Isn't that the chemistry?
No, the chemistry is determined by the colour of the lines between the players he is linked to!
Im confused in post 14547 there are red lines going across but he said their Chem is 9?![]()
) but the line represents how strong the link it between the players (ranging from red (bad) through to strong green (best)) but the workrate is either low, (red), medium (amber), or green (high) and is indicated by the small triangular arrow next to each player when you list them on Futwiz (or similar!) - as far as I know, these don't change depending on the other players as they are set for each one!
Red line means those players don't share anything in common with each other but you can boost them up to 9 chem if you surround them with other players who have strong links, same league and country or same team for instance.
Think I'll just keep my RPL and save the coins for IFs.
I don't get it, first you said it's red if they don't share anything in common but then you talk about same league and country or same team... so do they have something in common?????
:Got 65000 now. Not sure where to start for a gold team, any ideas?
Thanks
I see the triangles on Futwiz, wonder why EA have not shown them in game?
So Skirtel won't run forward either? How can I check the work rate of players before I buy them?
Thanks
Would you mind linking your squad? fancy making a RPL side myself.
Any preference on formations, players you'd like? playstyle?
Not too fussed really, just got back into Fifa and am lacking some knowledge. I am quite attacking though.
Aren't you on PS3 or am I thinking of somebody else?![]()
