Can't change VCore in AfterBurner
17 Jul 2006
Want to push my 6950 a bit but the slider for core voltage is blank in AB.
Its a Twin FrozR III, the AB version is the latest i think 2.3.1
I've ticked the box to allow it in options, and done the config edit stuff, i can move the core clock and memory clock way up so the config edit worked...also disabled ccc. :confused:
Trixx works for core voltage but not vram voltage on the TFIII, I had this problem too, but ended up swapping it out for another Ice-Q as icba mucking about anymore between 2 different oc tools.
