Hi all,
I just built a new rig for work. I wondered if it's possible to run 2 monitors directly off the motherboard.
I have 2 screens both of which have DVI & VGA. Is it possible to connect my main screen to the HDMI on the motherboard using a DVI - HDMI adapter? This would mean my 2nd screen would be connected the the boards VGA...
To add, I do have an old GPU which I was using with the old rig but as the on-board graphics are a lot better than this card I don't want to use it.
thanks!
thanks!
