ok am seeing a lot of things about this all over Google and here it seems to be so close then it side tracks to SLI 2 ect all i want to know is i got the money to buy 1 Asus GTX TITAN or GTX 690 am only going to buy 1 that's it am a gamer big time
Be far better off buying two GTX 680 to run in SLI instead of buying a 690 for the same money
Or even better off with 7950 crossfire for £400.
Titan gets trounced thoroughly on frame rates, but the microstutter is an issue. Depends whether it you can live with the stutter, a few hundred quid in my pocket would convince me I could.
I would look into crossfire tbh, or at least if you want a single card a 7990.
Many people around here will try to say its crap due to "microstutter" but they are blowing smoke out their bottoms.
Go into a PC shop, such as OCUK's shop and ask to look at some systems that run said crossfire or ask around.
if you have money to burn and want the BEST that this year can offer you so far then get a titan.
Microstutter is there and those frame latency times prove it is. When I was checking the smoothness in a couple of games on SLI 680's, It looked smooth but just didn't feel it. When I checked, it was very apparent it was there.
I didn't say it wasn't there... But only a handfull of people can see it, along with the fact AMD are addressing the issue in soon to be released drivers i dont see an issue?
If it was such a "BIG DEAL" like many on here make it out to be then why has this issue only been made a massive fuss of now?
I have used Crossfire with the 4k, 5k and 6k series from AMD, and never had an issue like many seem to report.
Seems like User problems to me
Not a lot of people know this but behind the scenes AMD are supporting the creator of radeonpro and have recently provided him with multiple monitors in order to help improve eyefinity issues.
I have to agree its not as big an issue as some are making it out to be, but it is an issue to be considered. It also affects some titles more than others. However, as far as crossfire is concerned there is a perfect solution and that is radeonpro. It will remove ALL microstutter, unless its a particular game issue/gpu scaling issue.
Back on topic. Probably best to listen to the advice of Kapstaad as he has owned both cards and can provide much better advice than me on which card would be better for you.
Both are pretty good tbh.![]()
This is where I did notice it on a couple of games when I had my 7970's/eyefinity,
radeonpro did a very good job of reducing it.![]()
It would be good to see some CF frame latency times in games like FarCry3/Crysis3/Tomb Raider at high resolutions and full details. These are the games I noticed microstutter more so because of the power needed to run on full details. Anything with loads of fps, it doesn't show or at least doesn't stick out so much.
If i win expect more latency benchmarks than you could ever possibly want.
