7950 and waterblock
The MSI TFIII V2s are decent if you're watercooling.
Other than that buy the cheapest voltage unlocked model you can and hope for a decent clocker :).
MSI TFIII V2 is this card unlocked and good for overclocking?
Is it ok with this card play crysis 3?
can you send link which waterblock will be the best for this card.. thx
It's a 7970 PCB version so any 7970 PCB block should work.
Overclocking is a lottery I'm afraid. But 7950s generally reach 1150-1200 though it's possible it won't.
Im just cant find this card on overlockers.co.uk
Oh MSI might have discontinued it. There was probs with the air coolers on them (not a prob if you're WC it).
In that case I would just get one with a decent warranty and the cheapest you can find. As I say, being a good overclocker is a bit of luck I'm afraid.
they are all good as each other , just the looks diff ,copper, silver, acy
so pick one you like look of & fine to fit on your card.
