Spec me a Gaming PC
Its a coolermaster bundle so will come with a GX550w. Not the best psu in the world but will certainly not go BANG!!
Lol, cheers. I have a coolermaster psu and it ain't caused me any bother yet. It's setting him back only £24 extra for the case + psu bundle, so it won't hurt to upgrade it if it starts playing silly buggers.
Slight problem...we've already sourced a case called a Silencio 550 which comes with a 550w psu.
The rest of the spec will be the i5 3570k CPU
The z77 MB & the low profile 8gb ram
The lad wants a SSD and a HDD for storage.
He was wrong about OS for next to nowt, it's Windows Office that he gets cheap, so we'll need an OS but he's unsure on W7 or W8. Will there be a problem running old games like BF2 on Windows 8?
Then, it's just a case of a DVD rw drive.
YOUR BASKET
1 x Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with Crysis 3 & Bioshock PC Games £239.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x Plextor M5 Pro 128GB Extreme Series Solid State Drive - (PX-128M5P) £99.95
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £82.99
1 x **B Grade** Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache - OEM £45.00
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (PV38G186C9K) £41.99
1 x Samsung SH-224BB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM £18.95
Total : £720.85 (includes shipping : £10.00).
Not a great case choice to be honest. I've used the smaller version myself, you are limited on heatsink height to 154mm (off the top of my head). This makes his choice of coolers limited for overclocking the i5K, most of the decent ones are 160mm or there abouts unless you go with a CLC setup instead.
I did toy with using the HIS 7950 as it's external exhaust, the sound proofing will insulate the case making temps higher. I left the OS out as he can try the evalutation of windows 8 for 3 months (free), if he doesn't like it then he can buy 7 no harm done.
Cheers. The case is beautiful if a little tight, but he's having it in his living room, so that's why he didn't want the 'orrid neon lit ones with go-faster stripes. Jeez, there's some that look like Stormtroopers.
OverclOcking is a long way off, but nevertheless it is something both he and I might/will eventually do. So what is CLC? There's always water cooling option too.
So Windows 8 is free for 3 months? Where does one find the files, please?
There are a few cases that do look like a stormtrooper in a blender though there are quite a lot that are elegant and classy; brands such as Corsair, Fractal, Lian Li and BitFenix opt for this approach..
A CLC is a Closed Loop Cooler (Or closed Liquid cooler) either way, its watercooling. This is OCUK's selection: http://www.overclockers.co.uk/productlist.php?groupid=701&catid=2330&subid=2262
The good thing with these is the take up little space, only 1 x 120mm fan spot and offer great cooling.. Means you don't need to worry about your cooler fitting in the case. :)
It's personal preference fella. I used the Silencio 450 a while back, the front USB3 ports didn't hook up internally to the mobo. If the 550 is the same an adapter for the mobo header would be wise.
Doomed has covered the CLCs nicely. Click HERE for the evaluation iso download
That's great, thanks, thanks all who have tried to help. We're nearly there now, just one or two things to decide. Big decision this as it's his first PC and it's a lot of money to dish out on something you're trying out.
One last question...the ATI 7950 was overwhelmingly recommended by all those who posted a spec for me, so going on that, I take it it's a better card than the Nvidia GTX 660 TI?
Cheers.
Cheers.
If you don't use Nvidia's CUDA or PhysX, Yes!
The HD 7950 performs better than the GTX 660 Ti, overclock the HD 7950 and it will be similar to the GTX 680
Never heard of them, but just read a short synopsis on CUDA, something about shifting some of the work onto the processor. Is it free software?
It's used by software like adobe but AMD GPUs can be used too. It's mostly for video encoding but you also get Quicksync from the CPU but again it's software dependant. CUDA is quite widely supported, Quicksync not so much.
PhysX isn't supported by that many games to get worried about it. For £240 with games the 7950 is really great. I don't think the 7970 is worth the extra as you can OC the 7950. For the price of the 7970 I'd take the Nvidia 670 which once overclocked is essentially a 680.
