Nowhere have I said anything about 2/4Gb 670/680's, that's yourself that keeps bleating on about it, not me, despite you knowing full well that I have witnessed the vram wall with plenty of gpu power in the tank when I hit it, to then keep trying to explain the difference between 2-4GB 6 series gpu grunt.
That's the topic though Tommy. That is what everyone is talking about. The 7900 vs 600 series debate isn't even a debate. It's clear cut.
Iv'e pointed it out before I'm talking about the limitations of the 2Gb/4Gb/ 256 bit bus combination but it's clearly not registering.
Bus yes, VRAM amount no. The two are linked but that doesn't automatically mean that the amount causes a problem because it doesn't. There's multiple users on this thread confirming it.
Quite clear and coherent I thought, for you then to go on about results last year that show zero bearing on titles released since and how it fairs against it's lesser counterpart that is the 7950 never mind the 7970 that quite clearly isn't shackled on the larger memory bus.
You keep saying this which is actually completely incoherent but you're yet to show anything with regards to the load on the GPU decreasing (so to increase FPS) so that the VRAM amount actually becomes a limit.
Thanks for the underlining but I'm quite capable of reading and taking on board text without it.
A 35%(which will be anything between 40-45% faster on the 79's) swing in performance isn't down to gpu grunt, it's down to the combination of gpu/vram/memory bus.
I'm using GPU grunt to simplify it as I know you struggle to digest complex debates unless it's down the right/wrong angle. Actually, it's down to GPU and memory bus actually, not VRAM. Gregster confirmed this from a more recent point of view just to completely unravel your "not recent" point anyway.
Move it on rusty and please stop implying/trying to put words in my mouth stating 2Gb vs 4Gb 67/80's vram argument, when I never mentioned anything about it.![]()
I'm not the one who keeps bleating on about the 600 series being VRAM limited for a surround set up having not used either... that's you. I'll repeat that, yes, the 7900 series are far superior on a triple screen set up but that doesn't necessarily mean the 600 series is insufficient. To try and suggest they are due to the VRAM amount is at best short sighted and at worst reckless when you're talking about people spending their own money.
