Does this overclock look ok?
That doesn't sound good..
I hit high 60's at 4.4 on my H50 and stopped,,
It sounds like 4.5 is your limit mate.
Yeah I agree its too high, but I have a few ways to combat it up my sleeve. Ill be replacing the Corsair thermal paste with Arctic Siver, add a second fan to the radiator for push/pull (waiting on screws to arrive) and then the extra case fans once my controller arrives. Also going to try and lower the voltage further as I think im giving it a bit more than is required.
Then again there is always this :D Hmmmm.
Well I can think of one reason for a rise in temperature, my bloody radiator fan was plugged in wrong! Thank christ I had a problem with my ram or I might never have noticed it!
*palmface*
LOL at myself, at 4.6 the temps at full load are around the mid 50s now that the fan is on.
Much better! It sounds like you're using constant voltage, as opposed to offset, from your earlier post. It has benefits in that it is typically more stable when you start pushing the limits of your chip, but for energy efficiency you could also try offset overclocking by setting your vcore to normal and then adding offset voltage until it reaches what you needed to get stable. That way, when idle your voltage will drop dramatically, reducing idle temps and power usage. But you risk instability.
What volts are you running now (under load)?
E: 80C under prime95 isn't bad for passive cooling at 4.6GHz ;)
seems you have a really nice chip there...wanna swap? :)
If its for a 3770k, sure! :p
Ill have a play around with the voltages tonight if I get a chance, Im happy with it being a bit less efficient but since the comp will most likely sit idle 80% of the time it might be a good idea to do what you have suggested.
Currently stable at 4.8, voltage is up at 1.275 and temps max out at 64 under Prime 95, quite pleased!
Very nice, considering you didn't know what you were doing 3 days ago.
I sooo need to get some decent cooling now.
From reading the guides on here I knew roughlyhow to do it, I just didnt know whether it was being done well and had no idea what all the abbreviations stood for or where everything was in the BIOS as the guites are quite out of date now. This thread has been a great help so thanks to all the guys :)
Epic volts for 4.8GHz mate! Looks like you got a really cherry :) Now play some games, run some benchmarks and generally mooch about to make sure it's stable, as prime95 can only do so much to test stability.
