VBA help needed ...
23 Apr 2007
Cardiff-ish, Wales
Hi guys and gals,
Any VBA gurus out there?
I'm trying to get some code working that will go through each sheet and turn off the scrollbars etc. It's intended to be part of some code that will get a dashboard ready for a slideshow and I want to maximise the real estate of the charts on the screen. Anyway, I'm getting a "Object doesn't support this property or method" message. What have I done wrong?
Thanks in advance,
Jed.
Code:
Sub ShowMenus()
        Sheets("Leads Today").Select
        ActiveWindow.DisplayScrollBars = True
        ActiveWindow.DisplayFormulaBar = True
        ActiveWindow.DisplayStatusBar = True
        ActiveWindow.DisplayHeadings = True
        Sheets("Order Intake Today").Select
        Sheets("Leads Month").Select
        Sheets("Order Intake Month").Select
End Sub
Sorted! I recorded a macro and it came up with a different structure. I then added the Status Bar line, that I couldn't see within the manual menu option and repeated for all the sheets. I'm sure there's a prettier way of doing it, but this works and will do for now :D
Code:
Sub ShowMenus()
   Application.DisplayFormulaBar = True
   Application.DisplayStatusBar = True
    With ActiveWindow
        .DisplayHorizontalScrollBar = True
        .DisplayVerticalScrollBar = True
        .DisplayWorkbookTabs = True
    End With
    With ActiveWindow
    End With
    With ActiveWindow
    End With
    With ActiveWindow
    End With
End Sub
Not sure why you'd have to repeat so much. Wouldn't this do the same?
Code:
Sub ShowMenus()
    With ActiveWindow
    End With
  End Sub
For some reason the DisplayHeadings part wouldn't work when it was within the With ActiveWindow bit.
Ideally I'd just have that one piece of code wrapped within a loop function, but that's beyond my skill ... at the moment ;) Feel free to help me out though if you can :D
Huh... just noticed you're in Maidenhead, I'm in the Travelodge, working at Three during the week. Small world :)
Dim ws as worksheet
Dim wb as workbook
Set wb = thisworkbook
For each ws in wb.worksheets
''put code doing stuff in in here
Next ws
set wb = nothing
That will loop through every worksheet in your workbook
but as you have found out scroll bars, menu bars, formula bars etc are at the application level so you can just set them in one go:)
lol I work opposite three in Sita. i was underneath the travelodge in the sainsburys earlier to get my lunch.
