What do you think of these kits? I'm getting ready to buy either, is the D5 pump a worthwhile upgrade over the 750? It's £80 more which stings a little.
I'll only initially be cooling the CPU, with the posibility of later on adding at the most, one gpu into the equation, but I don't even have a GPU worth cooling at the moment, and won't be doing for a long time.
My goal is as silent as possibly, are there any noise issues with either pump?
I'll be using Scythe AP-15's, what do you think about push pull vs either push or pull?
Thankyou.
Thankyou.
