Current PSU capable?
16 Nov 2010
What do you guys think of my current PSU for output? Have done the usual calculator stuff on various sites but they don't take everything into the equation..
I've a "Corsair TX 650W ATX SLi Compliant Power Supply" & bear in mind its about 4 years old now.
My setup is...
Asus m4a79xtd evo mobo
2 sticks of ddr3 1333 mem. (I think)
Phenom x4 965 be oc'd to 3800 @ 1.4875 v
Giga windforce 3 670 factory oc'd (& oc'd some more & added +112% power limit in afterburner)
Western digi cav black 500 gb HD
blu ray combi player
Steel series merc stealth keyboard which has led backlighting
Razer death adder which also has led
front card reader
Antec 902 case with two front 120 mm led fans/1 rear 120mm fan/1 top led 200 mm fan
Zalman cnps 9700 LED cpu cooler.
Wondered how much wattage these extra fans & various glowy bits add to desired PSU wattage. (remember currently using 4 yr old corsair 650 watts psu).
No problems running just wondering if my system might be stretching the PSU.
cheers ..Andy
Your current PSU will not be breaking a sweat :D
At full load you will be lucky to pull 350w~
Fans and lights are negligable.
Your PSU is just ticking over its fine:)
Get a wall plug meter its good fun too see how much juice its using and when, £20 my one from s high street electronics store
Ok thanks for the input guys. I bought one of those meters a while back gonna have to see if I can find it tho..good idea as it'd be interesting to see power draw anyway tho I'm happy taking onboard that my psu is more than enough. Just something I'd been wondering about.
cheers again folks..Andy.
So a 750w is just for show?
To be fair if money wasn't as tight at time of my PSU purchase I'd have also gone for 750w+ especially after realising it won't use any more power than needed, & just to keep it future proof.."just in case".
Think I binned that wattage meter thinking I'd never find a use for it... :\
