- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello
The absolutely awesome R1600T has been selling well at £77.99inc however from now until 5PM on Friday the 22nd of March we have lowered the price making this speaker set possibly the most awesome value speaker set that money can buy!!!
Thats right... take a look below, read up on the specs and then drop your jaw in astonishment!
Edifier R1600T Studio Plus 2.0 Monitors
The Edifier R1600T Plus is a professional low-noise amplifier with all wood enclosure. The high performance crossover provides superior coverage while magnetic shielding prevents interference. The 5-inch bass driver is designed using a composite cone structure for a truly balanced acoustic. Built-in, side-mounted controls mean volume, treble and bass are at your fingertips. Dual RCA inputs allow connection of two additional devices for maximum flexibility in your set-up.
- Professional low-noise amplifier coupled with high performance crossover.
- 4.5inch bass driver - designed using a composite cone structure for a balanced acoustic.
- Silk diaphragm 18 mm tweeter with aluminum phase plug.
- Side mounted rotary volume, bass and treble controls.
- All wood enclosure.
- Power Output: RMS 2 × 16W
- Signal to noise ratio: 85 dBA
- Distortion: 0.1%
- Bass unit: 5 inch (120mm), magnetically shielded, 6ohm
- Tweeter unit: 18mm silk dome tweeter, magnetically shielded, 4 ohm
- Input impedance: 10K ohm
- Input sensitivity: 550 mV ± 50 mV.
- What's in the box:
- 1 x Active speaker
- 1 x Passive speaker
- 1 x 3.5mm to RCA connector cable
- Audio connecting cable
- User manual
- Dimensions: 152(W) x 252(H) x 228(D) (mm)
Was £77.99 Inc. VAT
ORDER NOW
Now.....
Only £49.99 inc VAT!!!!
- Distortion: 0.1%
- User manual
Was £77.99 Inc. VAT
ORDER NOW
Now.....
