So I have tried to place a movement sensor that is designed to scare cats ( designed to emit a low pitch sound)
Might I suggest something that emits a high pitched sound?
Failing that, chili powder works. As does a hose etc...
pick it up and smear it on your neighbours knob. that'll confuse him![]()
An air rifle.
Hose?
Mace it...
shotgun
Throw something heavy at them, or get a catapult and use some ball bearings or something painful.
Darwin will ensure the cat gets the message or ceases crapping.........forever.![]()
Super Soaker!!
Updated cat deterrent![]()
Typical common ****
Typical common ****
You have cats yourself yet you still come out with creepy stuff like this?An air rifle.
i take it ur a cat lover. If that's the case.. KEEP IT IN YOUR OWN GARDEN
Typical common *****
