. More than 98 percent of the total power of the PSU can be delivered by the key rails only. Stable voltage output even at 0W load. In this way, Triathlor supports the energy-saving functions of modern CPU and graphics cards (C6 State/Hybrid Mode) and prevents compatibility issues. Smooth running 12cm T.B.Silence fan with patented Twister bearing (100,000 hours MTBF) and powerful Batwing blades for very effective and silent cooling. All-round modular cable management. 10/12P sockets for possible connector changes of upcoming high-performance CPU and graphics card generations.
- 80 Plus Bronze
- DC to DC design
- Speed Guard
- Air Guard
- Safe Guard
- 3 Year Warranty
Was £76.99 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Enermax Triathlor FC 700w '80 Plus Bronze' Modular Power Supply (ETA750AWT-M) @ £89.99 inc VAT
- 80 Plus Bronze
- DC to DC design
- Speed Guard
- Air Guard
- Safe Guard
- 3 Year Warranty
Was £94.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Qpad MK-85 Red LED Pro Backlit Mechanical Gaming Keyboard - UK Layout - Black Switches @ £99.98 inc VAT
nonl2br
<img src="http://www.overclockers.co.uk/LP/productimages/keyboard/black.gif">
<br>
Unlike your average keyboard, that functions through rubber domes, forcing you to press each key all the way down in order for the stroke to register, the MK-85 feature true mechanical switches with unmatched accuracy and feel. No more pressing with full-force in order to activate the keys.The QPAD keyboard will respond to your every stroke in an instant.<br>
<br>
Other boards normally have a short life span and wear out quickly, resulting in unresponsiveness, delays and a dull, clunky feel to the keys. The key switches on MK-85 are built to last 50 million strokes, and the QPAD mechanical key technology provides distinct feedback and puts you in absolute control. The travel distance of the keys is set to 4mm with an actuation point at 2mm.<br>
<br>
For gamers, it’s all about the feel and functionallity and that is where the QPAD MK-85 truly shines. With a full size keyboard layout in 3 sections, gaming profiles, macro recording, mechanical key switches, media keys and full N-Key roll over via USB, it’s the perfect gaming keyboard. Nuff said...<br>
<br>
- Key switch: Cherry black MX mechanical switch technology<br>
- N Key Roll over: Full N-Key roll over via USB<br>
- Key strokes: 50 Million<br>
- Lighting: Individual LED backlight on every key for enhanced visuals<br>
- Lighting features: Four levels of brigthness allow you to locate keys easily<br>
- Connectors: Gold plated USB connectors for extremly low latency<br>
- Media keys: Media keys for volume control, play, pause and skip tracks<br>
- USB Hub: Two high speed USB 2.0 ports<br>
- Audio ports: 3.5mm headphone-out and microphone-in jacks<br>
- Cable: 1.8 meter braided cable<br>
- Extras: 4 extra orange key caps and key cap puller<br>
- Dimensions: Keyboard: 44,8 x 14,9 x 3,5 cm (17,6 x 5,8 x 1,37 inch)<br>
- Wrist pad: 44,8 x 6,6 x 1,7 cm (17,6 x 2,48 x 0,66 inch)<br>
- Weight: 1.27 Kg (2.8 LBS)<br>
- Warranty: 2 year<br>
- Software: Customizable profiles, programmable keys and macro recording<br>
- Supports: Windows XP, Vista, 7<br>
Only £99.98 inc VAT.
ORDER NOW
Qpad MK-85 Red LED Pro Backlit Mechanical Gaming Keyboard - UK Layout - Red Switches @ £99.98 inc VAT
nonl2br
<img src="http://www.overclockers.co.uk/LP/productimages/keyboard/red.gif">
<br>
<br>
<br>
<br>
- Key switch: Cherry MX mechanical switch technology<br>
- Cherry Red Switches<br>
ORDER NOW
Employees in many industries need two computer monitors to successfully display and interact with information they need to get the job done. To meet these needs, IT needs a flexible professional graphics solution that's compatible with the variety of displays and computing systems they happen to have on hand.
AMD FirePro™ 2270 professional graphics are capable of driving two 30" high resolution DisplayPort, DVI or VGA displays. Featuring a low profile, energy efficient design, the AMD FirePro 2270 can be deployed in a wide range of systems, from notebook docking stations to small form factor desktops to large tower workstations.
512MB of Graphics Memory
Enables efficient multi-tasking across multiple applications or graphics intensive applications, helping to prevent system bog downs
Dual-view Display
Expands field of view across two 30" high resolution displays, allowing users to interact with multiple applications simultaneously, see images in more detail and improve workflow productivity. Ability to stretch one image or application across both screens to create one large view
Low Power Consumption
Consumes 15W maximum power, suitable for deployment in smaller energy efficient systems
Flexible Output Configurations
Supports two 30" high resolution DisplayPort, DVI or VGA displays, allowing IT to configure set ups with existing display inventory
Passive Cooling
Optimal cooling solution helps increase MTBF, enabling higher reliability and stability
Low Profile Design
Allows installation in the smallest form factors, notebook docking stations or full height systems
Unified Driver Architecture
Delivers the stability and reliability demanded by professional users, as well as the convenience and ease of maintenance vital for IT
Was £99.98 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
AMD FirePro V3900 Professional Graphics Card - 1GB - DDR3 SDRAM @ £93.95 inc VAT
AMD FirePro™ V3900 professional graphics enables an exceptional user experience by delivering features and reliability designed to help boost the productivity of professionals working with low to moderate-complexity designs.
The AMD FirePro™ V3900 professional graphics card is powered by a new generation GPU, backed by 1GB of fast DDR3 memory, 480 stream processors and support for up to 5 (five) display devices using AMD Eyefinity multi-monitor technology and DisplayPort™ 1.2 multi-streaming technology.
Features:-
- Officially certified for superior reliability when working in many CAD and M&E applications
- Outstanding performance for projects ranging from low to moderate complexity
- Supports up to 5 simultaneous displays with AMD Eyefinity and DisplayPort™ 1.2 multi-streaming technologies1
- 1GB of high speed DDR3 memory (twice the capacity of other entry-level cards2)
- Massively parallel processing architecture featuring 480 next-gen AMD stream processors
- Support for both dual-link DVI and DisplayPort™ connectivity
- AMD AutoDetect technology automatically optimizes GPU driver settings as applications are launched
- Full OpenCL™, OpenGL and DirectX® 11 support (Please see www.amd.com/api for specific version support)
- PCI Express® 2.1 compliant
Specifications:-
- AMD FirePro V3900 Professional Graphics Card
- Core Clock Speed: 650MHz
- Stream Processors: 480
- Maximum GPU Power: 50W
- Frame Buffer / Memory: 1GB GDDR5 128 Bit
- Power Connectors: zero power connections
- Display Outputs: DL-DVI-I, DisplayPort x 1
- Warranty: 3 Years
Was £98.99 Inc. VAT
Only £93.95 inc VAT.
ORDER NOW
AMD FirePro V4900 Professional Graphics Card - 1GB - GDDR5 SDRAM @ £131.99 inc VAT
AMD FirePro™ V4900 professional graphics offer strong performance and outstanding reliability while delivering features that help boost the productivity of professionals working with medium to large models, all in a single slot, half-length solution.
The AMD FirePro™ V4900 professional graphics card is powered by a new generation GPU, backed by 1GB of blazing-fast GDDR5 memory, 480 stream processors, and support for three simultaneous monitor outputs on a single card with AMD Eyefinity technology.
Features:-
- AMD Eyefinity Technology, With the revolutionary multi-display technology, the AMD FirePro V4900 professional graphics card supports three independent displays, delivering the most immersive graphics/computing experience with innovative display capabilities supporting massive desktop workspaces.
- DisplayPort 1.2, Support for the newest DisplayPort standard adds exciting new features such as high bit-rate audio, higher data bandwidth, and multi-streaming capabilities.
- AutoDetect Technology, As a user moves between applications, or opens new ones, the graphics driver settings are automatically configured for optimized performance.
- Full 30-bit Display Pipeline, Enables more color values than 24-bit products for more accurate color reproduction and superior visual fidelity.2
- Full Shader Model 5.0 Support, Helps create highly complex geometry and scenes without taxing the CPU.
- Certification, Ensure compatibility, reliability and the highest level of performance when used with professional 3D software packages.
- DirectX® 11 and OpenGL Advanced Features, Enables optimal performance in leading applications. Please visit www.amd.com/api to see specific OpenGL version support.
- OpenCL™, Industry standard API – Open, multiplatform development platform to help enable broad adoption of heterogeneous computing. Please visit www.amd.com/api to see specific OpenCL™ version support.3
Specifications:-
- AMD FirePro V4900 Professional Graphics Card
- Core Clock Speed: 800MHz
- Maximum GPU Power: 75W
- Frame Buffer / Memory: 1GB GDDR5 256 Bit
- Display Outputs: DL-DVI-I, DisplayPort x 2
- Warranty: 3 Years
Only £131.99 inc VAT.
ORDER NOW
AMD FirePro W5000 Professional Graphics Card - 2GB - GDDR5 SDRAM @ £371.99 inc VAT
AMD FirePro W5000™ is the most powerful midrange workstation graphics card ever created, delivering significantly better performance than the competing card against a wide set of measurements.1 For example, it has the ability to process up to 1.65 billion triangles per second, allowing a designer to easily interact and render 3D models, while the competing solution is only able to process up to 0.41 billion triangles per second (up to 4 times less).2 In addition, with double the graphics memory (2GB vs 1GB of the competitor) and a memory bandwidth that is up to 2.5 times faster than the competitor, moderately complex models will be no match for the AMD FirePro™ W5000.3 It’s the ideal solution for professionals working with a broad range of applications, moderately complex models and datasets and advanced visual effects.
Features:-
- Drive up to four displays with AMD Eyefinity technology,4 enabling users to multitask across multiple applications with ease
- Offers unmatched application responsiveness, features double the memory and up to 2.5 times more memory bandwidth than the competing midrange solution3
- Support for DisplayPort 1.2, enabling resolutions well beyond standard HD and compatibility with multistream transport hubs that allow AMD FirePro™ W5000 to power up to six displays4
- Optimizations and certifications for many major CAD/CAE and media and entertainment applications
- Intelligent power saving and monitoring technologies for higher performance
- AMD Eyefinity Technology, Industry-leading multidisplay technology enabling highly immersive and unrivaled multitasking experience across up to four displays, powered by a single AMD FirePro™ W5000 graphics card.4
- GeometryBoost, Allows the GPU to process geometry data at a rate of twice per clock cycle resulting is a doubling in the rate of primitive and vertex processing. Triangle rates increase two-fold relative to a GPU that does not possess GeometryBoost.
- DisplayPort 1.2, Simultaneously output multiple, independent audio streams and display content at resolutions beyond standard HD (maximum resolution of 4096x2160).
- Energy Efficient Design, AMD PowerTune technology dynamically optimizes GPU power usage and AMD ZeroCore Power technology significantly reduces power consumption at idle.5
- AMD ZeroCore Power, AMD ZeroCore Power technology leverages AMD's leadership in notebook power efficiency to grant our desktop GPUs the ability to power down when your monitor is off, also known as the "long idle state."
- AMD PowerTune, AMD PowerTune is an intelligent system that performs real-time analysis of applications that utilize a GPU. In the event that an application is not making the most of the power available to the GPU, AMD PowerTune can improve that application's performance by raising the GPU's clock speed by up to 30 percent - automatically.
- Video Codec Engine (VCE), A multistream hardware H.264 HD encoder, for power efficient and quick video encoding.
Specifications:-
- AMD FirePro W5000 Professional Graphics Card
- Core Clock Speed: 825MHz
- Stream Processors: 768
- Frame Buffer / Memory: 2GB GDDR5 256 Bit
- Warranty: 3 Years
Was £389.99 Inc. VAT
Only £371.99 inc VAT.
ORDER NOW
PNY Nvidia Quadro NVS 300 Dual VGA Low Profile Graphics Card - 512MB - GDDR3 SDRAM @ £102.95 inc VAT
The NVIDIA® NVS™ 300 by PNY, multi-display business graphics solution, designed for small and standard form factor systems, delivers reliable hardware and software for a stable business environment. Tested on leading business applications, NVS 300 by PNY is capable of driving two VGA, single link DVI or DisplayPort displays. With NVIDIA Mosaic™ and NVIDIA nView® technologies built in, you can span and efficiently manage your entire Windows desktop across multiple displays.
- Bus Interface : PCI Express Gen 2 x16
- Max Displays/Board DP : 2 ultra-high resolution displays at 2560 x 1600
- Max Displays/Board DVI : 2 ultra-high resolution displays at 1920 x 1200
- MAX Displays/Board VGA : 2 ultra-high resolution displays at 2048 x 1536
- Power : 17.5W - Passive cooling
- Form Factor : Small Form Factor
- Mosaic Mode Enabled : Yes (Windows 7 only)
- nView Enabled : Yes
Was £107.99 Inc. VAT
Only £102.95 inc VAT.
ORDER NOW
PNY Nvidia Quadro NVS 300 Dual DVI Low Profile Graphics Card - 512MB - GDDR3 SDRAM @ £103.99 inc VAT
Only £103.99 inc VAT.
ORDER NOW
PNY Nvidia Quadro 410 Graphics Card - 512MB - GDDR3 SDRAM @ £119.99 inc VAT
NVIDIA® Quadro® 410 GPUs combine outstanding workflow productivity for entry CAD/PLM users, comprehensive professional application certifications, and the peace of mind professionals have come to expect from NVIDIA Quadro products – all at an exceptional value.
- Shader Model 5.0.
- OpenGL 4.2.
- Microsoft® DirectX 11.
- NVIDIA CUDA Parallel Processing Architecture.
- NVIDIA® nView® multi-display technology.
- NVIDIA® Mosaic technology.
- 512MB Vram
- 64 Bit GDDR3
- 38W
- 1x DisplayPort
- 1x Dual Link DVI-I
- Max resolution: 3840x2160
- 192 CUDA Cores
Was £124.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
PNY Nvidia Quadro 600 Graphics Card - 1GB - GDDR3 SDRAM @ £149.99 inc VAT
NVIDIA® Quadro® 600 by PNY Technologies - Low-profile, power-efficient, professional graphics solution
Built for Professionals™, and certified on leading CAD and DCC applications, NVIDIA Quadro 600 by PNY delivers the best performance per watt in its class, maximizing productivity while conserving energy.
Designed for both small form factor and full height workstations, the NVIDIA Quadro 600 by PNY delivers advanced capabilities, allowing you to design, iterate and deliver higher quality results in less time.
- Frame Buffer Memory: 1GB DDR3
- Memory Interface: 128-bit
- Memory Bandwidth: 25.6 GB/s
- CUDA Parallel Processing Cores: 96
- Display Connectors: DVI-I (1), DP (1)
- Max Power Consumption: 40 W
- Graphics Bus: PCI Express 2.0 x16
- Form Factor: Low Profile - 2.731” H x 6.6” L Single Slot
- Thermal Solution: Active
- 3D Vision Pro: Support via USB
Was £158.99 Inc. VAT
ORDER NOW
PNY Nvidia Quadro 2000 Graphics Card - 1GB - GDDR5 SDRAM @ £399.95 inc VAT
Delivering the industry’s best-in-class performance across leading CAD and DCC applications, the NVIDIA Quadro 2000 by PNY mid-range professional graphics solution features Scalable Geometry Engine™ technology and 1GB of memory for fast processing of complex models and scenes.
With Quadro solutions your work flows – design, iterate and deliver higher quality results in less time.
- Frame Buffer Memory: 1GB GDDR5
- Memory Interface 128-bit
- Memory Bandwidth 41.6 GB/s
- CUDA™ parallel processing cores: 192
- Display Connectors: DVI-I (1), DP (2)
- Max Power Consumption: 62 W
- Form Factor: 4.376” H x 7” L Single Slot
Was £419.99 Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
PNY Nvidia Quadro 2000D Graphics Card - 1GB - GDDR5 SDRAM @ £389.99 inc VAT
Delivering the industry's best-in-class performance across leading professional ISV applications, the NVIDIA Quadro 2000D by PNY features two dual-link DVI connectors to drive two ultra-high-resolution panels and add flexibility for multi-monitor configurations. Professional applications can take advantage of the Quadro 2000D advanced feature set, including Scalable Geometry Engine™ technology, 192 NVIDIA CUDA™ parallel processing cores and 1GB of memory for fast processing of complex models and scenes.
The NVIDIA Quadro 2000D by PNY also delivers the industry's most advanced diagnostic imaging graphics solution. Offering two dual-link DVI connectors for display flexibility, support for 10/12-bit grayscale monitors up to 10Mpixels, and DICOM monitor calibration capabilities – the Quadro 2000D enables more confident medical analysis.
Based on NVIDIA's award-winning Fermi Architecture, the Quadro 2000D delivers advanced capabilities including Mosaic Technology which enables any application to scale across up to eight displays using multiple Quadro graphics boards.
- Memory Size: 1 GB GDDR5
- Memory Bandwidth: 41.6 GB/s
- CUDA Parallel Processing Cores: 192
- Display Connectors: DVI-DL + DVI-DL
- Maximum Power Consumption: 62 W
- Physical Dimensions: 4.376" H x 7.0" L Single Slot
- Warranty: 3 Years
Was £399.98 Inc. VAT
Only £389.99 inc VAT.
ORDER NOW
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) HDD @ £43.99 inc VAT
Combining proven components, state-of-the-art technology and industry-leading manufacturing expertise, the Seagate Barracuda 7200.12 drive - the 12th generation of this award-winning desktop hard drive family - delivers 500GB of high-performing, eco-friendly digital storage.
- Capacity: 500GB
- Cache: 16MB
- Interface: SATA 6GB/s
- Spin Speed: 7200RPM
- Seek Time: 8.5ms
- Warranty: 1 Years
Was £49.99 Inc. VAT
Only £43.99 inc VAT.
ORDER NOW
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD @ £59.99 inc VAT
The new Barracuda ST1000DM003 hard drive from Seagate offers customers a compelling new storage choice for high-capacity, high-performance computing solutions. The new Barracuda ST1000DM003 drive is built on a full-speed, 7200RPM platform. Further turbocharged with a huge 64MB cache and the industry’s new, high-performance SATA 6Gb/s interface, the Barracuda ST1000DM003 drive is destined to set a new standard for high-speed desktop performance. Discerning high-performance PC users, multimedia development professionals and power users in general will appreciate the capacity, performance and flexibility the Barracuda ST1000DM003 drive offers.
- Backwards compatible with SATA-II
- Capacity: 1TB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Warranty: 1 Years
Was £69.98 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST3000DM001) HDD @ £104.99 inc VAT
The new Barracuda ST3000DM001 hard drive from Seagate offers customers a compelling new storage choice for high-capacity, high-performance computing solutions. The new Barracuda ST3000DM001 drive is built on a full-speed, 7200RPM, 6 Head, 3 Disk platform. Further turbocharged with a huge 64MB cache and the industry’s new, high-performance SATA 6Gb/s interface, the Barracuda ST3000DM001 drive is destined to set a new standard for high-speed desktop performance. Discerning high-performance PC users, multimedia development professionals and power users in general will appreciate the capacity, performance and flexibility the Barracuda ST3000DM001 drive offers.
- Capacity: 3TB
- Cache: 64MB
- Warranty: 1 Years
Was £113.99 Inc. VAT
Only £104.99 inc VAT.
ORDER NOW
Western Digital Caviar Red 3TB SATA 6Gb/s 64MB Cache WD30EFRX - OEM HDD @ £129.95 inc VAT
WD Red is the only hard drive designed for NAS systems that have 1-5 drive bays. The drives are designed and extensively tested for compatibility in the unique 24x7 operating environment and demanding system requirements of home and small office NAS.
- Capacity: 3TB
- Cache: 64MB
- Spin Speed: 5900RPM
- Warranty: 3 Years
Was £149.99 Inc. VAT
Only £129.95 inc VAT.
ORDER NOW
Western Digital Caviar Red 2TB SATA 6Gb/s 64MB Cache WD20EFRX - OEM HDD @ £89.99 inc VAT
- Capacity: 2TB
- Cache: 64MB
- Warranty: 3 Years
ORDER NOW
Samsung SH-118AB/BEBE SATA 18x DVD-ROM (Black) - OEM @ £11.99 inc VAT
Samsung's 18x Serial SATA DVD-ROM gives a great optical drive for excellent value.
- DVD-ROM: 18x
- CD-ROM: 48x
- Access time 120ms
- Buffer Size : 1.5MB
Was £14.99 Inc. VAT
Only £11.99 inc VAT.
ORDER NOW
Liteon IHOS104-06 4x BD-ROM (Black) - OEM @ £29.99 inc VAT
Lite-On BD-ROM drives offer the best solution for people who want to enjoy High Definition Blu-ray movies at an affordable cost. Besides Blu-ray movies, your current DVD and CD collections can also be played. Lite-On BD-ROM drives are compatible with Blu-ray, DVD and CD formats to ensure optimal playback possibilities.
• Higher transfer rates with SATA connection.
• Future proof; compatibility with the latest motherboards.
• Better airflow in PC casings due to smaller cable and plug sizes.
• Enjoy High Definition Blu-ray movies.
• This is Bare OEM Hardware Drive and software is included PowerDVD
- Read Speed - 32x (CD) / 12x (DVD) / 4x (BD)
- Enclosure Type - Internal
- Enclosure Colour - Black
- Interface - Serial ATA
Was £34.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Asus BC-12B1ST BluRay-Rom / DVD-RW Drive OEM @ £59.99 inc VAT
The ASUS internal BC-12B1ST dual format high definition drive that has the capability to read and play different Blu-ray formats. The BC-12B1ST also reads and writes in three types of DVD formats in one convenient package – DVD+R, DVD-R and DVD-RAM
- Reading Speeds: BD-R : 8X / BD-RE : 8X / BD-ROM : 8X / BD-R(DL) : 8X / BD-RE(DL) : 6X / BD-ROM(DL) : 8X / DVD+R : 16X / DVD-R : 16X / DVD+RW : 12X / DVD-RW : 12X / DVD-ROM : 16X / DVD+R(DL) : 12X / DVD-R(DL) : 12X / DVD-ROM(DL) : 12X / DVD-RAM : 12X / CD-R : 48X / CD-ROM : 48X / BDMV Playback : 4X / DVD Video Playback : 6X / VCD Playback : 16X / Audio CD Playback : 16X
- Write Speeds: BD-R : 12X / BD-R(DL) : 8X / BD-R(LTH) : 4X / BD-RE : 2X / BD-RE(DL) : 2X / DVD+R : 16X / DVD-R : 16X / DVD+RW : 8X / DVD-RW : 6X / DVD+R(DL) : 8X / DVD-R (DL) : 8X / DVD-RAM : 12X / CD-R : 48X / CD-RW : 24X
- Buffer: 8 MB
Was £63.98 Inc. VAT
ORDER NOW
Samsung SH-224BB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM @ £18.95 inc VAT
The SH-S224 drive offers a powerful over-speed performance feature that enables consumers to burn data at high speeds - even on low speed media. With over-speed recording, users can write at 24X speeds on 16X media and 12X speeds on 8X media. As lower speed media is more cost-effective, users can save money while burning discs at faster speeds.
The SH-S224 drive provides blazing recording speeds across a gamut of different data media types including 24X DVD±R recording, 12X DVD-RAM recording, 16X DVD+R Dual Layer recording, 12X DVD-R Dual Layer recording, 8X DVD+RW recording and 6X DVD-RW recording. It enables consumers to burn 4.7GB on a DVD±R disc in approximately 4 minutes and 26 seconds, a 6 percent increase in speed compared to a 20X DVD writer. It also takes less than 12 minutes to burn 4.7GB in DVD-RAM format, which is a 30 percent increase in speed over a 20X DVD drive.
Samsung's SH-S224 drive supports SATA interface, the dominant interface for PCs.
As with Samsung's complete WriteMaster optical disc drive lineup, the SH-S224 features specific technology that ensures best-of-breed performance including SAT1 (Speed Adjustment Technology), TAC2 (Tilt Actuator Compensation) and Double OPC3 (Optimum Power Control). Buffer Under Run Free Technology4 supports stable writing under high speed, and Magic Speed5 and ABS (Automatic Ball Balancing System) 6 technologies reduce vibration and noise. The SH-S224 is also eco-friendly designed and is RoHS compliant.
Write Speed
- DVD-R: 24x
- DVD-R: 24x
- DVD-R DL: 12x
- DVD+R DL: 16x
- DVD+RW: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- CD-R:48x
- CD-RW: 4x
Read Speed
- DVD-R: 16x
- DVD+R: 16x
- DVD-R DL: 12x
- DVD+R DL: 12x
- DVD-RW: 12x
- DVD+RW: 12x
- DVD-RAM: 12x
- CD-R: 40x
- CD-RW: 40x
Was £20.99 Inc. VAT
Only £18.95 inc VAT.
ORDER NOW
Asus 24x DVD±RW DRW-24B5ST SATA ReWriter - Black (OEM) @ £18.95 inc VAT
ASUS DRW-24B5ST is a powerful 24X DVD±R/12X DVD±R(DL)/8X DVD+RW/6X DVD-RW/16X DVD-ROM/12X DVDRAM/ 48X CD-R/32X CD-RW/48X CD-ROM for a seamless function of flexibility, high quality and reliability.
- Interface: SATA-II
- Tray Loading
- Auto vibration Reduction System
- CD Write Speed: 48x
- DVD Write Speed: 42x
- CD Read Speed: 48x
- DVD Read Speed: 16x
- DVD-RAM Read Speed: 12x
- 1 Year Warranty
Was £21.98 Inc. VAT
ORDER NOW
Asus Xonar D2X 7.1 PCI-E Sound Card @ £79.99 inc VAT
With the introduction of Windows Vista, the whole audio architecture landscaped has been changed. This has resulted in teething problems for gamers - with the possibility of losing all surround sound or hardware accelerated Direct3D and EAX while gaming in the Windows Vista environment. To circumvent this problem, the Asus Xonar family of audio cards utilizes an Asus exclusive technology - the new DS3D GX extension in the Xonar D2X driver; to provide full support for surround sound and hardware accelerated features by translating DirectX to the DS3D GX. While other solutions like OpenAL requires special installation and game support, DS3D GX doesn't. Gamers can enjoy DirectX gaming with hardware enhanced surround sound and EAX effects automatically and immediately after installation. Asus Xonar D2X audio card, dedicated to be the best audio card for gaming and home entertainment, provides unprecedented 118dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24-bit ultra fidelity input and output with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar D2X is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Centre, which you will never have with onboard audio or other sound cards.
- PCI-Express Interface
- Vista Gaming with DirectSound & EAX support
- Hi-Fi class audio quality with SNR up to 118dB
- Dolby HomeTheater Technologies & DTS Connect
- Valuable Cakewalk and Ableton Live music production software bundled
- Unprecedented SSNR NR Up to 118db reaching the limit of PC audio sound quality clarity
- Full duplex High-definition audio processing at 192KHz/24Bit for all Input and outputs and Inputs
- Versatile Dolby/DTS Audio Technologies for Game, Music, and Video
- Accurate 3D sound positioning and hardware acceleration for PC gaming
- Real-time DDL and DTS Connect encoders for amazing gaming and surround sounds over your Home Theater System
- Requires floppy power-connector
- Vista Ready
Was £89.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp @ £22.99 inc VAT
The Xonar DG sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DG an ideal sound card for gamers who want to remain totally aware of their play environments.
- Built-in Headphone AMP
- Powers up every sound detail in gaming
- 3 gain modes for different usage scenarios
- Dolby Headphone for an immersive 5.1 surround imaging
- GX2.5 for realistic 3D audio effects
Was £25.99 Inc. VAT
Only £22.99 inc VAT.
ORDER NOW
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp - OEM @ £19.99 inc VAT
- OEM Bare card.
Driver location: http://uk.asus.com/Multimedia/Audio_Cards/Xonar_DG/#download
Was £22.99 Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Asus Xonar DGX 5.1 PCI-Express Sound Card with built in Headphone Amp @ £21.95 inc VAT
The Xonar DGX sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DGX an ideal sound card for gamers who want to remain totally aware of their play environments.
- PCI-E
Was £24.98 Inc. VAT
Only £21.95 inc VAT.
ORDER NOW
Asus Xonar Essence STX Sound Card @ £119.99 inc VAT
The Xonar Essence STX PCI-Express is the latest sound card from Asus that provides high quality audio performance. Its integrated headphone amplifier produces less than 0.001% distortion to accompany its industry-leading 124dB Signal-to-Noise Ratio (SNR). The sound cards also boast Hyper-ground technology, EMI Shield design, AV100 high-definition sound processor, 24-bit Burr Brown PCM 1792A D-A converters, Nichicon Fine Gold capacitors, Optical digital output, Two pairs of RCA jacks and Input and output 6.3mm stereo jacks. The new Asus Xonar Essence STX PCI-Express is also perfect for gaming and entertainment PCs since it supports ASIO 2.0, Dolby Digital Live, Headphone, Virtual Speaker, Pro-Logic II home theater sound technologies and DS3D GX2.5 3D gaming engines.
- Optical digital output
- EMI Shield design
- Dolby Digital Live
- Pro-Logic II home theater sound technologies
- DS3D GX2.5 3D gaming engines
- 24-bit Burr Brown PCM 1792A D-A converters
- 124dB Signal-to-Noise Ratio (SNR)
ORDER NOW
Asus Xonar Essence ST Sound Card @ £119.99 inc VAT
Choosing only the best components and finest design, the Xonar Essence ST achieves unprecedented 124dB SNR - 64 times clearer than on-board solutions, bringing top-of-the shelf audio experience for audiophiles. Xonar Essence ST is the world’s first audio card to focus on precision clock tuning to minimize audio jitter. The result is extensive musical details and lively sound image presented for revolutionary experience.
- Industry-leading 124dB SNR
- Built-in headphone amp drives every available headphone with <0.001% distortion
- Nichicon Fine Gold capacitors offer great dynamic performance
- Perfectly shielded EMI-free analog output path
- Customize your sound color effortlessly via swappable OPAmp socket
Was £144.98 Inc. VAT
ORDER NOW
Asus Xonar Xense Sound Card + Sennheiser PC 350 Xense Edition Headset @ £179.99 inc VAT
The new Asus Xonar Xense One and Sennheiser PC 350 Xense Edition package is the result of cooperation between Asus and premier personal audio maker, Sennheiser. Xonar Xense is a perfectly matched combination of cutting edge audio card and superior quality headphones that reinvents immersive sound for serious gamers. The gaming audio set creates unbeatable sonic experiences in PC gaming that are sure to be appreciated by hardcore gamers keen on competitive online play.
- Powerful headphone amplifier and matched high-impedance driver secure FPS-optimized sound positioning and dynamics
- No footsteps missed in front of the 118dB SNR sound clarity brought by EMI shield and studio-standard 6.3mm audio jack
- Stylish full-stainless steel design matches the earcup cover of Sennheiser headset
- Pro gamers’ long-hour usage catered by excellent headset ergonomics
- New Gain Level perfectly tuned up for the PC 350 headset
Was £189.95 Inc. VAT
ORDER NOW
Adata DashDrive Air AE400 Wireless Storage Reader and Power Bank @ £52.99 inc VAT
The AE400 can serve multiple mobile devices to read/write and stream data from SD memory cards and USB storage media via wireless technology, and is also equipped with a power bank that can charge other mobile devices.
Data transfer between devices and SD card/USB drive/ Portable HDD
- The AE400 adopts Samba/WebDAV server/Http streaming protocol to provide data transfer and sharing, providing devices (iOS/Android/ Windows/OS X/Linux) with wireless access to a SD Card, USB Flash Drive, or Portable HDD.
- Supports up to 15 hours continuous stream for one user.
- Supports simultaneous streaming of 1080p video for up to 3 users or 720p video for up to 5 users.
Power Bank
- Built-in high capacity battery: 5000 mAh
- Supports fast charging for iPhone/iPad
Easy to operate wireless hotspot
- The AE400 can connect to existing wireless networks and create an internet bridge connection. Through this hot spot, up to 10 other devices can connect to the internet through the AE400.
Free Application Download
- For iPad, iPad mini, iPod Touch and iPhone users. Requires iOS 5.0 or later versions. This application is also suitable to Android 2.3 and later versions’ devices.
Stylish Housing
- The surface of the AE400 gleams with a modern, hexagonal lattice design.
Cable transfer mode
- The AE400 can also act as a standard card reader via micro USB cable connected to a computer.
- Ports: Micro-B USB (data transmission & battery charging), USB AF (host port for UFD/portable HDD or Power Bank function), SD card (for SD/SDHC/SDXC)
- Battery: Li-Polymer 5000mAh rechargeable battery
- Power Bank: 5000 mAh
- Temperature: Operating 0~50°C; Storage -20~60°C
- File system compatibility: FAT32/exFAT
- Operating System Compatibility: iOS 5.0+ / Android 2.3+ Windows XP, Vista, 7, 8 Mac OS X 10.x+ / Linux 2.4+
- Wireless standard: IEEE 802.11b/g/n
- Wireless security: WPA, WPA2
- Data rate: up to 150 Mbps (wireless), up to 480 Mbps (USB2.0)
- Dimensions (L x W x H): 80 x 59 x 21mm (3.1 x 2.3 x 0.8in)
- Weight: 128g
- Warranty: One Year Warranty
- Box Contents: AE400, User’s guide, Micro USB cable
- Hexus Review: http://hexus.net/tech/reviews/storage/52441-adata-dash-drive-air-ae400/
- Kitguru Review: http://www.kitguru.net/mobile/zardon/adata-dashdrive-air-ae400-review/
Was £59.99 Inc. VAT
Only £52.99 inc VAT.
ORDER NOW
Intel 330 Series 60GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail @ £69.95 inc VAT
Get Fast. Play Fierce.
Faster game and application loads, less lag, smoother visuals.
Stay ahead of the competition when you level up to 6.0 gigabits per second (Gb/s) performance
New Level of Performance
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 500MB/sec
- Maximum Write: 450MB/sec
- Max I/O Per Second (IOPS): 33000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 years
Was £79.99 Inc. VAT
Only £69.95 inc VAT.
ORDER NOW
Intel 335 Series 180GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail @ £139.99 inc VAT
- Capacity: 180GB
- Maximum Read: 550MB/sec
- Maximum Write: 520MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- Warranty: 3 years
Only £139.99 inc VAT.
ORDER NOW
OCZ Vector 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (VTR1-25SAT3-128G) @ £113.99 inc VAT
The groundbreaking Vector Series delivers an industry-leading solid-state storage solution designed to provide superior user experience and improved application performance.
Advanced suite of NAND flash management keeps your drive at higher sustained performance over the long term for maximum endurance.
Excels in both incompressible and compressible data types such as multimedia, encrypted date,.ZIP files and software.
Cutting-edge controller technology delivers maximum performance and delivers unmatched endurance without compression or loss of usable capacity, rated for 20GB/day of host writes for 5 years (typical client workloads)
- Capacity: 128GB
- Controller: Indilinx Barefoot 3
- Maximum Write: 400MB/sec
- Max I/O Per Second (IOPS): 95000 IOPS (4KB File)
- Warranty: 5 Years
Was £119.99 Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
Samsung 120GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD120BW) @ £83.99 inc VAT
The Samsung SSD840 is a high performance SSD designed for power users. Capable of delivering up to 98,000 IOPS Random Read Speed and 540MB/s Sequential Read speed, it is an SSD of unrivaled high performance. Even better, the advanced MDX controller delivers these speeds regardless of data type, unlike some competing controllers that greatly favor compressible data.
• Capacity: 120GB
• Sequential Read: 530MB/s
• Sequential Write: 130MB/s
• Random Read (QD32, 4KB): 86,000 IOPS
• Random Write (QD32, 4KB): 32,000 IOPS
• Random Read (QD1, 4KB): 7,900 IOPS
• Random Write (QD1, 4KB): 29,000 IOPS
• Warranty: 3 Year
Was £89.99 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
Samsung 128GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD128BW) @ £113.99 inc VAT
The Samsung SSD840 PRO is a high performance SSD designed for power users. Capable of delivering up to 100,000 IOPS Random Read Speed and 540MB/s Sequential Read speed, it is an SSD of unrivaled high performance. Even better, the advanced MDX controller delivers these speeds regardless of data type, unlike some competing controllers that greatly favor compressible data.
• Capacity: 128GB
• Sequential Write: 390MB/s
• Random Read (QD32, 4KB): 97,000 IOPS
• Random Write (QD32, 4KB): 90,000 IOPS
• Random Read (QD1, 4KB): 9,800 IOPS
• Random Write (QD1, 4KB): 31,000 IOPS
• Active Power Use: 0.068W (down from 0.24W for 830 Series)
• Idle Power Use: 0.042W (down from 0.14W for 830 Series)
• Warranty: 5 Year
ORDER NOW
Samsung 250GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD250BW) @ £131.99 inc VAT
• Capacity: 250GB
• Sequential Read: 540MB/s
• Sequential Write: 250MB/s
• Random Read (QD32, 4KB): 96,000 IOPS
• Random Write (QD32, 4KB): 62,000 IOPS
• Warranty: 3 Year
Was £139.99 Inc. VAT
ORDER NOW
Startech 2-Port SATA III 6Gbps PCI-Express Controller Card (PEXSAT32) @ £26.99 inc VAT
The PEXSAT32 2-Port PCI Express SATA 6 Gbps (SATA 3.0) Controller Card offers simple connectivity between a host computer and SATA 3.0 devices - a cost-effective solution for connecting high-speed storage, such as High RPM Hard Drives and Solid State Drives (SSD), which in turn allows for easier data backups and archiving.
With full support for SATA 3.0 hard drives and data transfer speeds of up to 6 Gbps, the adapter card features a native PCI Express single chipset that provides enhanced compatibility, reliability and performance for external SATA 600 MB/s storage needs.
The controller card is backward compatible with SATA 2.0 devices, providing the versatility to use older storage, and features port multiplier capability with command-based and FIS-based switching for connecting multiple external hard drives to a host PC through a single external SATA connection.
A dual profile solution, the SATA 3.0 controller card includes a low profile bracket for installation in slimline or small form factor computer cases.
- Number of Ports: 2
- Includes normal and low profile backplate
- Max Data Transfer Rate: 6Gbp/s
- OS Compatability: XP, Vista, Windows 7, and Server 2008
- Lifetime Warranty
Was £31.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
OcUK Premium One Piece 8GB USB2.0 Stainless Steel Pen Drive @ £5.99 inc VAT
nonl2brPremium Stainless Steel single piece crafted 8GB Overclockers UK branded flash pen finished in a sophisticated champagne. Featuring speeds of up to 15Mb/s Read and 12Mb/s write along with a 5 year Warranty. Featuring Kingstons Flash technology the Overclockers UK flash drive delivers admirably in all aspects of performance, value and design.<br>
<br><br>
- Hi Speed USB 2.0 Compatible (backwards compatible to USB 1.1)<br>
- Easy plug and play functionality<br>
- Compatible with Windows® 7, Windows Vista®, Windows XP®, Windows 2000®, Windows® ME, Linux 2.4 and later, Mac® OS9, X and later<br>
- Portable and light weight (5.5 grams)<br>
- Up to 15Mb/s Read, 12Mb/s Write.<br>
- Lanyard or Keyring attachable<br>
- Dimensions: (LxWxD) 56x17x6mm <br>
- 5 Year Warranty<br>
- Capacity: 8GB<br>
<br><br>
<CENTER><IMG SRC="http://www.overclockers.co.uk/LP/images/transcend_chart.JPG" width="509" height="456"/></CENTER>
Was £6.49 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
OcUK Premium One Piece 16GB USB2.0 Stainless Steel Pen Drive @ £8.99 inc VAT
nonl2brPremium Stainless Steel single piece crafted 16GB Overclockers UK branded flash pen finished in a sophisticated champagne. Featuring speeds of up to 15Mb/s Read and 12Mb/s write along with a 5 year Warranty. Featuring Kingstons Flash technology the Overclockers UK flash drive delivers admirably in all aspects of performance, value and design.<br>
<br><br>
- Capacity: 16GB<br>
<br><br>
Was £9.98 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
Asus Z77 Sabertooth Intel Z77 (Socket 1155) DDR3 Motherboard @ £184.99 inc VAT
The new-generation ASUS SABERTOOTH Z77 with 32GB DDR3 memory features both the innovative Intel Z77 express chipset and Thermal Armor for precision cooling and unsurpassed reliability. The SABERTOOTH Z77 also features ASUS exclusive pioneering Dual Intelligent Processors 3 with SMART DIGI+ Power Control where 2 dedicated chips, the TPU and EPU provide an auto overclock and save energy through optimized power management, significantly boosting performance.
Another incredible feature is Fan Xpert 2 which enables the most customizable fan controls ever offered on a motherboard, while ASUS Wi-Fi GO! offers a future-proof and more convenient entertainment experience. Wi-Fi GO! can also convert PCs into routers and home entertainment becomes easier with Wi-Fi functions such as DLNA streaming, so users can enjoy content from a variety of devices.
Furthermore the ASUS SABERTOOTH Z77 includes support for both NVIDIA SLI and AMD CrossFireX which offer the ultimate in flexibility for 3D graphics. While LudicLogix Virtu MVP boots responsiveness, improves gaming frame rates by 30-70%, sharpens visual quality and works seamlessly with hundreds of game stations. Thus the SABERTOOTH Z77 takes motherboards to a whole new level!
Asus Exclusive Innovations:
· SMART DIGI+ Power Control
· Fan Xpert+
· Network iControl
· USB BIOS Flashback
· USB 3.0 Boost
· AI Suite II
Innovations:
· Quad GPU AMD CrossfireX - a flawless architecture accommodating the power of up to four graphics cards
· LudicLogix Virtu MVP - boots responsiveness, improves gaming frame rates by 30-70% and sharpens visual quality
Spec details:
SABERTOOTH Z77 V1.0
Note: The specifications are subject to change without notice.
CPU
LGA1155 socket for Intel® 3rd/2nd Generation Core™ i7/ i5/ i3/ Pentium® / Celeron® Processors
Supports 22/32nm CPU
Supports Intel® Turbo Boost Technology 2.0
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
** Refer to www.asus.com for CPU support list
Chipset
Intel® Z77 Express Chipset
Memory
4 x DIMM, Max. 32GB, DDR3 1866/1600/1333/1066 MHz, Non-ECC, un-buffered Memory
Dual channel memory architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs. Please refer to Memory QVL(Qualified Vendors List) for details.
** Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors List).
Expansion Slots
2 x PCI Express 3.0*/2.0 x16 slots (Single at x16, Dual at x8/x8)
1 x PCI Express 2.0 x16 slot** [black] (Max. at x4 mode, compatible with PCIe x1 and x4 devices)
3 x PCI Express 2.0 x1 slots
* PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
** The PCIe 2.0 x16 slot shares bandwidth with PCIe 2.0 x1_1 slot, PCIe 2.0 x1_2 slot and PCIe 2.0 x1_3 slot. The PCIe 2.0 x16 slot default setting is in x1 mode.
VGA
Integrated Graphics Processor- Intel® HD Graphics support
Multi-VGA output support: DisplayPort/HDMI port
Supports DisplayPort 1.1a with max. resolution 2560 x 1600@60Hz
Supports HDMI 1.4a with max. resolution 1920 x 1200@60Hz
Supports Intel® InTru™ 3D/Quick Sync Video/Clear Video HD Technology/Insider™
Maximum shared memory of 1696MB
Multi-GPU support
Supports NVIDIA® Quad-GPU SLI™ Technology
Supports AMD® Quad-GPU CrossFireX™ Technology
Supports LucidLogix Virtu MVP Technology*
* LucidLogix Virtu MVP supports Windows 7 operating systems.
Storage
Intel® Z77 Express Chipset:
- 2 x SATA 6Gb/s ports (brown) with RAID 0,1,5 and 10 support
- 4 x SATA 3Gb/s ports (black) with RAID 0,1,5 and 10 support
- Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology*
2 x ASMedia® 1061 SATA controllers**:
- 2 x SATA 6Gb/s ports (gray)
- 2 x eSATA 6Gb/s ports (red)
* Supports on Intel® Core™ processor family with Windows 7 operating systems.
** These SATA ports are for data hard drivers only. ATAPI devices are not supported.
LAN
Intel® 82579V Gigabit LAN controller
Audio
Realtek® ALC892 8-Channel High Definition Audio CODEC
- Absolute Pitch 192khz/24bit True BD Lossless Sound
- BD Audio Layer Content Protection
- Supports Jack-Detection, Multi-streaming, and Front Panel Jack-Retasking
- Optical S/PDIF out port at back I/O
USB
Intel®Z77 Express Chipset- supports ASUS USB 3.0 Boost UASP Mode.*
- 4 x USB 3.0 ports(2 ports at mid-board, 2 ports at back panel)
ASMedia® 1042 USB 3.0 controller- supports ASUS USB 3.0 Boost UASP Mode.
- 2 x USB 3.0 ports at back panel (blue)
- 10 x USB 2.0/1.1 ports (6 ports at mid-board, 4 ports at back panel)
*The USB 3.0 ports only support Windows® 7 or later versions. UASP standard only supports Windows® 8
Exclusive TUF Features
"Ultimate COOL!" Thermal Solution
- TUF Thermal Armor
- TUF Thermal Radar
"TUF ENGINE!" Power Design
- 8+4+2 Digital Phase Power Design
- TUF Components (Choke, Cap & MOSFET; certified by military-standard)
- ASUS DIGI+ Power Control Utility
"Safe & Stable!" Guardian Angel
- ESD Guards
- MemOK!
- Anti Surge
- Dust Defender
Other Special Features
- USB 3.0 Boost featuring the latest USB 3.0 UASP standard
- USB BIOS Flashback with USB BIOS Flashback Wizard for EZ BIOS download scheduling
- USB Charger+ featuring quick-charging function for all smart devices
- Network iControl featuring instant network bandwidth domination for top network program in use
- Lucid Virtu MVP
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- AI Suite II
- ASUS Q-Connector
- ASUS Q-Shield
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS MyLogo 2
- Multi-language BIOS
Back Panel I/O Ports
1 x DisplayPort
1 x HDMI port
1 x Optical S/PDIF Output
1 x USB BIOS Flashback Button
1 x LAN (RJ45) port
4 x USB 3.0/2.0 ports (blue, 1 supports USB BIOS Flashback)
4 x USB 2.0/1.1 ports
8-channel Audio I/O ports
Internal I/O Connectors
1 x USB 3.0/2.0 connector supports additional 2 USB 3.0/2.0 ports (19-pin; moss green)
3 x USB 2.0/1/1 connectors support additional 6 USB 2.0/1.1 ports
4 x SATA 6Gb/s connectors (2 x brown; 2 x gray)
4 x SATA 3Gb/s connectors (black)
1 x CPU Fan connector (4-pin Black)
1 x CPU OPT Fan connector (4-pin Black)
4 x Chassis Fan connectors (4-pin Black)
2 x Assistant Fan connector (3-pin White)
Front panel audio connector(AAFP)
1 x S/PDIF Out header
1 x Thunderbolt header
24-pin EATX Power connector
8-pin EATX 12V Power connector
System Panel (Q-Connector)
1 x MemOK! button
1 x Clear CMOS jumper
BIOS
64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function, F3 Shortcut Function and ASUS DRAM SPD (Serial Presence Detect) memory information
Manageability
WfM 2.0, DMI 2.0, WOL by PME, PXE
Accessories
2 x Serial ATA 6Gb/s cables
2 x Serial ATA 3Gb/s cables
1 x ASUS SLI bridge connector 7cm
1 x ASUS Q-Shield
1 x 2 in 1 Q-connector
2 x Accessory Fans(35mm)
1 x Accessory Package
- 1 x 40mm I/O Cover fan lid
- 3 x PCIe x16 slot dust covers
- 2 x DRAM slot dust covers
- 3 x PCIe x1 slot dust covers
- 2 x Short fan screws
- 4 x Long fan screws
- 1 x Adhesive Sponge for 35mm Fan
1 x TUF Inside sticker
1 x TUF Certification card
1 x TUF 5 Year Warranty manual (by region)
Thermal Armor Accessory Installation Guide
User's manual
Support DVD
Drivers
Anti-virus software (OEM version)
ASUS Update
ASUS Utilities
Form Factor
ATX Form Factor, 12”x 9.6” (30.5cm x 24.4cm)
Was £188.99 Inc. VAT
Only £184.99 inc VAT.
ORDER NOW
Asus P8B WS Intel C206 (Socket 1155) DDR3 Motherboard @ £179.99 inc VAT
The ASUS Workstation Series is the ideal foundation for a powerful PC. It delivers awesome power, dependable performance and unparallel multiple I/O scalability for the most demanding tasks and future upgrades. It intelligently reduces operation noise and dissipates heat through advanced and environmentally friendly methods to accommodate user needs. ASUS Workstation Series motherboards also bring you ultimate reliability and quality through our 24x24 initiative, which means 24 hour operation and a 24-month life cycle supply guarantee. Let the ASUS Workstation Series improve the quality of your work and life.
CPU
- Intel® Socket 1155 for 3rd/2nd Generation Core™ i7/Core™ i5/Core™ i3 Processors
- Intel® Socket 1155 for Intel® E3-1200/12x5 v2 processors
- Intel® Socket 1155 for Intel® E3-1200/12x5 processors
- Supports Intel® 32 nm CPU
- Supports Intel® Turbo Boost Technology 2
Chipset
- Intel® C206
Memory
- 4 x DIMM, Max. 32GB, DDR3 1600/1333/1066 MHz ECC, Non-ECC, Un-buffered Memory *1
- Dual Channel Memory Architecture
- Supports Intel® Extreme Memory Profile (XMP)
* Refer to www.asus.com or user manual for the Memory QVL (Qualified Vendors Lists).
* Non-ECC, Un-buffered memory only support for client OS (Windows7,Vista and XP).
Graphic
- Integrated Graphics Processor *2
- VGA output support : DVI port
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
- Maximum shared memory of 1748 MB
Multi-GPU Support
- Supports AMD Quad-GPU CrossFireX™ Technology
Expansion Slots
- 2 x PCIe 3.0/2.0 x16 (x16 or dual x8, black+blue) *3
- 2 x PCIe 2.0 x16 (x4 mode, white)
- 1 x PCIe x1
- 1 x PCI
Storage
- Intel® C206 chipset : 2 x SATA 6Gb/s port(s), gray
- Intel® C206 chipset : 4 x SATA 3Gb/s port(s), blue
- Support Raid 0, 1, 5, 10
LAN
- Intel® 82574L, 2 x Gigabit LAN Controller(s)
Audio
- Realtek® ALC892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- Audio Feature :
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
IEEE 1394
- VIA® 6308S controller
- 2 x IEEE 1394a port(s)
USB Ports
- Built-in Controller : 2 x USB 3.0 port(s) (2 at back panel, blue)
- Intel® C206 chipset : 14 x USB 2.0 port(s) (6 at back panel, gray, 8 at mid-board)
Workstation Feature
- 4 x PCIe x 16 slot(s)
- G.P. Diagnosis Card bundled
- Quick Gate: 2 x vertical USB 2.0 on board
- ASUS SASsaby series Cards support
- ASUS WS Diag. LED
Special Features
- ASUS EPU :
- EPU switch
- ASUS Power Design :
- 8 +2 Phase Power Design
- GPU Boost with switch
- ASUS Exclusive Features :
- MemOK!
- AI Suite II
- Anti-Surge
- ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert
- ASUS EZ DIY :
- ASUS EZ Flash
- ASUS Q-Design :
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports
- 1 x PS/2 keyboard/mouse combo port(s)
- 1 x DVI-I
- 1 x IEEE 1394a
- 2 x LAN (RJ45) port(s)
- 2 x USB 3.0
- 6 x USB 2.0
- 1 x Coaxial S/PDIF out
- 1 x Optical S/PDIF out
- 6 x Audio jack(s)
Internal I/O
- 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
- 2 x Vertical USB 2.0 port(s)
- 1 x TPM connector(s)
- 1 x COM port(s) connector(s)
- 1 x IEEE 1394a connector(s)
- 1 x CPU Fan connector(s)
- 1 x Power Fan connector(s)
- 1 x S/PDIF out header(s)
- 1 x 24-pin EATX Power connector(s)
- 1 x 8-pin ATX 12V Power connector(s)
- 1 x Front panel audio connector(s) (AAFP)
- 1 x System panel(s)
- 1 x MemOK! button(s)
BIOS
- 32MB flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.6, ACPI 2.0a, multi-language BIOS, ASUS EZ Flash Utility, ASUS CrashFree BIOS 3
Manageability
- WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Operating System
- Fedora 13
- Windows® Server 2008 R2 Enterprise
- Windows® Server 2008 Enterprise 32/64-bit
- Windows® Server 2003 R2 Enterprise 32/64-bit
- Windows® 7 32/64-bit
- Windows® Vista 32/64-bit
- Windows® XP 32/64-bit
- RedHat® Enterprise Linux WS 6.0 32/64-bit
- Open SUSE 11.4
- Ubuntu Desktop 10.04
Form Factor
- ATX Form Factor
- 12 inch x 9.6 inch ( 30.5 cm x 24.5 cm )
Was £184.99 Inc. VAT
ORDER NOW
Gigabyte Z77X-UP4 TH Intel Z77 (Socket 1155) DDR3 Motherboard @ £161.99 inc VAT
nonl2br<p><font face="Arial" color="#0066CC" size="4"><b>Special Features / Z77X-UP4<font color="#00CCFF">TH</font><br>
</b><font color="#000000" size="2"><br>
GIGABYTE 7 series motherboards combine a host of new and exciting technologies
with the latest Intel Z77 Express Chipset, creating a unique range of motherboard
designs that harness the outstanding performance of the new 3rd generation Intel®
Core™ processors. With an exclusive 'All Digital' VRM design, GIGABYTE
3D Power and GIGABYTE 3D BIOS (Dual UEFI), GIGABYTE 7 series motherboards ensure
exceptional power delivery and absolute control, with additional features that
ensure an unrivalled experience on your next PC build. </font></font></p>
<table style="border-width: 0 0 1px 1px; border-spacing: 0; border-collapse: collapse; border-style: solid; border-color: #dcdcdc;" width="95%" border="0" cellspacing="0" align="center">
<tr valign="middle">
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px" height="59"><img src="http://img830.imageshack.us/img830/9393/intelb.jpg" width="82" height="50"></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="*" height="59">
<font face="Arial" color="#0066CC" size="2">Support for the new INTEL 3rd
Generation CPU's. <font color="#000000">On the socket 1155 platform.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 0 1px 0 1px; border-style: solid; border-color: #dcdcdc;" width="5px" height="59"> </td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px" height="59"><img src="http://img853.imageshack.us/img853/8321/usbpower3.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">USB 3x Power Boost. <font color="#000000">Delivering
greater device compatibility and faster charge times.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img803.imageshack.us/img803/491/ud5e.jpg" width="82" height="50"></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="*">
<font size="2" face="Arial" color="#0066CC">Ultra Durable 5. <font color="#000000">Super
high rated Ferrite Core Chokes (60A). 2x Copper PCB and IR3550 IC's in the
CPU power zone for the coolest temperatures ever.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 0 1px 0 1px; border-style: solid; border-color: #dcdcdc;" width="5px"> </td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img16.imageshack.us/img16/957/usb3.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Super Speed USB 3.0. <font color="#000000">Super
fast transfer rates of up to 5 Gbps, 10x faster than USB 2.0.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img3.imageshack.us/img3/6383/virtumvp.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Lucid Virtu MVP. <font color="#000000">Producing
faster frame rates, with sharper visuals and reduced tearing.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img17.imageshack.us/img17/2311/sata3b.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Super SATA3 Native Suport. <font color="#000000">Supporting
super fast 6Gbps link speeds.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img62.imageshack.us/img62/4753/crossfiresli.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">NVIDIA SLI and AMD Crossfirex.
<font color="#000000">For multi display or ultimate performace gaming.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img694.imageshack.us/img694/3946/gen3v.jpg" width="82" height="50"></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="*"><font face="Arial" size="2" color="#0066CC">PCIe
GEN 3. <font color="#000000">Designed to take full advantage of the next
generation high bandwidth graphic card solutions.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="5px"><img src="http://img29.imageshack.us/img29/5711/dualeufibios.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">UEFI DualBIOS™. <font color="#000000">A
superior graphical BIOS interface, based on the trusted and secure GIGABYTE
Dual BIOS technology.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img803.imageshack.us/img803/5448/onoffcharge.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">ON/OFF Charge Technology. <font color="#000000">Allows
you to charge your iPad, iPhone or iPod even of your PC is off.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="5px"><img src="http://img220.imageshack.us/img220/2125/msata.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Onboard mSATA Connector. <font color="#000000">Mount
a low capcity mSATA SSD onto your motherboard to take advantage of INTEL
SRT and RAPID START.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img822.imageshack.us/img822/9665/dualthunderbolt.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Dual Thunderbolt. <font color="#000000">Daisy
chain up to 12 devices + 2 display monitors and transfer 1TB of data in
only 5 minutes!</font></font></td>
</tr>
</table>
<p><font face="Arial" color="#0066CC" size="2"><b><font size="4">Tech Spec / </font><font face="Arial" color="#0066CC" size="4"><b>Z77X-UP4<font color="#00CCFF">TH</font></b></font></b><font size="2">
</font><font face="Arial" color="#0066CC" size="2"><font size="2"><a href="http://uk.gigabyte.com/products/product-page.aspx?pid=4139#sp">[Click
for Complete/Advanced]</a></font></font></font></p>
<table style="border-width: 0 0 1px 1px; border-spacing: 0; border-collapse: collapse; border-style: solid; border-color: #dcdcdc;" cellpadding="0" cellspacing="0" width="95%" align="center" border="0" >
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" " align="left" width="114" height="26">
<font face="Arial" size="2" color="#0066CC">CPU</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="26">
<font face="Arial" size="2">Support for Intel Core i7, i5, i3, Pentium and
Celeron 1155 processors<font size="1">(Go to GIGABYTE's website for the
latest CPU support list.)</font></font> </td>
</tr>
<tr valign="middle" >
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114">
<font face="Arial" size="2" color="#0066CC">Chipset</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089">
<font face="Arial" size="2">Intel Z77 Express Chipset</font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="27"><font face="Arial" size="2" color="#0066CC">Memory</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="27">
<font face="Arial" size="2">4x DDR3 1600/1333/1066 MHz memory modules <br>
<font size="1">* Due to Windows 32-bit operating system limitation, when
more than 4 GB of physical memory is installed, the actual memory size displayed
will be less than 4 GB. </font></font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="27"><font face="Arial" size="2" color="#0066CC">Onboard
Graphics </font></td>
<font face="Arial" size="2">1x D-Sub, 1x DVI-D (1920x1200 max res), 1x HDMI
(1920x1200 max res), 2 x Thunderbolt ports (MDP1/MDP2)</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="24"><font face="Arial" size="2" color="#0066CC">Audio</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="24">
<font face="Arial" size="2">Realtek ALC892 HD Audo 2/4/5.1/7.1 S/PDIF In
& Out </font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="24"><font face="Arial" size="2" color="#0066CC">Multi-Graphics</font></td>
<font face="Arial" size="2">Support for AMD CrossfireX/NVIDIA SLI Technology</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="27"><font face="Arial" size="2" color="#0066CC">LAN</font></td>
<font face="Arial" size="2">1 x Realtek Gbe LAN chip</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="57">
<font face="Arial" size="2" color="#0066CC">Expansion Slots</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="57">
<p><font face="Arial" size="2">1 x PCI Express x16 slots, running at x16<font size="1"><br>
</font><font face="Arial" size="2">1 x PCI Express x16 slots, running
at x8</font><font size="1"><br>
</font><font face="Arial" size="2"><font face="Arial" size="2">1 x PCI
Express x16 slots, running at x4</font></font><font size="1"><br>
</font>3x PCI Express x1 slot<br>
</font> <font face="Arial" size="2">1x PCI slots </font> </p>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="51"><font face="Arial" size="2" color="#0066CC">Storage
Interface</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="51">
<p><font face="Arial" size="2">2 x SATA 6Gb/s connectors<br>
4 x SATA 3Gb/s connectors <br>
1 x mSATA 3Gb/s (Disables sata connector 5 when in use)</font></p>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="43"><font face="Arial" size="2" color="#0066CC">USB</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="43"><font face="Arial" size="2">USB
3.0/2.0 : </font> <font face="Arial" size="2"> 6 x on the back panel, 2x
via USB brackets on headers<br>
</font> <font face="Arial" size="2">USB 2.0/1.1 : </font> <font face="Arial" size="2">6
x via USB brackets on headers</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Internal
I/O Connectors</font></td>
<font face="Arial" size="2">1 x 24-pin ATX main power connector, </font>
<font face="Arial" size="2">1 x 8-pin ATX 12V power connector,</font> <font face="Arial" size="2">2
x SATA 6Gb/s connector, 4 x SATA 3GB/s connectors, 1 x mSATA connector,</font>
<font face="Arial" size="2">1 x CPU fan header, </font> <font face="Arial" size="2">4
x system fan headers, </font> <font face="Arial" size="2"> 1 x front panel
header, </font> <font face="Arial" size="2">1 x front panel audio header,
</font> <font face="Arial" size="2">1 x S/PDIF Out header, </font> <font face="Arial" size="2">1
x S/PDIF In header, 3 x USB 2.0/1.1 headers,</font> <font face="Arial" size="2">1
x USB 3.0/2.0 headers,1 x clearing CMOS jumper, 1 x TPM header, 1 x Serial
port header.</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Back
Panel Connectors</font></td>
<font face="Arial" size="2">1 x PS/2 KB/Mouse port, 1 x D-Sub, 1 x DVI-D,
1 x HDMI, 2 x Thunder Bolt,</font> <font face="Arial" size="2">1 x Optical
S/PDIF Out connector, </font> <font face="Arial" size="2">6 x USB 3.0/2.0
ports,1 x RJ-45 ports, </font> <font face="Arial" size="2">5x audio jacks
</font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">BIOS</font></td>
<font face="Arial" size="2">2 x 64 Mbit AMI EFI BIOS,</font> <font face="Arial" size="2">Support
for DualBIOS™</font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Form
Factor</font></td>
<font face="Arial" size="2">ATX Form Factor; 30.5 x 24.4cm</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Warranty</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089"><font face="Arial" size="2">3
Year Gigabyte Warranty</font></td>
</tr>
</table>
Was £167.99 Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard @ £82.99 inc VAT
nonl2br
<br />
<p><font face="Arial" color="#0066CC" size="4"><b>Special Features / Z77-D3H<br>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img694.imageshack.us/img694/2274/ultradurable4classic.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Ultra Durable 4 Classic. <font color="#000000">Advanced
temprature, humidity, electrostatic and power failure protection... The
ultimate in reliability.</font></font></td>
</tr>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img30.imageshack.us/img30/6495/crossfirej.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">AMD Crossfirex. <font color="#000000">For
</tr>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"> </td>
<font size="2" face="Arial" color="#0066CC"></font></td>
</tr>
</table>
<p><font face="Arial" color="#0066CC" size="2"><b><font size="4">Tech Spec / </font><font face="Arial" color="#0066CC" size="4"><b>Z77-D3H</b></font></b><font size="2">
</font><font face="Arial" color="#0066CC" size="2"><font size="2"><a href="http://uk.gigabyte.com/products/product-page.aspx?pid=4140#sp">[Click
</tr>
</tr>
</tr>
(1920x1200 max res)</font></td>
</tr>
<font face="Arial" size="2">VIA VT2021 codec High Definition Audio 2/4/5.1/7.1-channel
w/ Support for S/PDIF Out</font> </td>
</tr>
<font face="Arial" size="2">Support for AMD CrossfireX</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="24"><font face="Arial" size="2" color="#0066CC">LAN</font></td>
<font face="Arial" size="2">1 x Atheros GbE chip (10/100/1000 Mbit) </font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="58">
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="58">
</font> <font face="Arial" size="2">2x PCI slots </font> </p>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="41"><font face="Arial" size="2" color="#0066CC">Storage
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="41">
</td>
</tr>
3.0/2.0 : </font> <font face="Arial" size="2">4x on the back panel, 2x via
</font> <font face="Arial" size="2">USB 2.0/1.1 : </font> <font face="Arial" size="2">4x
on the back panel, 6x via USB brackets on headers</font></td>
</tr>
<font face="Arial" size="2">1 x 4-pin ATX 12V power connector,</font> <font face="Arial" size="2">2
<font face="Arial" size="2">1 x CPU fan header, </font> <font face="Arial" size="2">3
</font> <font face="Arial" size="2">1 x S/PDIF Out header, </font> <font face="Arial" size="2">3
x USB 2.0/1.1 headers,</font> <font face="Arial" size="2">1 x USB 3.0/2.0
headers,1 x clearing CMOS jumper, 1 x TPM header, 1 x Serial port header</font></td>
</tr>
<font face="Arial" size="2">1 x PS/2 keyboard/mouse port, 1 x D-Sub, 1 x
DVI-D, 1 x HDMI, 1 x Optical S/PDIF Out connector, </font> <font face="Arial" size="2">4
x USB 3.0/2.0 ports,</font> <font face="Arial" size="2">4 x USB 2.0/1.1
</font> </td>
</tr>
</tr>
Factor</font></td>
</tr>
</tr>
</table>
Was £89.99 Inc. VAT
Only £82.99 inc VAT.
ORDER NOW
Gigabyte Z77N-WIFI Intel Z77 (Socket 1155) DDR3 Mini ITX Motherboard @ £94.99 inc VAT
The New Z77N-WIFI from Gigabyte gives you all the features of a fully overclockable Z77 chipset with the mini form factor of M-ITX making it perfect for a high end ultra compact PC.
CPU
Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
L3 cache varies with CPU
(Some Intel® Core™ processors require a graphic card, please refer "CPU support List" for more information.)
Chipset
Memory
2 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory
* Due to a Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than the size of the physical memory installed.
Support for DDR3 1600/1333/1066/800 MHz memory modules
Support for non-ECC memory modules
Support for Extreme Memory Profile (XMP) memory modules
(Please refer "Memory Support List" for more information.)
Onboard Graphics Integrated Graphics Processor:
1 x DVI-I port, supporting a maximum resolution of 1920x1200
2 x HDMI ports, supporting a maximum resolution of 1920x1200
Audio
Realtek ALC892 codec
2/4/5.1/7.1-channel
LAN
2 x Realtek GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
1 x PCI Express x16 slot, running at x16
(The PCIEX16 slot conforms to PCI Express 3.0 standard.)
* Whether PCI Express 3.0 is supported depends on CPU and graphics card compatibility.
Storage Interface Chipset:
2 x SATA 6Gb/s connectors (SATA3 0/1) supporting up to 2 SATA 6Gb/s devices
2 x SATA 3Gb/s connectors (SATA2 2/3) supporting up to 2 SATA 3Gb/s devices
Support for RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
USB Chipset:
Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header)
Up to 6 USB 2.0/1.1 ports (4 ports on the back panel, 2 ports available through the internal USB header)
1 x serial port header
1 x USB 3.0/2.0 header
2 x USB 2.0/1.1 headers
1 x CPU fan header
1 x system fan header
1 x front panel header
Back Panel Connectors
2 x HDMI ports
2 x antenna connectors
1 x DVI-I port
2 x USB 3.0/2.0 ports
2 x RJ-45 ports
1 x optical S/PDIF Out connector
5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Line In, Line Out, Mic In)
I/O Controller
iTE I/O Controller Chip
H/W Monitoring
System voltage detection
CPU/System temperature detection
CPU/System fan speed detection
CPU fan speed control
* Whether the CPU fan speed control function is supported will depend on the CPU cooler you install.
BIOS
2 x 64 Mbit flash
Use of licensed AMI EFI BIOS
Support for DualBIOS™
PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
Unique Features
Support for @BIOS
Support for Q-Flash
Support for Xpress Install
Support for EasyTune
* Available functions in EasyTune may differ by motherboard model.
Support for eXtreme Hard Drive (X.H.D)
Support for Auto Green
Support for ON/OFF Charge
Support for Q-Share
Support for EZ Setup
Bundle Software
Norton Internet Security (OEM version)
Operating System
Support for Microsoft® Windows 8/7/XP
Form Factor
Mini-ITX Form Factor; 17.0cm x 17.0cm
Was £98.99 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
Asus P8H61-MX USB 3.0 Intel H61 (Socket 1155) DDR3 Motherboard - OEM ** @ £39.95 inc VAT
** Part comes as board, I/O, SATA Cable, Manual and driver disc only. No Retail box.
This motherboard supports the Intel® 3rd/2nd generation processors in the LGA1155 package, with iGPU, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, 2-channel (4 DIMM) DDR3 memory and 16 PCI Express 3.0/2.0 lanes. This provides great graphics performance. Intel® 3rd/2nd generation processors are among the most powerful and energy efficient CPUs in the world.
The Intel® H61 Express Chipset is a single-chipset design to support socket 1155 Intel® 3rd/2nd generation processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, H61 chipset provides 4 USB 3.0 ports for 10 times faster data retrieval speed. Moreover, Intel® H77 Express Chipset can also enable iGPU function, letting users enjoy the latest Intel® integrated graphic performance.
Intel® Smart Response Technology boosts overall system performance. It uses an installed fast SSD (min 18.6GB available capacity required) as a cache for frequently accessed data. Key benefits include reduced load and wait times, and lower power consumption through the elimination of unnecessary hard drive spin. This technology combines SSD performance with hard drive capacity, operating up to 6X faster than a hard drive-only system.
Your computer can receive web updates with fresh content for selected applications, even when the system is in sleep mode. This means less time waiting for applications to update and sync with the cloud, leading to a more efficient computing experience.
Allows your computer to quickly resume from a low-power hibernate state in seconds. Saving your system memory to the designated SSD, it provides your computer a faster wake-up response time, while still keeping the energy use low.
Specifications:
CPU: Intel® Socket 1155 for 3rd/2nd Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
Supports Intel® 22 nm CPU
Chipset: Intel® H61
Memory: 2 x DIMM, Max. 16GB, DDR3 2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333 MHz Memory
* 1600MHz and higher frequency is supported by Intel® 3rd generation processors.
* Due to OS limitation, when installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Install a 64-bit Windows® OS when you want to install 4GB or more memory on the motherboard.
* Due to the CPU behavior, DDR3 2133/1866MHz memory module will run at DDR3 2000/1800MHz frequency as default.
Graphics: Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
Multi-GPU Support Supports LucidLogix® Virtu™ MVP Technology *1
Expansion Slots:
1 x PCIe 3.0/2.0 x16
1 x PCIe 2.0 x4
1 x PCIe 2.0 x1
1 x PCI
Storage:
Intel® H77 chipset :
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *3
LAN: Realtek® 8111F, 1 x Gigabit LAN Controller(s)
Audio: Realtek® ALC887 8-Channel High Definition Audio CODEC
USB Ports Intel® H61 chipset :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
10 x USB 2.0 port(s) (4 at back panel, black, 6 at mid-board)
Special Features ASUS EPU :
- EPU
ASUS Digital Power Design :
- ASUS DIGI+ VRM Utility
GPU Boost
- MemOK!
- Anti-Surge
- USB 3.0 Boost
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS EZ Flash 2
- ASUS MyLogo 2
100% All High-quality Conductive Polymer Capacitors
Back I/O Ports 1 x PS/2 keyboard/mouse combo port(s)
1 x DVI
1 x D-Sub
1 x HDMI
1 x LAN (RJ45) port(s)
2 x USB 3.0
4 x USB 2.0
3 x Audio jack(s)
Internal I/O Ports 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s)
4 x SATA 3Gb/s connector(s)
1 x Chassis Fan connector(s)
1 x Internal speaker connector(s)
1 x System panel(s)
1 x Chassis Intrusion connector(s)
BIOS 64Mb Flash ROM, AMI BIOS, PnP, DMI v2.0, WfM2.0, SMBIOS v2.5, ACPI v2.0a
Manageability WOL, PXE, PME Wake Up
Form Factor uATX Form Factor
9.6 inch x 8.2 inch ( 24.4 cm x 20.8 cm )
Was £43.99 Inc. VAT
Only £39.95 inc VAT.
ORDER NOW
Gigabyte H61MA-D2V Intel H61 (Socket 1155) DDR3 Motherboard @ £41.99 inc VAT
nonl2br
<p><font face="Arial" color="#0066CC" size="4"><b>Special Features / H61MA-D2V</b></font></p>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img830.imageshack.us/img830/9393/intelb.jpg" width="82" height="50"></td>
<font face="Arial" color="#0066CC" size="2">For INTEL® 1155 Processors.
<font color="#000000">The latest CPU technology.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img853.imageshack.us/img853/8321/usbpower3.jpg" width="82" height="50"></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img444.imageshack.us/img444/5711/dualeufibios.jpg" width="82" height="50"></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="*"><font size="2" face="Arial" color="#0066CC">GIGABYTE
Dual EUFI BIOS. <font color="#000000">A new innovative way to modify BIOS
settings.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img151.imageshack.us/img151/9414/dvih.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">DVI Output. <font color="#000000">Compatible
with HDCP.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img836.imageshack.us/img836/8124/ud4so.jpg " width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Ultra Durable 4. <font color="#000000">Next
generation high quality components.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="5px"><img src="http://img403.imageshack.us/img403/2329/japcaps.jpg " width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">50,000 Hours Japanese Solid
Capacitors. <font color="#000000">Delivering solid stability, reliability
and longevity.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="5px"><img src="http://img694.imageshack.us/img694/3946/gen3v.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">PCI Express Gen.3 Support. <font color="#000000">Delivering
maximum bandwidth for the latest graphics cards.</font></font></td>
</tr>
</table>
<p><font face="Arial" color="#0066CC" size="2"><b><font size="4">Tech Spec / </font><font face="Arial" color="#0066CC" size="4"><b>H61MA-D2V</b></font></b><font size="2">
</font><font face="Arial" color="#0066CC" size="2"><font size="2"><a href="http://uk.gigabyte.com/products/product-page.aspx?pid=4183#sp">[Click
<font face="Arial" size="2">Support for Intel<sup>Ž</sup> Core? i7/ i5 /
i3 / Pentium and Celeron<sup>Ž</sup>, Socket 1155 <font size="1">(Go to
GIGABYTE's website for the latest CPU support list.)</font></font> </td>
</tr>
<font face="Arial" size="2">Intel<sup>Ž</sup> H61 Express Chipset</font>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="27"><font face="Arial" size="2" color="#0066CC">Video</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="27"><font face="Arial" size="2">1x
DVI, 1x D-SUB</font></td>
</tr>
<font face="Arial" size="2">2x DDR3 1333/1066/800 MHz memory modules <br>
</tr>
<font face="Arial" size="2">Realtek ALC887 codec High Definition Audio 2/4/5.1/7.1-channel</font></td>
</tr>
<font face="Arial" size="2">1 x Realtek 8111E (10/100/1000 Mbit) </font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="56">
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="56">
(To support PCI-E Gen3, you must install 22nm CPU / Ivybridge)<br>
</font>3x PCI Express x1 slot</font></p>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="19"><font face="Arial" size="2" color="#0066CC">Storage
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="19">
<p><font face="Arial" size="2">4x SATA 3Gb/s connectors</font></p>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="43"><font face="Arial" size="2">Chipset:
</font> <font face="Arial" size="2">4x on the back panel, 4x via USB brackets
on headers<br>
</font> <font face="Arial" size="2">Etron EJ168 chip: </font> <font face="Arial" size="2">2
USB 3.0/2.0 ports on the back panel</font></td>
</tr>
<font face="Arial" size="2">1 x 4-pin ATX 12V power connector,</font> <font face="Arial" size="2">4
x SATA 3Gb/s connector,</font> <font face="Arial" size="2">1 x CPU fan header,
</font> <font face="Arial" size="2">1 x system fan headers,</font> <font face="Arial" size="2">1
x front panel header, </font> <font face="Arial" size="2">1 x front panel
audio header</font><font face="Arial" size="2">, </font> <font face="Arial" size="2">2</font><font face="Arial" size="2">
x USB 2.0/1.1 headers,</font> <font face="Arial" size="2">1 x clearing CMOS
jumper.</font></td>
</tr>
<font face="Arial" size="2">1 x PS/2 keyboard/mouse port, </font> <font face="Arial" size="2">1
x D-SUB, 1 x DVI,, </font> <font face="Arial" size="2">4x USB 2.0/1.1 ports,
</font> <font face="Arial" size="2">2x USB 3.0/2.0 ports</font><font face="Arial" size="2">,
</font> <font face="Arial" size="2">1 x RJ-45 ports, </font> <font face="Arial" size="2">3x
audio jacks </font> </td>
</tr>
<font face="Arial" size="2">2 x 32 Mbit AWARD BIOS </font> <font face="Arial" size="2">Support
for DualBIOS?</font> </td>
</tr>
Factor</font></td>
<font face="Arial" size="2">Mico ATX Form Factor; 24.4cm x 17.4cm</font>
</td>
</tr>
</tr>
</table>
Was £44.99 Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
Gigabyte 970A-DS3 AMD 970A (Socket AM3+) DDR3 Motherboard @ £56.99 inc VAT
The 970A-DS3 motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via the GIGABYTE 333 onboard acceleration technologies. Featuring the USB3.0 controller, AMD 900 series motherboards allow users to take advantage of super fast USB transfer rates of up to 5Gbps, delivering 10x faster data transfer compared to USB 2.0. Utilizing the industry's first Serial ATA Revision 3.0 solution via AMD SB950 chipset, GIGABYTE AMD 900 series motherboards offer native 6 ports of next generation high speed data storage devices support with data transfer speeds of up to 6 Gbps with RAID 0, 1, 5, 10. The AMD 900 series motherboards introduce a unique hardware design with lower resistance fuses for ensuring lower voltage drops and providing more stable and plentiful power delivery. All USB ports also benefit from a 3x power boost for better power delivery to power hungry USB devices.
• On/Off Charge Technology
• Get Ready for New Generation of 32nm AMD AM3+ CPU
• Supports next generation of 45nm AMD AM3 CPU
• SATA 6 Gbps Support
• USB 3.0 Support
Form Factor: ATX
Graphics Interface: PCIe 2.0 (x16)
CPU Socket: AM3+
SLI: No
QPI Speed: N/A
System Bus: 4800MT/s
Hybrid SLI: No
Chipset: AMD 970
Hybrid Crossfire: No
Memory Type: DDR3
Crossfire: No
Memory Channel: Dual
Water Cooled: No
Memory Type (ECC): Non-ECC
SATA: SATA III - 6Gb/s
Memory Type (R/U): Unbuffered
RAID: SATA
Memory Speed (Mhz): DDR3 - 1066, DDR3 - 1333, DDR3 - 1600, DDR3 - 1866, DDR3 - 2000(OC)
Expansion Slots: 2 x PCI (32 bit), 1 x PCIe 2.0 x16, 1 x PCIe 2.0 x16 (x4 Bandwidth), 3 x PCIe x1
Memory Capacity: 32GB
Internal I/O: 1 x 24pin (V), 1 x 4pin (V), 1 x FP Audio Header, 6 x SATA III - 6Gb/s, 1 x SPDIF-Out Header, 3 x USB 2.0 Header
Graphics On Board: No
Back Panel: 1 x 10/100/1000 (LAN), 1 x Line In, 1 x Line Out, 1 x Mic In, 1 x PS/2 Keyboard/Mouse Combo, 6 x USB 2.0, 2 x USB 3.0
Was £59.99 Inc. VAT
Only £56.99 inc VAT.
ORDER NOW
Gigabyte 78LMT-USB3 AMD 760G (Socket AM3+) DDR3 Motherboard @ £39.95 inc VAT
The 78LMT-USB3 motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via revolutionary GIGABYTE Ultra Durable technology. Based on AMD 760G chipset, the 78LMT-USB3 supports the latest 45nm AMD AM3 Phenom II/ Athlon II processors, integrated DDR3 memory controller, HyperTransport™ 3.0 technology links and PCI Express 2.0 graphics interfaces for ATI Hybrid CrossFireX support. The 78LMT-USB3 is able to provide user friendly computing, reach the maximum system performance easily while still able to save the power and environment in real life at the same time.
GIGABYTE's AMD motherboards are ready to support new generation of 32nm AMD AM3+ multi-core processors, delivering the very best platform for multitasking, multimedia and high performance gaming.
CPU AM3+ Socket:
Support for AMD AM3+ processor
Support for AMD AM3 Phenom™ II processor / AMD Athlon™ II processor
(Please refer "CPU Support List" for more information.)
Hyper Transport Bus
4400 MT/s
Chipset
North Bridge: AMD 760G
South Bridge: AMD SB710
Memory
4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory (Note 1)
Support for 1333+ (O.C.)/1066 MHz memory modules
Onboard Graphics North Bridge:
1 x D-Sub port
1 x DVI-D port, supporting a maximum resolution of 1920x1200 (Note 2)
1 x HDMI port, supporting a maximum resolution of 1920x1200 (Note 3)
Audio
2/4/5.1/7.1-channel (Note 4)
LAN
1 x Realtek GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
1 x PCI Express x1 slot
(All PCI Express slots conform to PCI Express 2.0 standard.)
1 x PCI slot
Storage Interface South Bridge:
1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
6 x SATA 3Gb/s connectors supporting up to 6 SATA 3Gb/s devices
Support for RAID 0, RAID 1, RAID 10, and JBOD
USB South Bridge:
Up to 8 USB 2.0/1.1 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
2 x Etron EJ168 chips:
1 x IDE connector
1 x CPU fan header
1 x parallel port
1 x D-Sub port
1 x DVI-D port
1 x HDMI port
1 x RJ-45 port
3 x audio jacks (Line In/Line Out/Microphone)
I/O Controller
H/W Monitoring
CPU overheating warning
CPU/System fan fail warning
CPU/System fan speed control (Note 5)
BIOS
2 x 16 Mbit flash
Use of licensed AWARD BIOS
PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
Unique Features
Support for @BIOS
Support for Q-Flash
Support for Xpress BIOS Rescue
Support for Download Center
Support for Xpress Recovery2
Support for EasyTune (Note 6)
Support for Smart Recovery
Support for On/Off Charge
Support for Q-Share
Bundle Software
Operating System
Support for Microsoft Windows 7/ Vista/ XP
Form Factor
Micro ATX Form Factor; 24.4cm x 24.4cm
Was £42.95 Inc. VAT
ORDER NOW
Thermaltake Armor Revo Gaming Case - Black/Blue @ £132.98 inc VAT
Gamers and PC enthusiasts have long revered the Thermaltake Armor as an excellent and spacious chassis to house a high performance rig. With the Thermaltake Armor Revo's pure aesthetic gaming design and engineering deliver impressive amount of features that not only looks awesome but also fully integrated as well. From the inclusion of the latest internal USB 3.0 header to the ability to support high-performance 24cm water cooling radiator, the Armor Revo has the best of both world. While many other chassis claims high airflow design by stuffing as many fans into the case as possible, Thermaltake engineers placed three oversized 200mm blue LED fans and a 140mm rear exhaust fan in strategic locations, in addition to the CableClear cable management, to not only improve overall airflow but to prevent airflow blockage as well.
- Dimension (H x W x D): 586 x 254 x 552 mm
- Side Panel: Transparent Window
- Colour: Exterior & Interior : Black
- Material: SECC
- Cooling System: Front (intake) : 200 x 200 x 30 mm Blue LED fan x 1 (600~800rpm, 13~15dBA)
- Rear (exhaust): 140 x 140 x 25 mm Turbo fan (1000rpm,16dBA)
- Top (exhaust): 200 x 200 x 30 mm Blue LED fan (600~800rpm, 13~15dBA) / 140 x 140 x 25 mm or 120 x 120 x 25 mm (optional)
- Side (intake): Plug&Play 200 x 200 x 30 mm fan (600~800rpm, 13~15dBA)
- Bottom (Intake): 120 x 120 x 25 mm (optional)
- Drive Bays: Accessible: 4 x 5.25’’, 1 x 3.5’’ (Converted from one 5.25” drive bay)
- Hidden: 6 x 3.5’’ or 2.5’’
- HDD Docking: 1 x 3.5’’ or 2.5’’
- Expansion Slots: 8
- Motherboards: 9.6” x 9.6” (Micro ATX), 12” x 9.6” (ATX)
- I/O Ports: USB 3.0 x 2, USB 2.0 x 2, eSATA x 1, HD Audio x 1
- PSU: Standard PS2 PSU
- LCS Upgradable: Supports 1/2”?3/8”?1/4” water tube
- Other: CPU cooler height limitation: 180mm / VGA length limitation: 330mm
Only £132.98 inc VAT.
ORDER NOW
Thermaltake Armor Revo Gaming Case - Snow Edition @ £132.98 inc VAT
- Material: SECC
ORDER NOW
Intel Liquid Cooling Solution CPU Cooler (Socket LGA1155 / 1156 / 1366 / 2011) @ £69.98 inc VAT
Intel teamed up with no other than Asetek to offer the Intel RTS2011LC self contained water cooler kit. Asetek have been making these type of kits for a while and was behind the Corsair H50 and H70 as well as the Antec Kuhler 620 and 920.
- Socket LGA1155/LGA1156//LGA1366/LGA2011
- Fan Speed: 800-2200 RPM (4 wire PWM)
- Fan Dimensions: 120 mm x 120 mm x 25 mm
- Fan Airflow: 74CFM
- Unit Noise Level: 21dBA@800 RPM / 35dBA @ 2200 RPM
- Radiator Dimensions: 150mm x 118mm x 37mm
- Pump Z-Height: 33mm
- Total Thermal Solution Weight: 820 grams
- Cooling Liquid: Propylene Glycol
- Thermal Interface Material: TC-1996
Was £73.98 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Thermaltake Armor A30 LAN Gaming Case - Black @ £74.99 inc VAT
This A30 Armor case from Thermaltake is the ideal option for any budding LAN party regular. Small, portable yet about to house powerful gaming rigs then this case is right up your street. Includes new technology such as USB3.0 front support and a windowed side panel.
- Characteristic black bulletproof armor design with metal mesh elements;
- Top and front blue LED fan creates combat ambience and excellent ventilation
- Front I/O with USB 3.0 SuperSpeed Connector
- USB 3.0 x 1, USB 2.0 x 1, eSATA x 1 , HD Audio x 1
- Support for 13" GPU's
- 5.25" Drive Bays: 2
- Ext. 3.5" Drive Bay: 1
- Int. 3.5" Drive Bay: 2 & 2 x 2.5" SSD / HDD
- Expansion Slots: 4
- Front Cooling(intake): 90 x 90 x 25 mm blue LED fan (1200rpm, 16dBA )
- Rear Cooling(exhaust): 60 x 60 x 25 mm fan x 2 (1500rpm,18dBA)
- Top Cooling (exhaust): 230 x 230 x 20 mm blue LED fan (800rpm, 15dBA)
Was £79.99 Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
NZXT KRAKEN X40 AIO Water Cooling Unit - 140mm (Socket 775 / 1155 / 1156 / 1366 / 2011 / AMD AM2 / AM3 / AM3+ / FM1) @ £78.98 inc VAT
NZXT introduces the Kraken series, the first premium all-in-one water coolers for PC enthusiasts. The Kraken X40 is a high-end 140mm water cooling solution where ease of use meets functionality. Included is one NZXT FX-140 PWM fan, with capacity to install an additional in a push-pull configuration for unrivaled cooling performance. At the core of the cooler is a state-of-the-art pump attached to an all copper base. Bridging the radiator and pump are extra-long 16” tubing and premium sleeved cables, allowing Kraken X40 to be easily installed into even the largest chassis. We developed the Kraken series to be the best closed loop water cojolers on the market. Our customers should not settle for anything less.
• World's first all-in-one 140mm cooler with capacity to mount up to two 140mm fans
• High performance pump and copper block with interactive digital fan control
• Integrated HUE controlled LED pump cap
• Large tower support with extended 16" tubing and premium black sleeved cables for a clean look and improved airflow
• Completed sealed system backed by a 2 year warranty
• Material - Copper
• Pump Motor Speed: 2900 + 150 RPM
• Voltage: 12V
• Current 175 mA
• Fan Control: Interactive Digital Fan Control
• LED Color: Hue Controlled Color Changing Lights
• Fan Model: NZXT FX-140
• Dimension: 140 x 140 x 25 mm
• Speed: 800 - 2000 RPM + 10%
• Noise: 21 - 37dBA
• Voltage: 4.5 - 12V
• Air Flow : 54 - 98.3 CFM
• Air Pressure: 0.8 - 2.2 mm-H2O
• Connector: 4 Pin PWM
• Radiator Dimension: 138.4 x 27.0 x 172.5mm
• Material: Aluminum
• Tube Length: 400 mm
• Material: Rubber
Was £84.98 Inc. VAT
Only £78.98 inc VAT.
ORDER NOW
Thermaltake Chaser A31 Gaming Windowed Case - Black/Blue @ £76.98 inc VAT
The new Thermaltake Chaser A31 gaming case designed for computer gamers and enthusiasts that deliver a combination of cooling, performance and expandability any full tower features within this ultra-mean case. It has an e-sports appearance and outstanding protection designs that characterize a unique personality. Take a look at the side, the transparent windowed panel offers the best inner view for built system see through. Since gaming hardware produces a lot of heat, therefore this enclosure is built for maximum cool with a perforated front bezel with two 120 mm fans at front and rear. The two USB 3.0 SuperSpeed ports are located on front panel for faster data transfer and easy access. There's even an user friendly tray on top for mobile, mp3player, digital camera have lying around. The Chaser A31 is maximally customizable to fit user’s needs; the modular design lets you modify the placement of the front fans and hard drive cages. Get ready to be envied at the next LAN party.
- Dimension (H x W x D): 501 x 212 x 495mm
- Front Cooling: (intake) : 120 x 120 x 25 mm Turbo fan x 1 (1000rpm, 16dBA) / 120 x 120 x 25 mm (optional)
- Rear Cooling: (exhaust): 120 x 120 x 25 mm Blue LED fan (1000rpm,16dBA)
- Top Cooling (exhaust): (optional) 120 x 120 x 25 mm fan x 2 or 140 x 140 x 25 mm fan x 2
- Bottom Cooling(Intake) : (optional) 120 x 120 x 25 mm fan
- Drive Bays: Accessible: 3 x 5.25’’ , 1 x 3.5’’ (Converted from one 5.25” drive bay) / Hidden: 6 x 3.5’’ or 2.5’’
- Expansion Slots: 7
- Motherboard Support: 9.6” x 9.6” (Micro ATX), 12” x 9.6” (ATX)
- I/O Ports: USB 3.0 x 2, HD Audio x 1
- PSU: Standard PS2 PSU (optional)
- CPU cooler height limitation: 160mm
- VGA length limitation: 290mm(with HDD rack) / 410mm(without HDD rack)
Was £79.99 Inc. VAT
Only £76.98 inc VAT.
ORDER NOW
Prolimatech Magnetic Fan Pins (4pack) - Blue @ £3.60 inc VAT
These magnetic pins allow you to fix you fans to your chassis without the presence of vibration noises that normal screws provide.
- Material: Rubber / metal
- Color: Blue
- Contents: 4 magnetic rubber pins in storage box
- Compatibility (fan): without continuous web of the mounting holes
- Compatibility (housing): material: ferromagnetic (eg steel, nickel)
Was £3.95 Inc. VAT
Only £3.60 inc VAT.
ORDER NOW
Thermaltake Element Q mini-ITX HTPC Case - 220W Power Supply @ £51.98 inc VAT
This mini-ITX desktop or HTPC chassis is made from steel inside and out, and the front is capped with black plastic that houses the signature Element red trim. The outside of the entire chassis is black while the inside is left exposed. In the front there is room for a full sized 5.25" optical drive above a slot for either an internal 3.5" drive or it can be used to install a floppy drive externally. Below these you find the front I/O panel behind a cover with a press to release lock. Once the panel is open it will expose the connectivity for the two USB 2.0, MIC, and headphone jacks.
- Case Type: Mini Case
- Material: Steel
- Front Bezel Material: Plastic
- Motherboard Support: Mini ITX
- 5.25" Drive Bays: 1
- Int. 3.5" Drive Bay: 1
- Expansion Slots: 1
- Front I/O Ports: USB 2.0 x 2 / HD Audio
- Power Supply Supported: SFX
- Power Supply Included: 200W SFX Power Supply
- Dimensions: 64.07mm H x 125.53mm W x 100.29mm
Was £56.99 Inc. VAT
Only £51.98 inc VAT.
ORDER NOW
Thermaltake Commander Snow Edition Midi Tower Case - Black/White @ £43.98 inc VAT
The Commander MS-I Snow Edition is equipped with extra-long VGA support which will hold some premium weapons (graphic cards) in the market, such as nVidia GTX590 and AMD Radeon HD6990 with ease, cable management and 12cm blue LED fan to enhance air mobility (ventilation), USB2.0 and USB 3.0(internal 19pin) front I/O slots allow direct data transfers during combat situation, and 9 drive bays grant with maximum magazine (HDD, optical drives) storability so you will never run out of resources!
- Case Type: Middle Tower
- Net Weight: 4.5 kg / 9.9 lb
- Dimension (H x W x D): 426.0 x 202.0 x 484.0 mm (16.8 x 8.0 x 19.1 ) inch
- Front Cooling (Intake): 120 x 120 x 25 mm (optional)
- Rear Cooling (Exhaust): 120 x 120 x 25 mm Blue LED fan, 1000rpm, 16dBA
- Top Cooling (Exhaust): 120 x 120 x 25 mm (optional)
- Bottom Cooling (Intake): 120 x 120 x 25 mm (optional)
- Drive Bays: Accessible: 3 x 5.25’’, 1 x 3.5’’ / Hidden: 5 x 3.5’’, 1 x 2.5”
- Motherboards: Micro ATX / Standard ATX
- I/O Ports: USB2.0 x 1, USB3.0 x 1, MIC & Speaker (support AC’97 & HD Audio)
Was £46.99 Inc. VAT
Only £43.98 inc VAT.
ORDER NOW
"Titan 8700i Pulse" Intel Core i5 3570K 3.40GHz @ 4.40GHz DDR3 Ivybridge Gaming PC @ £608.98 inc VAT
Get ready to game with the "Titan 8700i Pulse"! Featuring the Intel Core i5 3570K overclocked to a ridiculous 4.40Ghz, you can enjoy ultra smooth framerates and an immersive computing experience. With a the latest DX11 graphics cards, equip yourself ready for the game ahead. With a massive 500GB hard drive you will never run out of space for your essential data. 8GB of memory provides a smooth computing experience, the "Titan 8700i Pulse" is finished off with the fantastic range of gaming cases to choose from.
Why You Should Buy This System
- A guaranteed 4.40GHz performance for the price of 3.40GHz
- Cinematic DX11 graphics
- Precision built and cabled by Overclockers UK expert technicians
- 8 Hours stressed tested and quality controlled
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
- All systems with an Windows 7 selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012. Not compatible with Windows 8.
System Specification
- Case: Xigmatek Alfar Midi Tower Windowed Case - Black/White (default choice, options available)
- Power Supply: Corsair GS 600w PSU
- CPU: Intel Core i5 3570K 3.40GHz @ 4.40GHz Ivybridge CPU
- Motherboard: Asus P8Z77-V LX2 Intel Z77 (Socket 1155) DDR3 Motherboard
- Cooler: Corsair H60 Water Cooler CPU Cooler
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 500GB HDD
- Graphics Card: ATI Radeon HD 5450 SILENT 512MB (default choice, options available)
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 24x DVD+/-RW SATA Drive
- Wireless: Asus USB-N10 Micro USB Network Adapter Wireless-N 150Mbps
Service Package
- Full 24 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Immense overclocks, powerful graphics and sleek hardware all combine to create the "Titan 8700i Pulse", perfect for the gaming enthusiast.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow 7 working days for your system to be built and configured. This may take longer during busier periods.
*Fast track service subject to current stock levels during busier periods.
Was £659.98 Inc. VAT
Only £608.98 inc VAT.
ORDER NOW
Thermaltake Level 10 GT Visionary Full Tower Case - Black @ £199.98 inc VAT
Following the high-profile launch of Level 10 Super Gaming Modular Case, the design collaboration between Thermaltake and BMW Group DesignworksUSA, in 2009, Thermaltake looks to invigorate the PC enthusiasts with the latest Level 10 GT computer case. The design language of the Level 10 GT expresses a passion for visual aesthetics deriving from demanding and immersive game play and multimedia entertainment enthusiasm. Modern games and entertainment applications also require highly advanced hardware configurations, which at the same time request more space and optimized ventilation than conventional hardware. With EasySwap Pitstop 5 every HDD/SDD has its own removable tray, EasySwap in hot-plug mode within seconds. With this users have greatest storage flexibility and maximum data transfer speeds you need. Modern multimedia peripherals operate at tremendous data transfer velocities, with 2 USB 3.0 connectors right on the top of the Level 10 GT you be guaranteed to always enjoy SuperSpeed entertainment. The concept of the clear lines of the outside design of the Level 10 GT is just as well continued in the inside. An advanced and highly convenient cable management bundles respective cables almost like in tunnels behind a back plate. Your system shines in clarity, easy access to all components is warranted for and even ventilation is greatly improved. High tech components are prone to heat impacting longevity and performance. For this vital reason the implementation of Thermaltake's QuadFan (of which three also feature ColorShift) Ventilation concept creates an ideal environment for your components to unfold their full potential. Perception of what and how it is surrounding us, can have strongly inspiring, motivating and vitalizing effects on us. With triple ColorShift three LED fans with five sets of illuminations let you get into the driver seat of your respective moods. Or if so wanted, you turn them all entirely. At times enthusiasm may push you to the ultimate limits, to where you have not been before. Particularly for those who are bound to go beyond these restrictions, i.e. tune and clock your setting, further measures to keep the heat down might be asked for. Ready for Liquid Cooling Systems you can rest assured to keep your coolness. Powerful performance needs space to unfold, this is also the case for highly advanced graphics cards, which the length has grown considerable over the past years and is most likely to grow even further in the future. With space for up to 37 cm oversized cards, there is sufficient space to stay future proof.
- Performance cooling made quiet: one top 200mm exhaust fan, one front 200mm intake fan, one side 200mm intake fan and one rear 140mm exhaust fan.
- Hinged side panel to enable easier opening of the side door and access to computer for maintenance or upgrade.
- Dramatically improved cable management. User no longer "hides" the excessive cable on the back, the Level 10 GT features numerous holders designed into the chassis for cable management.
- Five hot-swappable hard drive bays, each with its dedicated backplane to support hot-swap. Hard drive mounting supports both 2.5" or 3.5" drives.
- Connectivity array. Four USB 2.0 ports are conveniently located on the front bezel including a pair of audio ports. Two USB 3.0 ports and one eSATA port located on the top.
- Water cooling ready - 120mm or 240mm radiators can be easily attached to the top side of the chassis (top 200m fan needs to be removed)
- Fan speed management control embedded. ColorShift fans can be easily controlled through controls on the top.
- Fully black-powdered interior.
Was £209.99 Inc. VAT
Only £199.98 inc VAT.
ORDER NOW
Thermaltake Level 10 GT Visionary Full Tower Case - White 'Snow Edition' @ £209.99 inc VAT
Was £219.98 Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
Thermalright Archon SB-E X2 CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £55.19 inc VAT
Ever since the introduction of the first Archon “Slim Tower Heatsink” back in 2010, Thermalright has never stopped improving on its own design. Incorporating our new proprietary Pressure Vault Bracket System we introduce to the world the all new Archon SB-E X2. Aside from a total overhaul and upgrade of the mounting bracket system, the Archon SB-E X2 will be using two TY-141 high efficient double ball bearing silent fans, giving enthusiasts the perfect mash-up of performance, compatibility and silenceEver since the introduction of the first Archon “Slim Tower Heatsink” back in 2010,
Incorporating our new proprietary Pressure Vault Bracket System we introduce to the world the all new Archon SB-E X2. Aside from a total overhaul and upgrade of the mounting bracket system, the Archon SB-E X2 will be using two TY-141 high efficient double ball bearing silent fans, giving enthusiasts the perfect mash-up of performance, compatibility and silence!
The Archon SB-E X2 inherits the same award wining heatpipe design from the Archon SB-E. Eight 6mm sintered copper heatpipes along with a massive 170mm x 150mm heatsink footprint allows the pipes to equally disperse heat from the CPU to the heatsink fins, so no bit of airflow is left to waste! Archon SB-E X2’s Slim Tower design is only 53mm across. This allows the Archon SB-E X2 to be fully compatible with RAM of all kinds, so power users are free to fill their RAM slots with high-end overclocked RAM.
Premium performance is only the beginning when it comes to Thermalright products. Silence is equally important, so striking a balance with performance is key. The Archon SB-E X2 comes with two TY-141 140mm silent fans. The TY-141 utilizes Thermalright’s new Silent Torpedo fin design, delivering a massive 73.6 CFM for only 21dBA of silence! The Archon SB-E X2 is Silence and Performance done right, brought to you only by Thermalright!
• Heatsink Dimensions : L155 mm x W53 mm x H170 mm
• Weight : 775g (Heatsink Only)
• Heatpipes: Eight 6mm Copper Heatpipes
• Copper Base: C1100 Pure Copper Mirror Finished base with Nickel Plating.
Was £59.99 Inc. VAT
Only £55.19 inc VAT.
ORDER NOW
Thermaltake Level 10 GTS Gaming Case - Black @ £84.98 inc VAT
The highlight of Thermaltake cases are Level 10 GTS, a mid-tower of pedigree with the innate aesthetics and dynamic mechanism, inherited the unique characteristic of its predecessors Level 10 and Level 10 GT. It has equipped with two internal Superspeed USB 3.0 front ports, four EasySwap HDD bays and HDD security system to advance data management, advanced cable management, excessive ventilation options with built-in dust filters offer a clutter-free and dust-free environment, and last but not the least tool-free drive locking devices and combat headset holder grant instant accessibility and a clean surrounding. To deliver the best gaming experience in all respects, the special edition “Level 10 GTS Battle Dragon” is proven to be a member of the royal family and ready to take on any challenge for enthusiasts under all kind of situation with the Battle Dragon mark on their case! The Battle Dragon has sanctified Level 10 GTS with a powerful and ferocious Battle Dragon totem on the side panel for its purity of ancestry.
- 5.25" Drive Bay: 4
- Int. 3.5" Drive Bay: 1x internal (also fit 2.5")
- 4x Easy Swap Bays (Also fit 2.5")
- Front I/O Ports: USB3.0 X 2 / USB2.0 X 2 / Audio port
- Top Cooling (Exhaust): 200 x 200 x 30 mm fan x1 or 120 x 120 x 25 mm fan x2
- Rear Cooling (Exhaust): 120 x 120 x 25 mm Blue LED Fan
- Front Cooling (Intake): 200 x 200 x 20 mm blue LED fan
- Bottom Cooling (Intake): 120 x 120 x 25 mm fan
- Side Cooling (Intake): 200 x 200 x 30 mm fan x 1 or 140 x 140 x 25 mm fan x 1
Was £89.99 Inc. VAT
Only £84.98 inc VAT.
ORDER NOW
Thermaltake Level 10 GT Visionary Full Tower "Battle Edition" Case - Army Green @ £209.99 inc VAT
ORDER NOW
"Primo 6100i" Intel Core i3 2120 3.30GHz DDR3 Dual Core System @ £305.99 inc VAT
The "Primo 6100i" features a Intel Core i3 2120 3.30GHz processor seamless multi-tasking capabilities which is perfect for home/office use. Awesome power contained within a small chassis the "Primo Ignition" has the option to upgrade to one of many of the latest Low Power, energy efficient Nvidia series graphics cards for extra graphical punch. Utilising Hyper threading technology the "Primo Ignition" makes short work of video encoding and multitasking.
Why You Should Buy This System?
- Intel Core i3 2120 3.30GHz (Clarkdale) Processor with Hyperthreading technology for 4 Virtual cores
- 500GB Hard drive gives massive storage capacity including DVD Re-Writer Make this system perfect for data backup
- Case: IMP microATX Case
- Power Supply: OcUK 500W PSU
- CPU: Intel Core i3 2120 3.30GHz (Clarkdale) Dual Core CPU
- Motherboard: Gigabyte H61MA-D2V Intel H61 (Socket 1155) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- RAM: 4GB or 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: Seagate Barracuda 7200.12 1TB SATA 6Gb/s 64MB Cache HDD
- Graphics Card: Onboard Intel GMA graphics or a choice of energy efficient graphics cards
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: OcUK 24x DVD+RW SATA ReWriter
- 802.11N Wireless Network Adapter
Service Package
With multiple video outputs, compact size and advanced hyperthreading technology the "Primo 6100i" is perfect for the user looking for a highperformance system for a low price.
Was £335.99 Inc. VAT
Only £305.99 inc VAT.
ORDER NOW
Thermaltake Level 10 GTS Gaming Case - Snow Edition @ £84.98 inc VAT
Was £89.99 Inc. VAT
ORDER NOW
Thermaltake Soprano Tower Case - White @ £94.98 inc VAT
The classic case from Thermaltake; The Soprano was brilliant back in its hey-day. However Thermaltake have decided to rejuvenate it by releasing a new and up to date refreshed version. This case has all the brilliance of the original but includes newer features and design.
- Case Type: Mid Tower
- Dimension (H x W x D): 460 x 220 x 510 mm (18 x 8.7 x 20 inch)
- Colour: Exterior & Interior : Black & White
- Material: SECC
- Front Cooling: 200 x 200 x 20 mm Blue LED fan x 1 (600rpm, 13dBA)
- Rear Cooling: 120 x 120 x 25 mm Turbo fan (1000rpm,16dBA)
- Bottom Cooling: 120 x 120 x 25 mm
- Hidden: 5 x 3.5’’ or 2.5’’
- I/O Ports: USB 3.0 x 2, USB 2.0 x 2, HD Audio x 1
- LCS Support: 1/2” / 3/8” 1/4” water tube
- Other: CPU cooler height limitation: 175mm / VGA length limitation: 315mm
Was £109.99 Inc. VAT
Only £94.98 inc VAT.
ORDER NOW
Thermaltake Soprano Tower Case - Black @ £94.98 inc VAT
- Material: SECC
ORDER NOW
Thermaltake V3 "BlacX Edition" Midi Tower Case - Black @ £42.98 inc VAT
The new V3 BlacX Edition chassis is designed with the goal of offering more to the advocates who have excessive data to manage and required more than a stand chassis for daily usage but still keeping it within the means. With that initiative in mind, we used the V3 Black Edition chassis by adding our BlacX docking station to accomplish the goal. The BlacX docking station enhanced the original V3 Black Edition chassis data management ability and kept all the great functionality of the V3 Black Edition chassis. The new V3 BlacX Edition chassis is a mid-tower that will accommodates all ATX or ITX motherboards, three 5.25” and one 3.5” bays accessible from the front, and further four 3.5” and one 2.5” bays are accessible from the inside built with a modern all black interior and exterior design. The external Superspeed USB 3.0 and the top-mounted HDD docking station, provide a trouble-free environment and convenience data management for the advocates. Moreover, the bottom based PSU mount and metal mesh front bezel with dust filter, plus the option for 3 additional case fans: the front panel allows to add a 120 mm intake fan, the top panel offers the possibility to install a 120 mm exhaust fan and on the bottom is room for yet one more intake fan to optimize ventilation.
- Net Weight: 4.8 kg / 10.6 lb
- Dimension: D473.0 x W190.0 x H445.6 mm
- Front Cooling (Intake) : 120 x 120 x 25 mm (optional)
- Drive Bays: External: 3 x 5.25’’, 1 x 3.5’’
- Hidden: 4 x 3.5’’, 1 x 2.5”
- HDD Docking: 1 x 3.5” or 1 x 2.5”
- Material SECC
- Expansion Slots 7
- Motherboard Support: Micro ATX & Standard ATX
- I/O Ports: USB3.0 x 1, USB2.0 x 1, MIC & Speaker (support AC’97 & HD Audio)
Was £46.99 Inc. VAT
Only £42.98 inc VAT.
ORDER NOW
Thermalright True Spirit 140 CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £33.59 inc VAT
Ultra style heatsink fin array, with copper base, elevates heatsink’s overall quality. Large heatsink fin array, provides dissipating area of up to 150*125mm, make complete use of the airflow, with 140mm or 120mm fan. With the max width of 55mm, tall memory spreaders are no issue. The cooler is supplied with one Thermalright TY-140 PWM fan, ultra low noise at 21 dBA at max rpm (50cm testing distance)
Fan-clips are compatible with both 140mm and 120mm fan.
Heatsink Specifications:
- Dimension: Length 155mm x Width 53mm x Height 170mm
- Weight: 771g (including fan and pads. excluding mounting brackets)
- Heatpipe: 6mm heatpipe*6 units
- Copper Base: C1100 Pure copper nickel plated with mirror shine
Fan Specification:
- Dimension: L160mm x H140mm x W26.5mm
- Weight: 140g
- Fan speed: 900~1300RPM (PWM controlled)
- Fan noise: 19~21dBA
- Airflow: 56~73CFM
- Connector: 4 Pin (PWM Fan connector)
Was £39.95 Inc. VAT
Only £33.59 inc VAT.
ORDER NOW
Noiseblocker BlackSilent Pro Fan PM2 - 40mm @ £8.40 inc VAT
Noiseblocker is the number one specialist for quiet fans. To achieve this, the company relies on maximum quality with low and high manufacturing tolerances, technological know-how and advanced German engineering.
In addition, the Noiseblocker prides itself on quoting technical specifications at realistic values.
The mounting system of the fan is very refined and minimizes vibration transfer. Here, a large silicon frame provides a reduced volume.
Even the cables have been thought about, Noiseblocker has come up with something special. 20cm and 50cm sleeved cables are included in the package meaning you have maximum control over cable management. Connection is via 3-pin.
Technical details:
Dimensions: 40 x 40 x 25 mm
Volume: 17.7 dB (A)
Speed: 3,800 r / min
Airflow: 9,2 m³ / h
Starting voltage: 5 V
Operating voltage: 5 - 13.2 V
Power consumption: 0.81 W
Connector: 3-pin (20 +50 cm cable)
Life expectancy: 100,000 hours
Warranty: 6 Years
Was £8.99 Inc. VAT
Only £8.40 inc VAT.
ORDER NOW
Noiseblocker Multiframe S-Series M8-S3 HS Fan - 80mm @ £10.80 inc VAT
The Multiframe S series made by (((Noiseblocker)))®, which is generally recognised as the reference standard, is the first fan with a vibration-free fan frame and incorporates numerous other improvements, so that it is superior to standard fans in almost all aspects.
In conjunction with the unique (((Noiseblocker)))® technology, our almost noise-free NB-NanoSLI® bearing and the NB-EKAPlus II drive, the NB-Multiframe® S series currently represents the best that German engineering expertise has to offer. Quality you can rely on!
- Dimensions: 80x80x25mm
- Noise Level: 19dbA
- RPM: 2200rpm
Was £11.99 Inc. VAT
Only £10.80 inc VAT.
ORDER NOW
Noiseblocker Multiframe S-Series M8 S1 - 80mm @ £10.80 inc VAT
- Noise Level: 6dbA
- RPM: 1200rpm
Was £11.99 Inc. VAT
ORDER NOW
Noiseblocker BlackSilent Pro Fan P-1 - 80mm @ £10.80 inc VAT
Technical details:
Dimensions: 80 x 80 x 25 mm
Volume: 15.4 dB (A)
Speed: 1,500 r / min
Airflow: 29,3 m³ / h
Life Expectancy: 160,000 hours
Warranty: 6 Years
Was £11.99 Inc. VAT
ORDER NOW
Noiseblocker BlackSilent Pro Fan PE-1 - 92mm @ £9.60 inc VAT
The high-quality NB-EKA Plus II drive and the almost noiseless NB-NanoSLI bearings guarantee operating noise levels which are particularly low over the long term - both equipment features which until now have only been used as part of the costlier Multiframe Reference series.
In addition to the tasteful design in matte black and mirror finish, the BlackSilentPro fans are equipped with an individually extendable cable management system and an NB-Silentframe silicone seal and installation material for vibration-free assembly without tools.
- Dimensions: 92x92x25mm
- Noise Level: 14dbA
- RPM: 1300rpm
Was £9.98 Inc. VAT
Only £9.60 inc VAT.
ORDER NOW
Noiseblocker Multiframe S-Series M12-S2 Fan - 120mm @ £15.60 inc VAT
- Dimensions: 120x120x25mm
- RPM: 1250rpm
Was £15.98 Inc. VAT
Only £15.60 inc VAT.
ORDER NOW
Noiseblocker Multiframe S-Series M12-S3 HS Fan - 120mm @ £15.60 inc VAT
- Noise Level: 27dbA
- RPM: 1800rpm
Was £15.98 Inc. VAT
ORDER NOW
Noiseblocker Multiframe S-Series M12-P Fan - 120mm PWM @ £15.60 inc VAT
- Noise Level: 29dbA
- RPM: 2000rpm
Was £15.98 Inc. VAT
ORDER NOW
Noiseblocker BlackSilent Fan XLP Fan - 120mm PWM @ £7.20 inc VAT
The fact that good quality does not have to be expensive is shown by the third version of the NB-BlackSilentFan series. The well-balanced properties of this bestseller make this inexpensive and high-quality series of fans the absolute bestseller throughout the world.
Our least expensive series of fans moves in such high circles, however, that other producers come off worse in direct comparisons even with their considerably more expensive "high-end" fans.
- Noise Level: 31dbA
- RPM: 2000rpm
Was £7.99 Inc. VAT
Only £7.20 inc VAT.
ORDER NOW
Noiseblocker NB-eLoop Fan B12-1 - 120mm @ £13.20 inc VAT
Noiseblocker already have the largest range of fans aiming to be the quietest on the market.
Noiseblocker eLoop fans are designed to reduce as much frame vibration as possible to avoid resonation being transferred into the chassis.
The most striking feature of the Noiseblocker eLoop fan is a completely new wing design that makes noise levels in the air stream even quieter. This allows the use of a directed air flow with less wasted air flow.
The new fans are based on the research findings of Dr. Rudolf Bannasch Bionikers, who has developed his research with the basic principles of the rotor loop. The new technology has been in development for the past two years, then brought to the development laboratory at Noiseblocker.
Technical details:
B12-1 : 800rpm, 7.83 dBA, 57.3 m³/h
Dimensions: 120 x 120 x 25 mm
Noise level: max. 7.83 dB (A)
Speed: max. 800 r / min
Airflow: max. 57.3 m³ / h
Starting voltage: 5.4V
Power consumption: 0.33 W
Connector: 3-pin
Warranty: 6 Years
Was £13.99 Inc. VAT
Only £13.20 inc VAT.
ORDER NOW
Noiseblocker BlackSilent Fan XK2 - 140mm @ £8.40 inc VAT
- Dimensions: 140x140x25mm
- RPM: 1100rpm
Was £8.99 Inc. VAT
Only £8.40 inc VAT.
ORDER NOW
Noiseblocker BlackSilent Pro Fan PK3 - 140mm @ £14.40 inc VAT
- RPM: 1700rpm
Was £14.99 Inc. VAT
Only £14.40 inc VAT.
ORDER NOW
Z77 Gamer PRO Intel Core i7 3770K 3.50GHz @ 4.40GHz DDR3 Ivybridge Overclocked Bundle @ £549.95 inc VAT
Designed by experts the "Z77 Gamer PRO OC Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Z77 Gamer PRO OC Bundle" offers you value and performance in perfect combination.
Why You Should Buy This Bundle?
- Prebuilt and configured. Just "plug and play"
- Quad core, hyperthreading Intel Core i7 3770K overclocked to 4.50GHz!
- 16GB of Dual Channel DDR3 memory delivers fast load times
- Intel Z77 Chipset for future proof computing
Bundle Specification
- CPU: Intel Core i7 3770K 3.50GHz @ 4.40GHz Quad Core CPU
- Motherboard: Asus P8Z77-V (Socket 1155) DDR3 Motherboard
- RAM: Patriot Intel Extreme Masters 16GB DDR3 1600MHz Dual Channel
- Cooler: Prolimatech Megahalems CPU Cooler - Black w/x2 120MM Zaward Golf III Fans
Service Package
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £594.95 Inc. VAT
Only £549.95 inc VAT.
ORDER NOW
Prolimatech PK-1 Nano Thermal Compound (1g) @ £0.83 inc VAT
The Prolimatech PK-1 Nano Aluminium Thermal Compound is thermal compound that is entirely environmentally safe and recyclable. Even with that being said it is at the head of the pack as far as performance, and is very easy to apply.
- Excellent long-term stability
- Non-electronically conductive
- Non-corrosive
- Easy to apply and less to use
- No "burn-in" time required
- Low dry-out
Was £1.99 Inc. VAT
Only £0.83 inc VAT.
ORDER NOW
Prolimatech PK-2 Nano Aluminium Thermal Paste - 5g @ £7.20 inc VAT
When putting down, nothing beats smooth and easy. That is why we created the PK-2 thermal compound. The PK-2 thermal compound is a high performance thermal bonding agent specially designed for easy application.PK-2's core feature is its low viscosity, allowing for one to quickly and easily apply the thinnest coat of thermal compound possible.This will get your components up close and personal in no time.
• Easy Application
• Easy Application
• Low Dry-Out
• Non-Corrosive
• Electrically Non-Conductive
• Wide range of application temperature
One Syringe of thermal compound amd one easy-to-spread spoon
Was £7.49 Inc. VAT
Only £7.20 inc VAT.
ORDER NOW
Prolimatech PK-3 Nano Aluminium Thermal Paste - 1,5g @ £3.60 inc VAT
Like two hot lovers, a heatsink and the processor want to make full contact. But microscopic imperfections in their craftsmanship create small gap for air. These gaps act as thermal insulators, inhibiting the transfer of thermal energy from your components. PK-3 thermal compound is made up of specially designed nano particles, engineered to correct these imperfections. The nano particles work by filling in the small air gaps and allowing for peak transfer of heat away from your components.
• High Thermal Conductivity
• Low Thermal Resistance
• Long-Term Stability
• Non-Corrosive
• Non-Corrosive
• No "burn-in" time required
One syringe of thermal compound and one easy-spread card
Was £4.50 Inc. VAT
Only £3.60 inc VAT.
ORDER NOW
XSPC K2 Thermal Compound 1.5g @ £4.80 inc VAT
High performance thermal compound for CPU and GPU water blocks.
- Thermal Conductivity = >4.0 W/mK
- Thermal Impedance = < 0.185 C-in2/W
- Viscosity at 25C = 76 CPS
- 1.5g Tube
Was £4.99 Inc. VAT
Only £4.80 inc VAT.
ORDER NOW
Corsair Vengeance 2000 Wireless 7.1 Professional Gaming Headset @ £105.98 inc VAT
Corsair Vengeance™ 2000 delivers the clutter-free freedom of wireless, high-quality 5.1/7.1 surround sound technology, superior audio fidelity, and a comfortable design. Experience true wireless freedom with up to 40 feet of range and 10 hours of battery life. Optimized HRTF technology provides precise positional audio cues for an incredibly immersive gaming experience. Large 50mm audio drivers have been painstakingly tuned for tight bass response - so lows are greatly enhanced without being distorted. Noise-cancelling mic prevents background sounds from interfering with VOIP chat. Large, sound-isolating circumaural earcups have microfiber-covered memory foam earpads. Padded headband stays comfortable over long play sessions.
Free yourself
Experience wireless freedom with up to 40 feet of range and 10 hours of battery life
Optimized HRTF positional audio technology
Experience immersive multi-channel gaming the way it was intended
50mm audio drivers and high-sensitivity noise cancelling mic
High bandwidth audio quality and clear in game chat
Large diameter, circumaural earcup design
Blocks distracting sounds and keeps your head in the game
Comfortable microfiber covers and memory-foam pads
Ear pads that provide improved comfort and conform to the shape of your head
Was £114.98 Inc. VAT
Only £105.98 inc VAT.
ORDER NOW
Logitech G930 7.1 Surround Sound Wireless USB Headset @ £120.00 inc VAT
Level up without being tied down. Gaming-grade wireless gives you a lag-free, interference-resistant connection with a range of up to 12 metres (40 feet) - so nothing stands between you and victory. 7.1 surround sound powered by Dolby technology delivers a detailed, positional soundfield that lets you hear your opponents before they see you. You'll have total command over music, voice morphing, chat clients and more with three programmable G-keys. And a memory foam-lined headband fends off fatigue, while plush ear pads ease pressure points and seal out unwanted noise.
- Gaming-grade wireless performance
- 7.1 surround sound
- Three programmable G-keys
- Memory foam-lined headband
- Noise-cancelling microphone
Was £129.98 Inc. VAT
Only £120.00 inc VAT.
ORDER NOW
Roccat Kave 5.1 Surround Sound Analog Gaming Headset @ £60.00 inc VAT
nonl2br
<br>
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels. <br>
<br>
- Real 5.1 Surround sound with speakers aligned at a 12° angle<br>
- Microphone with mute LED fully rotatable and completely removable<br>
- Tip’N’Control desktop remote for central management of all volume functions<br>
- Dual sound-profile with movie and game settings<br>
- Solid aluminium hinges enabling heavy duty use<br>
- Hand-sewn comfortable earcups featuring external noise cancelling<br>
- Adjustable vibration unit for a realistic gaming experience <br>
- Headband with three pads for equal weight distribution<br>
- Easy to carry folding and compact design <br>
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/125bfd1f2f2cc9251cc512dfde5e4fb1.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/f620e869ce025933aeef18e4d0fd3894.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/798d360d6701787365c7266f8cf96fbe.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/48545abd6c12c63d38c082c343da0099.jpg">
<br>
<script type="text/css">
#youtube {
float:right;
margin-left: 50px;
</script>
<div id="youtube">
<iframe width="640" height="390" src="http://www.youtube.com/embed/yEyXafzsrB0" frameborder="0" allowfullscreen></iframe>
</div>
Was £65.99 Inc. VAT
Only £60.00 inc VAT.
ORDER NOW
Enermax Platimax 750w '80 Plus Platinum' Modular Power Supply (EPM750AWT) @ £159.98 inc VAT
The Enermax Platimax 750W is a High-performance power supply topology which uses all magnetic quadrants of the main transformer to achieve maximum efficiency and rock stable output voltage. It features Innovative and patented transmission technology for direct voltage transmission to reduce the wire-resistance and to increase the efficiency.
- 80 Plus Platinum
- Dynamic Hybrid Transformer Topology
- Copper Bridge Array
- Multi Rail Design
- Special OC Edition
- Future ready and flexible
- Full Modular Cable Management
- Fit4Server
- DX 11 Ready
- HeatGuard
- CordGuard
- SafeGuard
- High Quality Japanese Capacitors
- 5 Year Warranty
Was £172.99 Inc. VAT
Only £159.98 inc VAT.
ORDER NOW
Enermax Platimax 850w '80 Plus Platinum' Modular Power Supply (EPM850AWT) @ £182.99 inc VAT
The Enermax Platimax 850W is a High-performance power supply topology which uses all magnetic quadrants of the main transformer to achieve maximum efficiency and rock stable output voltage. It features Innovative and patented transmission technology for direct voltage transmission to reduce the wire-resistance and to increase the efficiency.
- 80 Plus Platinum
- Multi Rail Design
- Fit4Server
- DX 11 Ready
- HeatGuard
- CordGuard
- SafeGuard
- 5 Year Warranty
Was £192.98 Inc. VAT
Only £182.99 inc VAT.
ORDER NOW
Enermax Platimax 1000w '80 Plus Platinum' Modular Power Supply (EPM1000AWT) @ £229.98 inc VAT
The Enermax Platimax 1000W is a High-performance power supply topology which uses all magnetic quadrants of the main transformer to achieve maximum efficiency and rock stable output voltage. It features Innovative and patented transmission technology for direct voltage transmission to reduce the wire-resistance and to increase the efficiency.
- 80 Plus Platinum
- Multi Rail Design
- Fit4Server
- DX 11 Ready
- HeatGuard
- CordGuard
- SafeGuard
- 5 Year Warranty
Was £241.99 Inc. VAT
Only £229.98 inc VAT.
ORDER NOW
Enermax Platimax 1500w '80 Plus Platinum' Modular Power Supply (EPM1500AWT) @ £264.98 inc VAT
The Enermax Platimax 1500W is a High-performance power supply topology which uses all magnetic quadrants of the main transformer to achieve maximum efficiency and rock stable output voltage. It features Innovative and patented transmission technology for direct voltage transmission to reduce the wire-resistance and to increase the efficiency.
- 80 Plus Platinum
- Multi Rail Design
- Fit4Server
- DX 11 Ready
- HeatGuard
- CordGuard
- SafeGuard
- 5 Year Warranty
Was £284.99 Inc. VAT
Only £264.98 inc VAT.
ORDER NOW
Enermax Revolution 87+ 650w '80 Plus Gold' Modular Power Supply (ERV650AWT-G) @ £109.98 inc VAT
The revolution 87+ range of PSU's from Enermax offer stable and safe power supply thanks to four high-performance and massive 12V rails each with separated over current protection (OCP). Extremely low ripple noise. DC-to-DC converter for minimum energy losses and maximum efficiency as well as best possible and most stable voltage regulation at dynamic and cross loading. Technological breakthrough topology using a staged dynamic transformer array for extremely high efficiency with the most durable and stable output at any load. Integrated 13.9cm fan with patented Twister Bearing Technology ensures efficient and ultra silent cooling and long lifetime (100,000 hours MTBF).
- 80 Plus Gold certifed
- Dynaminc Hybrid Transformer Topology
- Quad Multi Rail Design
- Speed Guard
- Heat Guard
- High Quality Japanese Capactiors
- Safe Guard
- Cool Guard
- 5 Year Warranty
Was £117.98 Inc. VAT
Only £109.98 inc VAT.
ORDER NOW
Enermax Revolution 87+ 850w '80 Plus Gold' Modular Power Supply (ERV850AWT-G) @ £149.99 inc VAT
- Speed Guard
- Heat Guard
- Safe Guard
- Cool Guard
- 5 Year Warranty
Was £159.98 Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Enermax Revolution 87+ 1000w '80 Plus Gold' Modular Power Supply (ERV1000AWT-G) @ £179.99 inc VAT
- Speed Guard
- Heat Guard
- Safe Guard
- Cool Guard
- 5 Year Warranty
Was £194.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Enermax Triathlor 450w '80 Plus Bronze' Power Supply (ETL450AWT) @ £57.98 inc VAT
The new Enermax Triathlor range supports two massive 12V rails to power high-performance processors and graphics cards. More than 98 percent of the total power of the PSU can be delivered by the key rails only. Stable voltage output even at 0W load. In this way, Triathlor supports the energy-saving functions of modern CPU and graphics cards (C6 State/Hybrid Mode) and prevents compatibility issues. Smooth running 12cm T.B.Silence fan with patented Twister bearing (100,000 hours MTBF) and powerful Batwing blades for very effective and silent cooling.
- 80 Plus Bronze
- DC to DC design
- Full GPU and CPU Power from two 12 Rails which deliver 98% of the rated power
- OCP on all the rails
- 12cm T.B. Silence fans
- Speed Guard
- Air Guard
- Safe Guard
- High quality Japanese Capacitors
- Scratch resistance housing
- 3 Year Warranty
Was £62.99 Inc. VAT
Only £57.98 inc VAT.
ORDER NOW
Enermax Triathlor 550w '80 Plus Bronze' Power Supply (ETL550AWT) @ £64.98 inc VAT
- 80 Plus Bronze
- DC to DC design
- Speed Guard
- Air Guard
- Safe Guard
- 3 Year Warranty
Was £69.98 Inc. VAT
Only £64.98 inc VAT.
ORDER NOW
Enermax Triathlor FC 550w '80 Plus Bronze' Modular Power Supply (ETA550AWT-M) @ £71.99 inc VAT
The new Enermax Triathlor range supports two massive 12V rails to power high-performance processors and graphics cards. More than 98 percent of the total power of the PSU can be delivered by the key rails only. Stable voltage output even at 0W load. In this way, Triathlor supports the energy-saving functions of modern CPU and graphics cards (C6 State/Hybrid Mode) and prevents compatibility issues. Smooth running 12cm T.B.Silence fan with patented Twister bearing (100,000 hours MTBF) and powerful Batwing blades for very effective and silent cooling. All-round modular cable management. 10/12P sockets for possible connector changes of upcoming high-performance CPU and graphics card generations.
- 80 Plus Bronze
- DC to DC design
- Speed Guard
- Air Guard
- Safe Guard
- 3 Year Warranty
Was £76.99 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Enermax Triathlor FC 700w '80 Plus Bronze' Modular Power Supply (ETA750AWT-M) @ £89.99 inc VAT
- 80 Plus Bronze
- DC to DC design
- Speed Guard
- Air Guard
- Safe Guard
- 3 Year Warranty
Was £94.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Qpad MK-85 Red LED Pro Backlit Mechanical Gaming Keyboard - UK Layout - Black Switches @ £99.98 inc VAT
nonl2br
<img src="http://www.overclockers.co.uk/LP/productimages/keyboard/black.gif">
<br>
Unlike your average keyboard, that functions through rubber domes, forcing you to press each key all the way down in order for the stroke to register, the MK-85 feature true mechanical switches with unmatched accuracy and feel. No more pressing with full-force in order to activate the keys.The QPAD keyboard will respond to your every stroke in an instant.<br>
<br>
Other boards normally have a short life span and wear out quickly, resulting in unresponsiveness, delays and a dull, clunky feel to the keys. The key switches on MK-85 are built to last 50 million strokes, and the QPAD mechanical key technology provides distinct feedback and puts you in absolute control. The travel distance of the keys is set to 4mm with an actuation point at 2mm.<br>
<br>
For gamers, it’s all about the feel and functionallity and that is where the QPAD MK-85 truly shines. With a full size keyboard layout in 3 sections, gaming profiles, macro recording, mechanical key switches, media keys and full N-Key roll over via USB, it’s the perfect gaming keyboard. Nuff said...<br>
<br>
- Key switch: Cherry black MX mechanical switch technology<br>
- N Key Roll over: Full N-Key roll over via USB<br>
- Key strokes: 50 Million<br>
- Lighting: Individual LED backlight on every key for enhanced visuals<br>
- Lighting features: Four levels of brigthness allow you to locate keys easily<br>
- Connectors: Gold plated USB connectors for extremly low latency<br>
- Media keys: Media keys for volume control, play, pause and skip tracks<br>
- USB Hub: Two high speed USB 2.0 ports<br>
- Audio ports: 3.5mm headphone-out and microphone-in jacks<br>
- Cable: 1.8 meter braided cable<br>
- Extras: 4 extra orange key caps and key cap puller<br>
- Dimensions: Keyboard: 44,8 x 14,9 x 3,5 cm (17,6 x 5,8 x 1,37 inch)<br>
- Wrist pad: 44,8 x 6,6 x 1,7 cm (17,6 x 2,48 x 0,66 inch)<br>
- Weight: 1.27 Kg (2.8 LBS)<br>
- Warranty: 2 year<br>
- Software: Customizable profiles, programmable keys and macro recording<br>
- Supports: Windows XP, Vista, 7<br>
Only £99.98 inc VAT.
ORDER NOW
Qpad MK-85 Red LED Pro Backlit Mechanical Gaming Keyboard - UK Layout - Red Switches @ £99.98 inc VAT
nonl2br
<img src="http://www.overclockers.co.uk/LP/productimages/keyboard/red.gif">
<br>
<br>
<br>
<br>
- Key switch: Cherry MX mechanical switch technology<br>
- Cherry Red Switches<br>
ORDER NOW
