Got my wife a 2010 Yaris 1.33 TR recently and I've noticed that it has what I can only describe as a sluggish accelerator. What I mean by this is put your foot down on the pedal and there's a distinct delay between the press and the engine revs climbing, there's also a similar delay when taking your foot off, so foot off the gas and the engine revs will die much slower then say in my Accord or the wifes previous Civic.
I've done a quick google and there are suggestions that range from cable needs greasing to that's how the car is to dual mass flywheel (whatever that is
) Doesn't cause any real issues except that it's very easy to stall the car and when I was driving car I found that the engine was racing between gear changes as the revs would still be high when depressing the clutch, do everything slower and it seems fine.
Anybody have any views/thoughts on this, before I take it to Toyota to look, don't want to look an idiot if it turns out to be normal.
