i own an o/c 3570k running at 4.2ghz,but my gpu only seems to be running at around 60% in gpuz,i even put it my 7850 to stock speeds,any thing i can do? playing max payne 3 was the first time i noticed this
am running v sync(along with that virtu thingy)Are you running any form of vsync or frame limitter ?
As you are running v-sync, your card has less work to do. Therefore your gpu usage is lower. Disable v-sync, try a game and you will see higher gpu usage.
yesi know what v sync does,but whats that got to do with the low load on my card?or has it got something to do with only having 1gb of memory
