Hi all,
I have a question about rolling out printers.
Our current set up is rolling them out using a login script, printers are installed on the server and shares set up. (\\server\printer)
The question I have is, is there a way of installing the associated print drivers on client machines without needed admin rights? It's fine on xp, but on vista upwards you need admin rights.
Ideally I would install all printer drivers for the site first, then use the login script to remove all the printers and re add them depending on the user type as different users need access to different printers.
Thanks all
Thanks all
