Graphics card that can sustain 3/4 monitors?
27 Feb 2013
Hey guys, currently running a gtx 460 and looking to upgrade my gpu just a bit in order to run 3 monitors concurrently... mostly for desktop usage and multitasking. I game but only a very little bit, right now just gw2, starcraft 2, and bf3 all of which my 460 handles very well for my needs. But I would really like to run 3 or more monitors at once, if I can sustain "eyefinity" or whatever that would be fine and dandy but this really isn't my main concern.
Would like to spend no more than about $200, need a card that can handle 3 or more outputs at the same time, would also need 4 connection slots as I will need to switch over to my TV when watching movies etc.
What would you recommend? More than likely going to purchase something used unless there is a crazy good shellshocker etc.
My current motherboard only has a single PCIe x16 slot so... I also don't mind buying a PCI card but no one can give me a straight answer and people keep linking me to $70 PCI cards which is a joke, I would rather just buy another 460 for a few bucks more you know?
Thanks
ATI 7950, 7970 or nVidia GTX 670/680
$200 thats about £130 so even second hand 7960 or 670 is pushing it a bit.
What inputs do your monitors have? as this will have a bearing on what adaptors would/might be needed for connections. If you need £20 worth of adaptors, that might have a bearing on your choices.
