In relation to the side fan I have on my case which is situation over the GFX card, should I have air blowing into the case or air going out of the case? i.e should the arrow on the fan be pointing in the direction inside the case?
Cheers
If your gpu exhausts most of the heat our the rear, side intake.
If your gpu dumps most of the heat in the case, side exhaust.
This works best for me with an accelero gpu cooler. I can feel my side exhaust pumping out a lot of hot air.
You might try turning of the top front exhaust.. and it that helps maybe try it as a slow speed intake.My cooling setup is: 2x Scythe Gentle Typhoon front intake, 1 back exhaust, 2 top apache 140mm exhaust, 1 side apache 140mm exhaust/intake
You might try turning of the top front exhaust.. and it that helps maybe try it as a slow speed intake.![]()
I understand your logic, but I cannot for the life of me be bothered to take my system apart to swap a fan over hehe, I had to to fit them. -.-
Than just unplug the top front fan.
Not to be rash but I don't think you understand at all. Your intake area/cfm to exhaust area/cfm ratio is way out of whack.
You have 2x 120mm fans intake area = 226sq cm trying to supply air to 3x 140mm + 120mm exhaust fans = 574.6sq cm. That's more than twice the exhaust area as you have intake.... meaning your intake doesn't have snowball's chance in hell of supplying the air your exhaust is capable of. But if you unplug your top front fan those numbers change to 417sq cm in to383sq cm out.
At least if your top front is unplugged your intake : exhaust area ratio would go from 226:575 (half as much in as out) to 417:383 (just slightly more in than out) .![]()
I have never noticed any benefit having a side fan on my Arc Midi. I keep fitting one but always remove it as it makes no difference to temps.
This is a question I've seen a lot, so I've got some figures for you.
Running all my fans full whack playing Crysis 3 with the side fan as intake on two Windforce cards at 1254/1780 (dumps heat into case) my max temps were 67 on the top card, 60 on the bottom card. Fan profile:
With the side fan as exhaust my temps are a lot better:
In fact swapping the side fan to exhaust even dropped my CPU temps a little...
