- 17 Mar 2013
- North Hampshire
Looking for the best gaming tower that £300 can buy, need all components so will be a challenge!
Thanks guys
Thanks guys
You don't need HDMI out to use a HDTV, I use a DVI to HDMI.. Works fine..
Spending more on a motherboard than the CPU ( and GPU) seems odd to me.
HDMI is easier and you know that. Unless he owns speakers already or wants to buy the 3.5mm adapter/lead to put the sound seperately through the TV or wear headphones.
The description for what is needed is vague at best....Spec away mate![]()
I use a DVi to HDMI and get sound through my TV. Using a monitor is a different story either way..
I did like your spec honest, just wasn't sure on the need for that good a motherboard... An A55 and an A6 seem about right![]()
i dont think youll be getting a decent pc for £300, if i was you i would save up until at least i have £700![]()
I really don't agree with you.
If you are a light to medium gamer who doesn't mind running medium/high settings trinity is your ticket and as proved you can get a good trinity build (with overc locking with the a75/a85 chipset) for that price...
Every gaming pc doesn't have to be an i5 with a 7850. £700 may be hard to get hold of...
Poor advice.
I don't think you'll be getting anywhere with that grammar and punctuation![]()
i personally dont think an AMD trinity will be future proof. it will be struggling to run present games so it will more than likely struggle with future games. it really depends on what type of games you want to play.I spec what I'd do with my cash. I'd want the better chipset/mobo which gave the HDMI output and the sataIII ports and overclocking options and the full ATX size. Gigabyte as we know has a 3 year UK based warranty and a dual (UEFI) BIOS as a nice safety feature.
You'd be surprised what Trinity can do on a tight budget......
And that's using "slow" 1600mhz RAM to feed the IGP and a cheap A55 mobo.
what youre saying is partly true, however i wouldnt call a £300 pc a gaming pc
So what price bracket does the definition of a 'gaming PC ' start and how is it defined?
A PC with enough graphical and processing power to okay game can be a gaming PC. An A6 rig will play a majority of non demanding and online games on high/ultra. And other titles at med/high..
Even some £1k + rigs can struggle with the likes of crysis 3 at ultra..
A gaming pc can only be defined by its uses and the demands of its user, to give demeaning advice as you did, isn't helpful (or welcome)
