E90 330d Steptronic Gearbox
13 Dec 2002
Newcastle upon Tyne
So I just recently got my E90 330d Sport, its running fine at the minute but someone has just told me their prone to gearbox problems, any truth in this? its shifting smooth as silk at the moment when it goes in for its engine oil service next month should I be enquiring about a gearbox oil change? In the service booklet theres no mention about this
80k just done today, it has full bmw service history but from what I can tell in the service book theres no mention of gearbox oil change?
There is no scheduled transmission oil change. If you intend to keep the car for some time, I would maybe recommend changing it at that mileage.
Yeah, I think ill be keeping it (all being well) for at least a couple of years, been in touch with the two local bmw dealers to me one wanted £225 for an oil change and the other was £190 which is still a lot for what it is but £35 difference would go a bit towards the gearbox oil change I guess.
Just do the fluid..can't remember what it takes, I think its LT71141. If so just get the febi stuff, around £20 for 5L and just replace the fluid.
I wouldn't really bother with replacing the filter etc. Just remove the pan and clean it up.
Keep on top of fluid changes and give the valve body a service when you get to 100k. You'll be fine. The ZFs 6 speeds don't just randomly pop, they're quite good.
[TW]Fox;23946685 said:
They do tend to go, just keep 1.5k aside for when it goes and stop worrying about it.
It 'going' is not the problem, it starting to behave differently and be altogether a less pleasant transmission for tens of thousands of miles before hand is the problem!
The idea of replacing the ZF fluid, known for happily lasting a hundred thousand miles plus, with something 15% of the price would make me nervous. What ownership reports are there with Febi oil in the transmission long-term?
For the sake of £100 extra on a fluid going in to an automatic transmission for another 100,000 miles or more, I'd probably go for the ZF stuff :p
I haven't had any problems with my box (same car as you) to date but one thing I did notice is that after having the car serviced the other day, the gearbox behaves in a very different manner. It is holding on to gears a lot longer and doing a lot less searching on hills which is quite nice actually. Whatever they did to change it I like it :D
Would a fluid change in the gearbox void the BMW warranty?
Even though it's made in Germany, the correct yellow colour, and is specifically for Lt71141 ?
You like being taken for a ride don't you?
They might one day try to argue it, but that would never stand up; ZF themselves recommend changing the fluid in certain conditions.
Are all fluids the same if they are made in the same country with the right colour, to the same specs? Show me the chemistry report. A browny 5W-30 engine oil made in the UK to LL04 doesn't suddenly become the same as Castrol Edge.
Either unhooked the battery which cleared the throttle adaptions or the cleared the tranny adaptions via obd2.
