aye, i'd also go vet route. Was just hinting at there maybe being a source of stress but if there's been no change to routine or environment tends to rule that out.
I'm unsure if they're the same as cats but I wouldn't doubt they are. You'll need to clean where he's peeing with a special cleaner, google it (I think one of the favorites is called Urine-Off)
Sounds like scenting behaviours e.i. Marking territory which isnt uncommon if changes have upset them , although vet route sounds best to rule out any infections or problems with going.
you really need to catch it about to - or jsut having wazzed there... then scold the patch of wee and dog and take it outside (the dog not wee).. lock it out for 5 mins that let it an and make a big fuss...
at night you should really try and get the dog outside until it pees
there are also other things you can try like putting down a bright mat / blanket where its peeing and then moving it (of the first thing dose not work)
