GTX 660 Ti SLI Clocks
20 Jul 2012
Manchester
I've had my 660 ti SLI setup for a few weeks now, and have noticed that my first card consistently clocks below my second card.
It's usually 30-50Mhz lower, even though both are set at the same core values in afterburner. I was just wondering if this was normal or not.
Cheers.
It will throttle back when it hits 70c and because it is the top card, it will get hot fairly quick. Make sure your case has good airflow and apart from water cooling, not much you can do about it.
They generally don't hit 70C. The only time I've seen the top card hit 70C is in Crysis 3. The clocks are different even when at 50C :confused:
Is one of my cards just not as good as the other?
Yer that will be the case.
Have you tried syncing the cards when overclocking?
Yeah I've always had it on sync, as I heard running cards at different clocks is more likely to cause microstutter.
Oh well :( It's not a big deal I guess.
